Thread started 28 Jul 2003 (Monday) 13:26
error connecting camera to computer
sista
1 post
Joined Jul 2003
Jul 28, 2003 13:26 |  #1
Hi I just bought this canon ixus 400 digital camera a few days ago. I wanted to connect the camera to my laptop but how come i got this error 'no camera found' and 'camera error. check the lens cover and the cable connections then reconnect.'
i am using windows xp for my laptop.
I've installed the softwares before connecting the cam to my laptop. my laptop could detect this camera but it didn't show up in the control panel on scanners and camera section.
Do I need to install anything else in order to connect the camera to my laptop?
o ya i've tried to install this wia600.exe that i've downloaded from the canon website but still it doesn't work.
can anyone please help.....
thanks a lot.
blixa
Joined Sep 2003
Sep 05, 2003 17:28 |  #2
i have a similar problem. I have winXP and i can't get my ixus400 to work. when i try to view the images through ZoomBrowseEX (or photoshop, or any other software) i get "no camera detected" alert... although the camera is connected and running :(
anybody knows a solution?
pHanisch
Joined Sep 2003
Sep 06, 2003 09:02 |  #3
I have the same problem, Windows XP, No camera detected using Zoombrowzer 4.02 and having downloaded wia390 driver.
Any answers?
blixa
Joined Sep 2003
Sep 06, 2003 10:17 |  #4
just wanted to say that i solved my problem.. i tried to plug the usb cable into another usb prot and - strangely as it may sound - it worked! my camera gets detected and everything is working fine :)
blixa
Joined Sep 2003
Sep 06, 2003 11:56 |  #5
ok, here are some updates:
apparently the ixsus 400 didn't like my scaner (mustek 1200 ub). that's why the camera worked when it got plugged into another usb port - i unplugged the scanner from it :|
oh, well... when i'll download pictures from the camera i won't be using the scanner and everybody will live happily ever after ;)
adam1093
Dec 17, 2006 11:34 |  #6
same prob here with my 400d
was working ok now isnt
no camera detected
anyone have any ideas?
Canon 400d + Kit Lense + Sigma 10-20mm
Jon
Joined Jun 2004
Dec 17, 2006 12:05 |  #7
Added any new USB devices?
Jon
Cocker Spaniels
ssd
Dec 19, 2006 01:38 |  #8
If you disconnect the cable from computer without disconnecting from the camera body and reconnect, the camera will not be detected. Make sure to disconnect the cable from both ends, reconnect first to camera and then to computer. Now look through "My Computer" icon.
EOS 500 D
lolita877
1 post
Mar 19, 2007 19:31 |  #9
ssd wrote in post #2419014 (external link)
i can't connect my canon 400D to my computer either. in fact all it does is come up with the new hardware detected wizard and asks me to install the cd, when i do it cant find it and says invalid data.
when i open utility manager it doesnt detect a camera
please help, im fed up with trying to figure it out myself for the past 2 days
fiuman
Mar 20, 2007 04:58 |  #10
I had a similar problem with my A550, after installing a scanner. I uninstalled a scanner, then reinstalled camera, now it works perfectly.
Kell ­ s
1 post
Sep 03, 2007 08:25 |  #11
lolita877 wrote in post #2897850 (external link)
Hi,
I Have the exact same problem with connecting my 400D. I was just wondering whether or not you had overcome this problem yet? If so I'd really appreciate some guidance.
Kell s
ssd
Sep 04, 2007 02:18 |  #12
First install the camera software(s) that came with the camera without connecting the camera to computer. Now,
1) If the software prompts to connect camera, connect it. Do not forget to connect the cable first to the camera.
2) If the software does not prompt, then finish installation. Restart. Keep the cd in place. Connect the camera to computer as mentioned in the previous point.
Wait..... Computer automatically does the rest.
EOS 500 D
Micky ­ Daeus
Sep 04, 2007 04:53 |  #13
At work the A550 didn't get picked up by Zoombrowser 4 & gave a "camera not connected" warning. I updated to the newer version from usa.canon.com and everything went okay from then.
13,999 views & 0 likes for this thread, 10 members have posted to it.
1869 guests, 110 members online
