Thread started 03 Mar 2006 (Friday) 22:09
Stofen vs 430EX onboard diffuser for direct flash work
Lightstream
Yoda
Joined Feb 2006
Mar 03, 2006 22:09 |  #1
I was just wondering about this issue..
When firing the flash directly at a subject, I've experimented with pulling down the 14mm diffuser panel to create a softer light even though I don't need the angle of coverage it provides. It does produce a noticeable, substantial softening of the shadows behind the subject for the situations where I can't bounce.
Is there any difference between this method and using a Stofen omnibounce to diffuse the light in direct flash mode? I'm just wondering whether to buy it.. if it provides better diffusion in direct mode than the panel, I'd consider it, if not, it's one less piece of gear to pay for and carry.
I'm aware this is not the intended use of the Omnibounce. In bounce mode, I'm very happy with the results from my bounce card with rubber band :)
PhotosByEric
Joined Jun 2005
Mar 03, 2006 23:58 |  #2
are you using a flash bracket or is the 430 on the camera? I have the omnibounce and 430 w/bracket. If you want a sample pic let me know how your set up.
Eric
www.photosbyeric.smugm​ug.com (external link)
Canon 30D, Canon 15-85, Tamron 17-50 2.8, Canon 60 2.8 macro, 580exI, 430exI, st-e2, and a wish list a mile long:lol:
DreamCrushers in POTN FF
ChopstickHero
Mar 04, 2006 00:30 |  #3
i have the stofen omnibounce. i think it works much better than the panel. but it cuts the flash alot so sometimes when there isn't anywhere to bounce the light, i use the panel.
Canon 40D and 350D :: Canon 70-200mm f/2.8L IS :: Canon 17-55mm f/2.8 IS :: Canon 10-22mm f/3.5-4.5 :: Canon BG-E2 & BG-E3 :: Canon 430EX Speedlite :: Crumpler 6MDH & The Whickey and Cox
mbze430
Mar 04, 2006 01:26 |  #4
you can be really cool, and wear a cap with a white reflector and turn the flash head 180 backward and bounce it off the cap reflector!
My Hub to my personal work (external link) (just click on the banners)
Lightstream
Yoda
Joined Feb 2006
Mar 05, 2006 00:33 |  #5
Thanks for the feedback :)
Eric, a sample would be great. I'm using the 430EX on the hot shoe, no brackets. I usually shoot horizontal (landscape orientation) to avoid the side shadow effect.
And someone gave me a white cap just yesterday :D
5,164 views & 0 likes for this thread, 4 members have posted to it.
2102 guests, 96 members online
