Thread started 15 Sep 2015 (Tuesday) 17:25
Godox AD360 light & PB 960 Battery Issues
ShotByTom
Gallery: 23 photos
Sep 15, 2015 17:25 |  #1
I have the above equipment that I purchased last August. I haven't used it much, but I charged it all night last night and it showed a full charge this morning. After using it for about 20 shots at 1/128h power the battery began shutting off. The only way to get it to work again was to remove the battery, then put it back on. After doing that the light would work for a couple of shots then it would shut off again and I would have to remove the battery to get it to work again. The battery showed 3/4 power at that point, but it kept shutting off every couple of shots.
Has anyone experienced this before? I remember there was an issue with the batteries, but I don't remember if this was the problem..
Gear
Website (external link)
mmmfotografie
hanging up-side-down in a cave
Joined Jul 2013
Sep 16, 2015 03:34 |  #2
Yes this a very well known problem and discussed into the smallest technical details in this forum.
A resumé can be found here: http://flashhavoc.com/​godox-battery-issues/ (external link)
ShotByTom
Gallery: 23 photos
Sep 16, 2015 08:28 as a reply to  @ mmmfotografie's post |  #3
Ok, thanks for the info. I bought the light, and a Godox v860, from Dzone2 on Ebay, I'll contact them.
Gear
VeneziaPhoto
Joined Mar 2018
Mar 17, 2018 04:09 |  #4
I'm a photographer in Cheshire, UK. See www.VeneziaPhoto.co.uk (external link), I'm a big fan of Godox, but when I came to use my AD360 a week or so ago, I noticed the Battery Pack was bulging! Wouldn't charge and wouldn't fire the flash. So took it to bits to see the issue, then researched a fix, all you need are:
Screwdriver
Wirecutters
Couple of bits of cable
Soldering Iron/Solder/Flux - plus some soldering skills (that I clearly don't possess!)
2 or 3 Cable ties
3 x 3.7v 18650 Lithium Ion Batteries, mine were Ultrafire 5600 mAh with protection for over charging - will charge 1000 times according to the spec. So the original is rated at 3600 mAh, so more capacity too
Then 20-30 mins and hey, you're done!
So here's a video of how to do it, vimeo.com/258492295
Hope it helps some others out :)
Phil
mmmfotografie
Joined Jul 2013
Mar 17, 2018 10:32 as a reply to  @ VeneziaPhoto's post |  #5
I don't think that you will get a lot of flashes out of a charge.
Look at the space the 18650 needs and the original battery and keep in mind that the technology is the same. These batteries have normally a mAh of 2000 to 2400 so less then the original battery pack.
Choderboy
I like a long knob
Gallery: 185 photos
Mar 17, 2018 11:16 |  #6
VeneziaPhoto wrote in post #18587649 (external link)
Screwdriver
Wirecutters
2 or 3 Cable ties
Phil
FYI, the highest capacity 18650 available are 3500mAh: Panasonic (Sanyo) NCR18650GA.
There are many available with higher claimed capacity but it's just that, claim.
Dave
Image editing OK
VeneziaPhoto
Joined Mar 2018
Mar 24, 2018 01:40 as a reply to  @ Choderboy's post |  #7
Hi
Try here https://www.ebay.co.uk …049087:g:PgcAAO​Swo6lWMZ0K (external link)
This is what I used
5600mAh and you do get plenty of flashes
Also bear in mind these are £10 for 4 of which you need three as opposed to £45-55 for an original? Just trying to help here, if you've made the same modification and it doesn't work then fair enough but guessing you haven't?
Phil
Choderboy
I like a long knob
Gallery: 185 photos
Mar 24, 2018 02:03 |  #8
[QUOTE=VeneziaPhoto;18​592788]Hi
This is what I used
Phil[/QUOTE
I was just providing some facts. Pigs don't fly. 3500mAh 18650s are the highest capacities that are available to consumers.
Dave
Image editing OK
Choderboy
I like a long knob
Gallery: 185 photos
Mar 24, 2018 02:06 |  #9
OK. I was wrong. Panasonic have released a 3600mAh 18650. The 'G'
Dave
Image editing OK
Choderboy
I like a long knob
Gallery: 185 photos
Post edited over 5 years ago by Choderboy. (2 edits in all)
Mar 24, 2018 03:27 |  #10
For anyone interested my claims are very easy to verify:. The more you Google the more obvious it becomes.
It's a serious issue. Google "vent with flame" and you will see the consequences of being ignorant.
This first link puts it simply, even though it is from 2016:
https://xaeus.wordpres​s.com …tify-18650-cell-capacity/ (external link)
How to identify 18650 cell capacity by color / code and how to tell fakes from real – [En]
Posted on 2016.09.08
There are 4 very big companies that produce (used to be) very good quality cells: Samsung, Sanyo, Sony and
LG. And there’s also the 99.998% fakes called Ultrafire.
Practically, all Ultrafire cells on the online
market that state any capacity over 3000mAh are fakes.
https://reactual.com …best-18650-batteries.html (external link)
The Best 18650 Batteries Of 2018
by Patrick Hyde January 11, 2018
https://electronics.st​ackexchange.com …ty-ranges-of-lithium-ion- (external link)
18650-batteries
What is the valid capacity ranges of Lithium Ion 18650 batteries?
I'm seeing wildly varying capacities that are seemingly fake on 18650 cells, such as these "9,800 mAh" ones on eBay, but are ~$1 / cell.
However, 'genuine' cells from Panasonic and similar name brands seem to top out around 3,500 mAh or so, but cost more like $8 / cell.
How can I tell true capacity apart from the lies?
https://www.ozbargain.​com.au/node/324863 (external link)
What Are The Largest Capacity 18650 Batteries I Can Get?
Dave
Image editing OK
5,053 views & 0 likes for this thread, 4 members have posted to it and it is followed by 4 members.
1707 guests, 141 members online
