Thread started 01 Sep 2015 (Tuesday) 19:39
Question for upcoming first attempt at night sky photography
chrisr09
Joined Jun 2011
Sep 01, 2015 19:39 |  #1
I'm going to AZ shortly and will try for the first time to shoot the night sky. I live in a light polluted area so I'm really looking forward to the experience. I'm a hobbiest and don't have the specialized gear that is used in a lot of the shots I see posted here. I currently shoot with a Canon 6D and I already have the 16-35L f/4 and the 24-105L f/4. Will I be disappointed with these lenses? Just wondered if I need something faster. I was looking at Rokinon 14mm f/2.8, Rokinon 24mm f/1.4 or a Tokina 16-28 f/2.8. Would I get better results with any of these? I know the Rokinons are manual focus (I've never owned a MF lens). My hope is to be able to shoot the Milky Way (after I find out how to find it!). I just downloaded Stellarium to play around with.
I'd appreciate any thoughts you more experienced night shooters can offer me. I'm leaving in about 2 weeks. If what I have is sufficient, I'm happy. If I NEED one of the other lenses, I better get cracking so I have it before I leave.
Thanks!
Christine
Christine ~ My Flickr (external link) ~ My Fine Art America (external link)
Canon 5DIII & Canon 7DII ~ Canon 16-35mm f/4L ~ Canon 100mm f/2.8 Macro USM ~ Canon 24-105mm f/4L ~ Canon 400mm f/5.6L USM ~ Tamron 70-200 f/2.8 Di VC USD ~ Rokinon 14mm f/2.8 ~ Canon Speedlights 430 EX & 430 EXII ~ Induro CT-213 tripod ~ Acratech GP ballhead
wunhang
Sep 01, 2015 19:58 |  #2
For the night sky, my experience is if you hold the shutter for longer than 15 secs, you'll start noticing star trails. The Rokinons also have the added benefit of controlling coma very well (elongation of light pinpoints) and being quite affordable for what they can do. Manual focus with them can be a chore as their markings can be off (quality control at times).
Canon 5D IV | Canon 5D II | XSI (Infrared modified) | SL1 | 16-35mm L f/4.0 IS | 24-70mm L f/2.8 II | 40mm f/2.8 | 85mm f/1.8 | 70-200mm L f/4.0 IS | Rokinon 14mm f/2.8 | C/Y 28mm f/2.8 | Tamron 35mm f/1.8 VC | C/Y 50mm f/1.7 | Zeiss 100mm MP
::SmugMug (external link)::
sebjones86
Joined Apr 2014
Sep 03, 2015 17:45 |  #3
It depends what you're aiming for..
i would go with f/2.8 option lenses, smaller lens too, it'll fit alot more of milky way in the image too
on finding the milky way, on a clear night, you'll clearly see it! It's something to behold too, the first time i saw it in it's full glory, i was speechless!
good luck:-D
Light travels faster than sound, this is why people may appear bright until you hear them speak
SiriusDoggy
Sep 03, 2015 18:30 |  #4
Maybe you should rent it and also bring your 16-35 and compare the results by shooting the same subject with the same settings other than aperture being wide open on both lenses. With the Rokinon being 3 stops faster you will get the same results in 1/3 the time. And time is an issue since since the earth is rotating. At 24mm you can shoot for approx. 20 seconds on a full frame camera before noticeable trailing will start. Longer focal lengths will show trailing much sooner. Of course you can bump up the ISO to compensate for the slower f4 lenses but then you have to deal with noise at the higher ISO settings.
Here's a shot taken recently with the 5d MarkII, ISO 3200, Rokinon 24mm 1.4 and 20 seconds.
IMAGE: http://www.siriusproductionsllc.net/photos/i-mLFQB25/0/X2/i-mLFQB25-X2.jpg
Greg M.~
Scopes: Explore Scientific ED152CF & ED127mm, StellarVue SV70T, Classic Orange-Tube C-8, Lunt 80mm Ha single-stack solar scope.
