Thread started 12 Sep 2015 (Saturday) 12:49
what canon lens to buy
tjs42
Joined Nov 2012
Sep 12, 2015 12:49 |  #1
ive been using a canon 70d with a sigma 17-50 2.8 ex hsm and a sigma 30mm 1.4dc hsm. i take most of my pics at low light kickboxing events that my sons club competes in. no flash allowed so some pics are terrible. dont want to raise the iso too much as that is just as bad. looking at paying £3-400 for a good second hand canon lens (or similar) that is good at very low light. not a fixed one as im at different distances at these events. any help much appreciated. sorry if this is in the wrong section
GeoKras1989
Joined Jun 2014
Sep 12, 2015 12:54 |  #2
The 60D is very usable at ISO 6400. The 70D must be at least as good as the 60D. Perhaps your exposure and post-processing skill could use a boost. That is a lot less expensive than new hardware.
WARNING: I often dispense advice in fields I know little about!
tjs42
Joined Nov 2012
Sep 12, 2015 13:00 as a reply to  @ GeoKras1989's post |  #3
my pp is almost non existant. i use lightroom a bare minimum. took pics at one event at 6400 very noisy and couldnt really get rid of it in lr.
Phoenixkh
a mere speck
Gallery: 67 photos
Joined May 2011
Sep 12, 2015 13:17 |  #4
tjs42 wrote in post #17704733 (external link)
You might already be doing this but just in case.... do your noise reduction before you sharpen. It makes a world of difference.
Kim (the male variety) Canon 1DX2 | 1D IV | 16-35 f/4 IS | 24-105 f/4 IS | 100L IS macro | 70-200mm f/2.8L IS II | 100-400Lii | 50 f/1.8 STM | Canon 1.4X III
RRS tripod and monopod | 580EXII | Cinch 1 & Loop 3 Special Edition | Editing Encouraged
enrigonz
Sep 12, 2015 13:23 |  #5
I hope you're shooting RAW... Your current setup should produce very good images at 6400 iso but I wouldn't dream of shooting jpeg on any event.
Canon Stuff :) |Flickr (external link) | Facebook (external link)
tjs42
Joined Nov 2012
Sep 12, 2015 13:38 |  #6
i shoot in raw. use manual mode. shutter 500 and depending on lighting 4-800 iso.any higher and the noise creeps in. will try and find a 6400 shot to show you. have used a slower shutter speed but didnt like the blur i was getting
tjs42
Joined Nov 2012
Sep 12, 2015 13:48 |  #7
Phoenixkh wrote in post #17704748 (external link)
ill try that as i was doing it the other way round
tjs42
Joined Nov 2012
Sep 12, 2015 13:52 |  #8
longbeachgary wrote in post #17704779 (external link)
To me if you're shooting in bright sunlight at low ISO you can expect that there will be no noise but when you're in a very low light situation and there is no other way to capture the image except to use a higher ISO, then how can you complain? Your only other choice is to not shoot at all.
thats why i was asking if a better lens to what i have would make a difference to low light shooting. i wasn't complaining i was asking a question
GeoKras1989
Joined Jun 2014
Sep 12, 2015 13:57 |  #9
60D at ISO 6400. Natural light. Processed exclusively in Lightroom. Shot raw, ETTR, +2/3 EC. Total processing time < 1 minute. This is not a crop, it is the full frame as shot. I can't find any noise in it on a 22" monitor.
I'd prefer to stay at ISO 3200 or below with the 60D. If you can tolerate this loss of detail, 6400 is very usable.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/09/2/LQ_747550.jpg
Image hosted by forum (747550) © GeoKras1989 [SHARE LINK]
GeoKras1989
Joined Jun 2014
Post edited over 8 years ago by GeoKras1989. (3 edits in all)
Sep 12, 2015 14:06 |  #10
Completely and utterly not true.
tjs42 wrote in post #17704780 (external link)
It does not matter in which order you do this. What matters is that you look at the results of one, then go back to the other to refine your results. The effects of LR adjustments are the same no matter which order you do them in, or how many times you go back and forth. The key to noise reduction in LR is to keep both NR and sharpening to a minimum, while applying as much of each as you can get away with.
