Thread started 19 Sep 2015 (Saturday) 22:15
Retouching issues: colour mismatch
Alveric
Gallery: 38 photos
Sep 19, 2015 22:15 |  #1
Hi all,
This is a portion of an image I need to finish. There was a sign on the fence that needed removing (she also wants the car removed, but that's not doable, at least not by me), so I cloned it out using the part of the fence closest to the right edge; unfortunately, the sunlight was stronger there and now you can see how the patch where the sign used to be is lighter.
IMAGE: http://www.diamantstudios.ca/Gemeines/bilder/Examples/Retouching_issue_01B.jpg
Is there a way to bring that area to the same hue as the area below? I've tried Burn and Hue/Saturation adjustment layers to no satisfactory effect. Thought someone here might have some suggestions.
TIA
Damo77
Sep 19, 2015 23:22 |  #2
Did you clone on a blank layer? I mean, do you have that area of new fence separate from the rest of the image, on its own layer?
Damien
Website (external link) | Facebook (external link)
Alveric
Gallery: 38 photos
Sep 19, 2015 23:28 |  #3
Own layer.
Damo77
Sep 19, 2015 23:41 |  #4
Ok, then I really would have thought that Hue/Saturation would work. Add the Hue/Sat adjustment layer, clip it to the cloned layer, then lower the Lightness slider and possibly raise the Saturation slider.
Damien
Alveric
Gallery: 38 photos
Sep 21, 2015 10:06 |  #5
Thanks for the tip regarding the saturation, I didn't initially try that. Seems to have done it. I still don't entirely like the final product, but I think it's passable. Man, do I hate retouching.
Thanks. :-)
nathancarter
Gallery: 32 photos
Sep 21, 2015 13:53 |  #6
Even though you've described the problem, I'm looking for it in your preview and not seeing anything objectionable.
Conclusion: You're over-thinking it, and nobody will notice except you.
chauncey
Sep 22, 2015 07:04 |  #7
The method that works for me is...using the "color sampler tool" pick a spot to mark the colors>overlay with the new layer>
use levels a levels adjustment layer set to one layer only, you will need to fiddle with each of the RGB numbers to make
that new layer match-up with the lower layer.
kirkt
Sep 22, 2015 07:37 |  #8
nathancarter wrote in post #17716113 (external link)
^^This.
Kirk
1,847 views & 0 likes for this thread, 5 members have posted to it.
1650 guests, 136 members online
