Thread started 06 Sep 2015 (Sunday) 08:23
What focus point and mode when shooting portraits wide open
gqllc007
Joined Jan 2015
Sep 06, 2015 08:23 |  #1
Ok so I have always used single spot focus point on the eyes in one shot mode when hand holding the camera.
When using 85L at 1.2-2.0 or 135L at 2.0 we all know dof is extremely shallow.
So is it better to shoot in AI Servo and single focus point instead of One shot and single spot focus? Models have a tendency to move a little and not uncommon when shooting hand held for the camera to move slightly too.
gqllc007
Joined Jan 2015
Sep 06, 2015 08:36 |  #2
Ok I just tested this at 1/500 f/1.2 using AI servo and single and spot focus points with the 85 1.2L II. And my result showed that the eye was in sharp focus exactly 50% of the time regardless. Which wasnt better than one shot and single spot focus. The AF is slow on the 85 1.2 so response time in AI servo is slow. I will try this with the 135
gqllc007
Joined Jan 2015
Sep 06, 2015 08:46 as a reply to  @ gqllc007's post |  #3
Ok I just tried this with the 135L 2.0
In AI servo with single focus point not spot 95% of the time the eye was in sharp focus
In AI servo with spot single focus point the focus was only 50% sharp focus on eye
I would think the faster focusing response of the 135L accounted for this high rate of success compared to the 85L. So for me I will shoot 85L in one shot-single point and the 135 in AI servo and single point focus. I am surprised the spot single focus point didnt fare better with accurate focus on the eye
sandpiper
Sep 06, 2015 09:58 |  #4
gqllc007 wrote in post #17696822 (external link)
You seem to be thinking that the spot AF is there for better accuracy, it isn't. The spot AF is less accurate than the regular AF point, as it has less to work with and may have trouble finding a good line of contrast to lock on to. It isn't there to be a more accurate focus point, it is for when you are trying to shoot through tight gaps in something closer which may be focused on instead with the larger AF point (such as twigs near a bird in a tree, or a chain link fence between you and your subject). For portrait use, where no such obstructions are present, you should be using a regular AF point and aligning it with a good line of contrast for the best results. That is what your test showed.
gqllc007
Joined Jan 2015
Sep 06, 2015 11:46 as a reply to  @ sandpiper's post |  #5
That clarifies what focus point to use but not what mode to use AI servo or One shot?
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 8 years ago by TeamSpeed.
Sep 06, 2015 21:50 |  #6
I use spot AF for portraits, I use it to lock onto the eyes. It is more accurate if your subject has a good point of contrast. I use ai servo just in case I or the subjects move. Otherwise one shot if dof covers the entire body of the subject. Spot AF is good for picking out that one person in a group shot as well, that will get the entire group into focus while trying to blur the background, without thanking the aperture too small.
maverick75
Joined May 2012
Sep 06, 2015 21:55 |  #7
I use one shot and I've never had the issue of a model moving.
agedbriar
Sep 07, 2015 13:29 |  #8
maverick75 wrote in post #17697556 (external link)
Time for younger models? ;-)a
Wilt
Post edited over 8 years ago by Wilt.
Sep 08, 2015 08:48 |  #9
agedbriar wrote in post #17698325 (external link)
Like toddlers
Or pet photography
dnauer
Gallery: 11 photos
Sep 10, 2015 22:49 |  #10
TeamSpeed wrote in post #17697551 (external link)
Do you guys use BBF or let the shutter meter/focus when you use spot AF? Been playing with a mix -- have been using BBF for years, but have started doing some portraits and am finding slight focus issues with BBF and one shot, not so with BBF and AI Servo -- so considering changes in my technique, but have been using center point focus for all of this --
itsallart
Gallery: 1095 photos
Joined Jan 2015
Post edited over 8 years ago by itsallart. (2 edits in all)
Sep 10, 2015 23:17 as a reply to  @ dnauer's post |  #11
But it also depends on your camera. My 6d is good with the center point but my 5d3 is way better if I select another "hot spot" out of the gamut :)
Renata
Seeing lights and shadows is an art :)
My Vinyl Source (external link)Tanami Muse (external link)
Face Masks on Etsy (external link)
JeffreyG
Gallery: 42 photos
Sep 11, 2015 06:32 |  #12
In my experience, one shot focus is more accurate and works in lower light than servo focus.
Some people suggest that servo will be good if the photographer or the model moves just a little, but in my understanding, Canon's servo focus is designed for and expects much more significant movement that a tiny 1cm sway by your model. In my experience servo doesn't do any kind of magic in tracking such a possible tiny sway. As far as the camera is concerned, a model 4 meters away that is swaying back and forth 1cm is going to be seen as stationary by the camera. It will probably not update the focus distance and move the lens.
Best bet on a stationary model is to focus with one shot, and snap the shutter immediately after attaining focus, before you or the model can move.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Sep 11, 2015 10:26 |  #13
JeffreyG wrote in post #17703232 (external link)
The only thing with this is that when I do portraiture, there are 2 moving subjects, myself and the person/persons being shot. And if there are kids, that introduces a whole new level of complexity, as they are just little bundles of raw energy, and sitting still isn't in their vocabulary. :)
Now with purely a studio set up with tripod and very controllable subjects, I would definitely use One Shot.
agedbriar
Post edited over 8 years ago by agedbriar.
Sep 11, 2015 18:31 |  #14
Not only do I need AI Servo for kids portraits, I even have Case 3 selected, for high tracking speed. Case 1 often wasn't fast enough on my 5D3.
Besides kids moving even when they mean to "pose", it's also me, struggling to capture the moment.
I tested AI Servo on static subject with the quite sensitive Moire pattern and Siemens star methods and in decent light the difference in favor of One Shot AF was barely perceptible, practically lost wthin the normal AF variability.
5,431 views & 1 like for this thread, 9 members have posted to it and it is followed by 4 members.
1507 guests, 133 members online
