Before I spend much time on the technique...how might I improve on it?
Candle was placed image left with mirror on the right
Balancing the candle flicker was the result of a four second SS at ISO 100 and f/8 and stacking.
Sep 16, 2015 19:50 | #1 Before I spend much time on the technique...how might I improve on it? The things you do for yourself die with you, the things you do for others live forever.
MartinDixon Slit-scan project master More info | Sep 17, 2015 04:40 | #2 Not doing much for me. flickr
joedlh Cream of the Crop 5,513 posts Gallery: 52 photos Likes: 684 Joined Dec 2007 Location: Long Island, NY, N. America, Sol III, Orion Spur, Milky Way, Local Group, Virgo Cluster, Laniakea. More info | Sep 17, 2015 07:46 | #3 Looks pretty cool to me. I do agree that the stand is a distraction. The subject could use a little more space on the bottom. A different support surface it might help. Like maybe a fluff of satin or some such. There's a white fold in the backdrop that sort of draws the eye. Joe
freestylee30 Senior Member More info | Sep 17, 2015 11:16 | #4 I like it and think the light is interesting as is. I kind of wonder what it would look like with the whole image being brightened just a little bit and then some selective burning on those interesting mirrored holes. Brandon | zenfolio
Sep 17, 2015 12:19 | #5 I don't understand the requirement of having to use a candle to light this when the candle/flame is no part of the image. Why not use something easier to light with... window light, etc. The stand, as mentioned, does not fit the subject matter. You would be better off using maybe some sand, or a beach towel (if not too distracting) to better fit the theme. The background, even though blurred, does not fit the theme/feel either. 5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
Sep 17, 2015 18:41 | #6 It's the candle that provides the light and it's the light that interests me. The things you do for yourself die with you, the things you do for others live forever.
Then why not include the candle/flame in the shot. What I am getting at is there are much easier ways to get orange/warm light that will get you brighter light that will allow for lower ISO and/or faster shutter to get better quality and make the shoot easier to get.... unless you want to show the candle/flame in the shot. 5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
Sep 18, 2015 04:17 | #8 there are much easier ways to get orange/warm light how The things you do for yourself die with you, the things you do for others live forever.
joedlh Cream of the Crop 5,513 posts Gallery: 52 photos Likes: 684 Joined Dec 2007 Location: Long Island, NY, N. America, Sol III, Orion Spur, Milky Way, Local Group, Virgo Cluster, Laniakea. More info | The subject isn't moving. Shutter speed is irrelevant. So I don't see a problem with using a candle. I also disagree with the suggestion that the candle be in the shot. Do we put softboxes in portrait shots? Joe
Sep 18, 2015 08:19 | #10 The OP was about "Before I spend too much time on the technique... how might I improve on it". So I am assuming they want to improve on the technique... which means they are open to suggestions on how to best emulate the light/look of the image. I also see that it is mentioned they used a candle with a 4 second shutter at f/8 and used stacking in order to get this shot. This means tripod (set up time), more than one shot (stacking) and then post processing work (stacking). Think about how much time this takes to get what? A warm light on a subject. It seems like a lot of work to just get warm light on the subject so I think maybe they like the idea of a candle being the light source but it's not obvious that that's what's being used here so maybe including it in the shot would help convey that (and this is the only reason I can think of that you would want to use candle light to light the subject) 5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
FarmerTed1971 fondling the 5D4 More info | Sep 18, 2015 08:25 | #11 Doesn't do much for me either. Cropping in on the three holes on the apex of the shell would make a more interesting comp. Getting better at this - Fuji X-t5 & X-t3 - 16 1.4 - 35/50/90 f2 - 50-140 - flickr
Sep 18, 2015 09:09 | #12 I should have been more clear...the subject is secondary in this case. The things you do for yourself die with you, the things you do for others live forever.
FarmerTed1971 fondling the 5D4 More info | Sep 18, 2015 09:17 | #13 Then I think you were successful. Getting better at this - Fuji X-t5 & X-t3 - 16 1.4 - 35/50/90 f2 - 50-140 - flickr
Snydremark my very own Lightrules moment More info | Sep 18, 2015 10:08 | #14 That second one is a bit more successful at what you've been describing. The shot in this post left the front of the seashell rather distractingly unlit and with a distinct lack of contrast with the background. Having the full black backdrop in that second shot worked quite well to solve that issue. - Eric S.: My Birds/Wildlife
LeftHandedBrisket Combating camera shame since 1977... More info Post edited over 8 years ago by Left Handed Brisket. | Sep 18, 2015 10:18 | #15 Snydremark wrote in post #17712153 The shot in this post left the front of the seashell rather distractingly unlit this is kind of what gets me with this shot. PSA: The above post may contain sarcasm, reply at your own risk | Not in gear database: Auto Sears 50mm 2.0 / 3x CL-360, Nikon SB-28, SunPak auto 322 D, Minolta 20
| Latest registered member is semonsters 907 guests, 119 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