Noise reduction kills detail. Don't overdo it.
Sharpening enhances noise. Don't overdo it.
My method goes back and forth between sharpening and noise reduction several times looking for that happy medium. If order mattered, my work would be a mess. I do NR, then sharpening, back to NR, then more sharpening, until I get the best results. If you are adjusting one parameter first, then doing the other without looking at the results, you are not getting the best results available. Lightroom is fantastic at noise reduction, if it is used properly.
EDIT:
I can't find them, so I assume I deleted them. But I did some pretty intense noise testing over the summer. Somewhere in POTN, I posted some shots from the 60D at ISO 12,800 (EDIT: 6400, sorry) and from the 6D at ISO 102,400. Both had extremes of highlights and shadow. Neither displayed any visible noise, even in the shadows. Admittedly, those shots were staged, on a tripod, and processed heavily. The processing was a bit time-consuming, but I proved to myself that ISO settings are mostly irrelevant to your results. Shoot the ISO that gets the job done.
EDIT w/correction. The 60D shots are at ISO 6400, not 12,800. My point stands. Here is the link:
https://photography-on-the.net …showthread.php?​p=17566142
tjs42
Joined Nov 2012
Sep 12, 2015 14:22 |  #11
GeoKras1989 wrote in post #17704793 (external link)
EDIT:
I can't find them, so I assume I deleted them. But I did some pretty intense noise testing over the summer. Somewhere in POTN, I posted some shots from the 60D at ISO 12,800 and from the 6D at ISO 102,400. Both had extremes of highlights and shadow. Neither displayed any visible noise, even in the shadows. Admittedly, those shots were staged, on a tripod, and processed heavily. The processing was a bit time-consuming, but I proved to myself that ISO settings are mostly irrelevant to your results. Shoot the ISO that gets the job done.
thanks for the advice. i have some pics still to do in lr so will try it out
GeoKras1989
Joined Jun 2014
Sep 12, 2015 14:25 as a reply to  @ tjs42's post |  #12
Good luck with those. It really is not difficult once you've done it a few times. It really helps to ETTR when working at these levels. My default at ISO 6400 is +2/3 EC, and keep an eye on the blown highlights. If they matter, back off.
Larry ­ Johnson
Joined Sep 2011
Sep 12, 2015 14:35 |  #13
Canon 70-200 f/2.8
Ain't Nature Grand!
Shooting 7D2 with Canon 400mm, f/5.6.
60D, canon 18-135 EFS, and 1.4 extender in the bag.
davesrose
Title Fairy still hasn't visited me!
Sep 12, 2015 14:48 |  #14
I think it's difficult to recommend one lens, since I have no idea what focal length you're looking for. If you insist on zoom, then get the widest aperture/ image stabilization preferred. Assuming for kickboxing you're not that far away. I used to have a Tamron 28-75mm lens that's a pretty good budget 2.8. The newer Tamron 24-70mm is more versatile since it is 2.8 and has VC (image stabilization). I now have the Canon L lens, which I find has better contrast...the Tamron lenses are nice and sharp and are a great value.
Canon 5D mk IV
EF 135mm 2.0L, EF 70-200mm 2.8L IS II, EF 24-70 2.8L II, EF 50mm 1.4, EF 100mm 2.8L Macro, EF 16-35mm 4L IS, Sigma 150-600mm C, 580EX, 600EX-RT, MeFoto Globetrotter tripod, grips, Black Rapid RS-7, CAMS plate and strap system, Lowepro Flipside 500 AW, and a few other things...
smugmug (external link)
maverick75
Joined May 2012
Post edited over 8 years ago by maverick75.
Sep 12, 2015 14:50 |  #15
Canon EF 85mm 1.8, super quick and accurate focusing faster speedside than zooms. I shoot live music stuff in horribly lit venues so I know all about needing fast shutter speeds and high ISO and still forced to shoot wide open.
3,033 views & 0 likes for this thread, 10 members have posted to it and it is followed by 3 members.
1030 guests, 179 members online