Mounts: iOptron CEM70EC Mount, iOptron ZEQ25 Mount.
Cameras: ZWO ASI2600mm Pro, ZWO 2600MC Pro, ZWO 1600mm
Filters: Chroma 36mm LRGB & 3nm Ha, OIII, SII, L-Pro, L-eXtreme
Scrumhalf
Gallery: 158 photos
Joined Jul 2012
Sep 03, 2015 19:02 |  #5
Are you just shooting starfields, Milky Way shots, etc.? If you are going after deep sky objects, which you can easily do if you have a tracker, I would recommend a copy of "Turn Left at Orion." In my opinion, it is a must-have for any serious stargazer.
Here is a shot of M31 with a 6D and 70-200 II on an iOPTRON Skytracker. I didn't quite nail focus on this shot but it gives you a general idea of what can be done with relatively simple equipment provided you know where to look.
IMAGE: https://farm3.staticflickr.com/2897/14812128913_585e76c5f8_b.jpg
IMAGE LINK: https://flic.kr/p/oyU2​SZ  (external link) M31 - taken near John Day, Oregon (external link) by Scrumhalf (external link), on Flickr
Sam
5D4 | R7 | 7D2 | Reasonably good glass
If I don't get the shots I want with the gear I have, the only optics I need to examine is the mirror on the bathroom wall. The root cause will be there.
DanThoman
Sep 04, 2015 08:36 |  #6
Christine - You're going to have to use manual focus with any lens. Try focusing on a distant object before it gets dark (use live view at 10x) and if using a zoom like the 16-35L make sure to use tape or a rubber-band on the focus ring so you don't have lens creep. My 16-35L has performed well up to 30 sec exposure unguided. Try using a 15 second exposure and check your histogram. The hump should be close to the left edge. Take several photos and stack them if possible. This photo was taken at 16mm, iso 800, f2.8, 30 sec. I didn't stack because of clouds. There is some coma at the corners but it could have easily been cropped.
IMAGE: http://thomanstudio.com/img/s9/v16/p1419573491-4.jpg
Dan
my gear
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Sep 04, 2015 08:41 |  #7
chrisr09 wrote in post #17691754 (external link)
Thanks!
Christine
Heya,
You should be able to do fine with that 16-35 F4L and the 6D. No need to spend money unless you get into this really really deep (in which case, I'd absolutely suggest the Samyang 24 F1.4 for this specifically).
You should be able to shoot the 16-35L at F4 and ISO 3200~6400 at 20~30 seconds depending on conditions and selected focal length (I'd do 20~24mm on that lens) with the idea of rotation blur if you go too long on the focal length for time of exposure.
Should be fine!
The next challenge is learning to process the images. The initial capture will not be mind blowing, they never are. The amazing images you see around here are not SOOC, they are heavily processed and often composites even, so keep that in mind. There are several resources for ways to process the milky way. My suggestion is to slightly over-expose so you have more data to work with later in RAW.
Very best,
Intheswamp
Endeavor to Persevere
Gallery: 89 photos
Joined Sep 2013
Post edited over 8 years ago by Intheswamp.
Sep 04, 2015 11:06 |  #8
Below is a 20-second shot made with a Samyang 14mm (same as Rokinon) at f/2.8. Click on the image so you can go to Flickr and view the full resolution image (even though it is downsized from the original). If you do this you will see that this lens is indeed sharp wide open. With wider lenses you can get away with longer shutter speeds. In calculating shutter speeds so as not to have star trails check out the "500 Rule" which is more conservative than the "600 Rule"...no rule really, but something to go by to get pinpoint stars with no streaks/trails. The equation is to divide the focal length of the lens by 500 (conservative) or 600 (pushing the envelope). 500/16mm=31 sec. I would go no longer than this shutter-wise and would probably pull it back to 25 seconds or so, personally. Of course, if you want star trails...let'er rip! :)
It's nice to have a fast lens for capturing sporadic meteors.
