Which is better?
texshooter Senior Member 652 posts Likes: 26 Joined Jun 2009 More info | Sep 09, 2015 14:24 | #1 Which is better?
Sep 09, 2015 15:00 | #2 The 400mm f5.6 was left off Canon's list of recommended lenses for the 5Ds. Perhaps this means the 7DII combo is better?
Sep 09, 2015 15:01 | #3 IQ should be about same, but if you shoot any action or birds in flight, the 7DII shoots much faster. Thorsten
Sep 09, 2015 15:03 | #4 texshooter wrote in post #17701142 The 400mm f5.6 was left off Canon's list of recommended lenses for the 5Ds. Perhaps this means the 7DII combo is better? It probably just means that Canon would like you to buy more expensive lenses / those with a higher profit margin. Thorsten
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Sep 09, 2015 18:08 | #5 Personally I wouldn't bother with using the crop mode, unless you are really tight for space on your CF card, and it makes no difference to file size in RAW anyway. You still get the advantage of the pixel density, but you get 2.56× the area to frame in. handy for those times when you might otherwise miss a bit of a fast moving subject off the edge of the frame as you pan. You can still crop down in post for better framing anyway. Not only that but using a 400mm prime on the 5DS will actually give you the framing options of a 250-400mm zoom on a 1.6 cropper.
Sep 09, 2015 19:27 | #6 BigAl007 wrote in post #17701364 Personally I wouldn't bother with using the crop mode, unless you are really tight for space on your CF card, and it makes no difference to file size in RAW anyway. You still get the advantage of the pixel density, but you get 2.56× the area to frame in. handy for those times when you might otherwise miss a bit of a fast moving subject off the edge of the frame as you pan. You can still crop down in post for better framing anyway. Not only that but using a 400mm prime on the 5DS will actually give you the framing options of a 250-400mm zoom on a 1.6 cropper. Alan
JeffreyG "my bits and pieces are all hard" More info Post edited over 8 years ago by JeffreyG. (2 edits in all) | Sep 09, 2015 19:39 | #7 texshooter wrote in post #17701472 But if I crop in post (5Ds full frame mode), I won't get as much background blur as if I crop in camera (5Ds 1.6 crop mode). Yes? No. When and where you discard the edge of the frame makes no difference on the blur. The degree of blur and the DOF are function of the lens focal length, the aperture, and the enlargement from image to print. The enlargement is a factor of the cropped image file size (and by size, I mean the physical dimenstions of the part of the sensor that captured the image.....24x36mm for the full, un-cropped sensor in the 5D for example). My personal stuff:http://www.flickr.com/photos/jngirbach/sets/
DavidArbogast Cream of the Crop More info | Sep 09, 2015 20:06 | #8 The resulting image quality would be about the same. The shooting experience favors the 7D II (faster shooting). But, as a great all-in-one solution the 5DS is terrific (handy for wildlife and a 400mm, while great for wider-angle lens for other types of photography. David | Flickr
Sep 09, 2015 22:20 | #9 JeffreyG wrote in post #17701486 No. The degree of blur and the DOF are function of the lens focal length, ). This why I would expect the 5ds 1.6 crop mode to give more background blur because it increases the effective focal length by a factor of 1.60.
Thorsten Member More info Post edited over 8 years ago by Thorsten. | Sep 09, 2015 22:31 | #10 texshooter wrote in post #17701672 This why I would expect the 5ds 1.6 crop mode to give more background blur because it increases the effective focal length by a factor of 1.60. It actually does not. The focal length stays the same, no matter what crop mode you use or not. What you get with a crop is the field of view of a longer lens (a smaller portion of your subject will fill the frame). But this effect has no impact on the DOF (background blur). For the DOF calculation, the actual focal length is used, so just 400mm. Thorsten
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Sep 09, 2015 22:38 | #11 texshooter wrote in post #17701672 This why I would expect the 5ds 1.6 crop mode to give more background blur because it increases the effective focal length by a factor of 1.60. But shooting with a 24x36mm frame and cropping in camera via the crop mode to 14.9x22.3 mm image area results in the identical image presented by the same 400mm lens to the APS-C body! You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
I think we are all wrong. See below. Cropping in camera actually reduces background blur. Image hosted by forum (747146) © texshooter [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff.
Thorsten Member More info Post edited over 8 years ago by Thorsten. (3 edits in all) | Sep 09, 2015 22:51 | #13 Read Jeffrey's post again, he has put it best: The degree of blur and the DOF are function of the lens focal length, the aperture, and the enlargement from image to print. Note that DOF depends on the enlargement! If you crop an image, you will get less DOF, due to the fact that you would be enlarging the image more (compared to printing the uncropped image to the same print size). So you will get more background blur by cropping, but this is not due to the focal length, and it is exactly the same no matter if you crop in camera or in post. Also, this change in DOF is much smaller compared to a real focal length change (i.e. swapping out the 400mm lens for a 600mm lens). Thorsten
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 8 years ago by Wilt. (2 edits in all) | Sep 09, 2015 23:00 | #14 texshooter wrote in post #17701687 I think we are all wrong. See below. Cropping in camera actually reduces background blur. That graph fails to take into consideration the cropping (in camera by the 5DS) of the image from 24x36mm to 14.9x22.3mm, it assumes use of the FULL frame area! You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Thorsten Member More info Post edited over 8 years ago by Thorsten. (2 edits in all) | Sep 09, 2015 23:08 | #15 texshooter wrote in post #17701687 I think we are all wrong. See below. Cropping in camera actually reduces background blur. The numbers in this chart are correct, but you may have interpreted it wrong. The "blur disk diameter", sometimes also called circle of confusion (CoC) is a measure what diameter the human eye will still see as a point, when looking at a given print form a certain viewing distance. Point of light sources that are in front or behind the focal plane are rendered as a circle by the optical system. So what we regard as DOF is not actually all perfectly in focus. It's just that the blur is so small that the eye cannot see it, so it still "looks" in focus. If you enlarge an image more (i.e. by starting from a crop), you are also enlarging those circles. That means a smaller original circle will be required for the eye to still see it as a point. Smaller circle = less DOF. So what this chart shows is that with 1.6x crop, you get a smaller CoC and therefore less DOF (more background blur). Thorsten
| Latest registered member is semonsters 1032 guests, 109 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
