I will be building this desk in the next few weeks. It fits into a corner of my living room and will house two computers. My main work station will be on the side with the added upper shelf, and a second desktop that my daughter uses will be on the top along the empty wall. The short section under the window (which has blackout drapes) will have my printer and scanner on it with a filing cabinet inside the "box" which will have doors on it so you can not see the cabinet.
Anyways just looking for suggestions on things to build into the desk. I have a pretty good idea already for cable management under the desk. And will be adding a dedicated usb charging hub as well as a hub for both computers for easy usb access. My computer is a laptop with a 27" monitor, the other is a desktop which I will build a bracket for under the desktop to keep it off the floor.
I should mention the little "L" shaped shelf on the blank wall can not be removed as much as i want to, my wife wants it there so it matches the wall on the other side of the room and so she can put pictures and other assorted "things" on it.