A star map application for your smart phone would be handy. (I've got an archaic, dumb phone so I don't know what to suggest. :) ) You will most likely capture some galaxies and other dso's in your wide field images so the star map app would help you identify what you may be capturing. An intervalometer would be a great accessory for starting your camera and shooting off a long series of long exposures. Don't forget the tripod. A flashlight with a red filter helps retain your night vision (any kind of clear red plastic wrap (gift wrap?) will do)...but, a flashlight with no filter is better than no flashlight at all. ;) If they have bugs in AZ, then bug repellent.
Bring something to drink...and eat if you'll be out there a long time, along with a chair of some sort.
And most of all, have FUN!!!!! :)
Ed
IMAGE: https://farm1.staticflickr.com/581/20468779420_9730af718b_b.jpg
IMAGE LINK: https://flic.kr/p/xbKR​11  (external link) IMG_5482app (Custom) (external link) by Intheswamp (external link), on Flickr
The poorest of the poor. A country of children taking care of children: https://handsofloveusa​.org/ (external link)
My little weather page: www.beeweather.com (external link)
Scrumhalf
Gallery: 158 photos
Joined Jul 2012
Sep 04, 2015 12:07 |  #9
And some warm clothing. It gets cold at night in the desert! :)
Sam
bk2life
Gallery: 18 photos
Joined Nov 2010
Sep 04, 2015 12:14 |  #10
where in az are you going? That will help decide what you will and wont see. Also depends on your clothing, right now we are having a cold front and gettin high 80s and low 90s at night.. normally we're still above 100 at night.
could give you lots more ideas, and suggestions once we figure out where you are going when your here..
-james
5Diii|7D|Nifty 50|Canon 17-55mm-2.8|Canon 70-200L 2.8 IS ii|2x 600EX-RT|ST-E3-RT|CS6
chrisr09
Joined Jun 2011
Sep 04, 2015 20:20 as a reply to  @ sebjones86's post |  #11
Thanks for your suggestion. I was there (Elgin, AZ) two years ago for my brother-in-law's funeral. That was the first time I've ever seen a real dark sky. I was in awe of the beauty.
Not sure what I'm going for yet since I've never attempted this before. And I have to realize that I won't often get a chance to shoot such a dark sky. I'm trying to gather as much helpful info beforehand. I hope I retain some of it!
Hope I get something decent enough to share when I get back for a little critique.
chrisr09
Joined Jun 2011
Sep 04, 2015 20:25 as a reply to  @ SiriusDoggy's post |  #12
Lovely shot. I hope I can get something half this good. I know it will be my first attempt, so I have to be realistic in expectations. I'm going to try with the lenses I have and see if I have an interest in doing this more often. If so, that 24mm f/1.4 is what I'd have in mind.
chrisr09
Joined Jun 2011
Sep 04, 2015 20:28 as a reply to  @ Scrumhalf's post |  #13
That's an amazing shot. Nothing I would have guessed was possible with a 6D. Not sure I'm ready to jump into this type of photography in earnest but I will take a look at that book. Thanks!
chrisr09
Joined Jun 2011
Sep 04, 2015 20:34 as a reply to  @ DanThoman's post |  #14
Another beautiful shot. I appreciate your recommendations. I think I have my gear set, using my 16-35 f/4. I have headlamp, gaffers tape so I don't bump focus ring, sturdy tripod, shutter cable release. I've never stacked photos before but I'll be sure to take many exposures in case I want to try that. Keeping fingers crossed that I remember what to do when I'm actually out there! And the weather cooperates. Thanks!
chrisr09
Joined Jun 2011
Sep 04, 2015 20:39 as a reply to  @ MalVeauX's post |  #15
Appreciate your response and glad you think I'll be fine with my current gear. I can always add that 24mm f1.4 later if I find this is something I'd like to pursue more.
Post processing is a big factor, I'm sure. I have to remember that when viewing my pics SOOC and not get disappointed. Most of all, I want to enjoy my experience, not feel too pressured. Thanks!
8,819 views & 11 likes for this thread, 11 members have posted to it and it is followed by 7 members.
1325 guests, 109 members online
