One thing people tent overlook when choose lower cost SD card is the write performance. Take the PNY Performance Elite for example, if you look at the spec carefully, it is the read speed that is up to 95MB/s. there is no mention of write speed anywhere. Being a Class10 card, it needs to write at minimum of 10MB/s. With the relative low cost, I am pretty sure the write performance is on order of 10-15MB/s. Otherwise, they would have spelled it out on the spec. On top of that, this also means the flash used on this card is TLC flash (3 bit per cell), which is generally slower for write (as seen from spec or lack of) and far less reliable than MLC flash (2 bit per cell).
The other example on the previous post is Lexar profession card. The spec says 95MB/s read, 45MB/s write. This card costs 2x more, significant faster. To archieve 45MB/s write, this has to be a MLC (2-bit per cell) flash. TLC base SD is very unlikely, if possible at all to get to 45MB/s write.
While I don't think the write speed matter for a lot of usage, I will still recommend get the Lexar Prof type or equivalent just for reliability from MLC flash
