lecherro wrote in post #17718994
Heres a funny one for you... I shoot with a Sony NXCAM. When i use a freshly formatted card my AVCHD file folder is labeled with all caps... My mac cannot translate that into be the folder it is... IF i Un Caps the whole folder file name... wahlah there it is. then i have to do the same to the bdnn folder in that..... Crazy computers.
In the MacOS, certain folder names are protected. AVCHD is one of them. You'll see that if you rename any folder.
Like lecherro said, you can rename AVCHD or BMDV to anything else, and they'll show up as normal folders and files.
OTOH, if you're recording long takes that create multiple 4GB files, it's important to import the whole card into your NLE. If you don't, the NLE doesn't correctly reassemble the take, there will be a few frames missing.
Re the choice of AVCHD over MP4, test them both to figure out what your NLE likes best. I did this and found out that Premiere likes the AVCHD of the Canon XA20 much better, with no need for it to create preview files like it did for MP4. At some cost of weird file management with that AVCHD folder structure...
The idea is to AVOID the need to use a converter!
I'm just remembering that Premiere CC has been through two upgrades since I tested, I should do it again!
From the upper left corner of the U.S.
Photos, Video & Pano r us.
College and workshop instructor in video and audio.
70D, Sigma 8mm, Tokina f2.8 11-16, Canon EF-S f2.8 17-55, Sigma f2.8 50-150 EX OS, Tamron 150-600VC. Gigapan Epic Pro, Nodal Ninja 5 & R10.
