If you look at the battery door near where the rubber grip is, you will notice a little rubber door. What is that for? Is there a part number for that as well? I never realized it was a little piece of rubber until last night.
Frodge Goldmember More info Post edited over 8 years ago by Frodge. | Sep 04, 2015 06:25 | #1 If you look at the battery door near where the rubber grip is, you will notice a little rubber door. What is that for? Is there a part number for that as well? I never realized it was a little piece of rubber until last night. _______________
JohnfromPA Cream of the Crop 11,258 posts Likes: 1527 Joined May 2003 Location: Southeast Pennsylvania More info Post edited over 8 years ago by John from PA. | Sep 06, 2015 07:02 | #2 My guess is it is the grip alignment pin and the rubber insert is removed prior to attaching the grip. Item #4 on the attached image. Image hosted by forum (746386) © John from PA [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff.
mainbyte Senior Member More info Post edited over 8 years ago by mainbyte. | Sep 06, 2015 07:36 | #3 You may be talking about the little rubber door that is used for the wire on an AC adapter? Ron Canon 6D | Canon 7DII | 17-40 f/4L | 24-105 f/4L | 70-300 4/5.6L |100mm f/2.8L macro | 50mm 1.4 | 580exII | 2 - 430exII |
Sep 06, 2015 08:06 | #4 That's what I was talking about mainbyte. Thanks a lot. What is the purpose of that adapter? _______________
It is just an AC adapter and replaces the battery. One use would be in a studio setting where you can plug this adapter in and run the camera all day without having to change batteries. Of course you would need 110 voltage ( or 220, depending on country of use) to use this adapter. Canon 6D | Canon 7DII | 17-40 f/4L | 24-105 f/4L | 70-300 4/5.6L |100mm f/2.8L macro | 50mm 1.4 | 580exII | 2 - 430exII |
Sep 06, 2015 09:24 | #6 Thanks for your help! Much appreciated! _______________
JohnfromPA Cream of the Crop 11,258 posts Likes: 1527 Joined May 2003 Location: Southeast Pennsylvania More info | Canon wants $85 for the Canon ACK-E8 adapter but a generic version is available for much less.
Sep 06, 2015 13:58 | #8 Thanks a lot John. _______________
| Latest registered member is semonsters 1294 guests, 135 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
