Thread started 01 Sep 2015 (Tuesday) 11:11
ADVICE - Godox Smart 250SDI
deviangel
Joined Aug 2012
Sep 01, 2015 11:11 |  #1
Hello guys, I need your advice. I own 2 softboxes which have 5 bulbs and power of 200w each softbox. I am new in studio photography but I want to buy Godox 250SDI and upgrade a little bit. I also own speedlight but I don't get enough light from these. I usually shoot stock, wedding and portrait photography. Is it good upgrade considering its 80$ and in my country that's a lot or not would you recommend something else?
Thank you for your time.
Canon 6D | Canon 85mm f/1.8 USM | Canon 50mm f/1.4 USM |
https://500px.com/devi​angel
deviangel
Joined Aug 2012
Sep 03, 2015 20:08 |  #2
I got this one isntead
http://www.godox.com …tudio_Flash_E_S​eries.html (external link)
the 300W version :)
Opinions?
Thank you
Phil ­ V
Joined Jan 2005
Sep 05, 2015 03:24 as a reply to  @ deviangel's post |  #3
If you haven't bought it yet - don't.
The built in reflector and lack of 'proper' mounting system makes it less than scaleable. From the same maker, this is really the entry level. (external link)
website: South Yorkshire Wedding photographer in Doncaster (external link)
Twitter (external link)Facebook (external link)
Whortleberry
Joined Dec 2011
Sep 05, 2015 05:14 |  #4
Phil V wrote in post #17695667 (external link)
Definitely agree with Phil V on this. The problem lies not in what you can do with either of the units initially mentioned, but what you can't do with them.
  • No chance of changing the built-in reflector.
  • No chance of changing to a softbox other than a fairly restricting umbrella-type.
  • Very limited adjustment power levels.
The thing to remember is that, at this stage, you may only be thinking of the immediate requirement. However, if you only buy to that level and no higher, you are automatically restricting your expansion ability. You don't say what 'your country' is so it's difficult to make specific suggestions but in general terms, I'd be looking at:-
  • Bowens mount for alternative reflectors / softboxes. Not because Bowens is 'the best' but simply because it offers you the greatest variety of options at an affordable level - not everyone can afford (for example) a selection of Elinchrom Deep Octas at GBP£250 each.
  • Absolute minimum 1/1 to 1/16 power adjustment; personally I'd prefer down to 1/32 or even lower if possible. It's very surprising how often you need just a tiny bit of power and anything which has a minimum setting of 1/8 can and will cause you problems. These can't always be fixed by moving the flash further away.
  • Don't buy something with a low maximum power. You can always turn the power down if working in a small room but if you suddenly need to light a whole wedding group you can't turn the power up beyond 100%.
  • Obviously, availability in your country. While internet vendors may seem to be universal, there are often restrictions imposed by individual countries which make import impossible or hugely expensive.
  • Let's not forget your budget! It's all very well saying (for example)"Buy only Broncolor, they're the best and you'll never regret it" except if you can't afford that particular brand then they obviously aren't the best for you.
  • Keep as many options open as utterly possible, so buy something which can be expanded to suit your individual requirements in the future.
  • Avoid really cheap flash units. There's almost always a really good reason that they're cheap and it's very rarely because the seller wants to do you a favour!
Phil ǁ Kershaw Soho Reflex: 4¼" Ross Xpres, 6½" Aldis, Super XX/ABC Pyro in 24 DDS, HP3/Meritol Metol in RFH, Johnson 'Scales' brand flash powder. Kodak Duo Six-20/Verichrome Pan. Other odd bits over the decades, simply to get the job done - not merely to polish and brag about cos I'm too mean to buy the polish!
FlickR (external link) ◄► "The Other Yongnuo User Guide v4.12" by Clive Bolton (external link) ◄► UK Railway Photographs 1906-79 (external link)
1,444 views & 0 likes for this thread, 3 members have posted to it.
1062 guests, 104 members online
