For low light gyms ... if I shoot in raw, does it matter if I set a custom white balance ?
Sep 23, 2015 08:45 | #1 For low light gyms ... if I shoot in raw, does it matter if I set a custom white balance ?
Qlayer2 OOOHHH! Pretty Moth! More info | Sep 23, 2015 08:52 | #2 If you are shooting in raw, you can always adjust in post. The question is- do you want to get it right in camera, and not have to worry about adjusting it later?
Thank you !
gonzogolf dumb remark memorialized More info | Sep 23, 2015 09:37 | #4 I would suggest doing a custom white balance. Ideally you can just adjust the WB from the raw in post but there are other issues at play here. Many gyms don't have full spectrum lights, meaning they are deficient in part of the color spectrum, often lacking in red. So getting as close as you can in camera will give you the best starting point for postprocessing.
Sep 23, 2015 10:16 | #5 Permanent banCustom WB is way too easy to do to pass on it. If I am not shooting in daylight, or with flash, I always shoot a CWB frame. It literally only takes 2 seconds. WARNING: I often dispense advice in fields I know little about!
Sep 23, 2015 10:35 | #6 Thanks guy's ... easy to do, I'll have to make it a habit.
gonzogolf dumb remark memorialized More info | Sep 23, 2015 10:48 | #7 lacogada wrote in post #17718815 Thanks guy's ... easy to do, I'll have to make it a habit. Any opinions on white vs grey card ? Grey card if you have one.
Voaky999 Goldmember More info | Sep 23, 2015 11:58 | #9 I use one of these things and it works really well Don
Sep 23, 2015 13:13 | #10 Permanent banlacogada wrote in post #17718815 Thanks guy's ... easy to do, I'll have to make it a habit. Any opinions on white vs grey card ? White vs grey does not matter for white balance. The grey cards are for setting exposure. I use a sheet of white (Brightness=96) computer paper. The stuff is cheap, disposable, and readily available. There is no sense spending money on a special made card. WARNING: I often dispense advice in fields I know little about!
LeftHandedBrisket Combating camera shame since 1977... More info | Sep 23, 2015 13:47 | #11 the only problem with white is that if you over expose it, and it clips, it will screw up your white balance. PSA: The above post may contain sarcasm, reply at your own risk | Not in gear database: Auto Sears 50mm 2.0 / 3x CL-360, Nikon SB-28, SunPak auto 322 D, Minolta 20
PhotosGuy Cream of the Crop, R.I.P. More info Post edited over 8 years ago by PhotosGuy. (2 edits in all) | Sep 23, 2015 14:07 | #12 Shoot white on the meter reading at less than 1/120 sec & it will be gray enough for a good WB. FrankC - 20D, RAW, Manual everything...
Sep 23, 2015 14:34 | #13 Permanent banLeft Handed Brisket wrote in post #17719063 the only problem with white is that if you over expose it, and it clips, it will screw up your white balance. Shooting a white subject will produce a grey photo at metered ZERO. That (underexposure) is normal meter behavior. Overexposure would have to be intentional. PhotosGuy wrote in post #17719088 Shoot white on the meter reading at less than 1/200 sec & it will be gray enough for a good WB. I don't think one leg of the triange has much bearing on the other two. A meter-centered shot of a while piece of paper used to set custom white balance has nothing to do with exposure. WARNING: I often dispense advice in fields I know little about!
Sep 23, 2015 14:54 | #14 GeoKras1989 wrote in post #17719127 WB and exposure are two entirely separate, and totally unrelated settings. WB accounts for the COLOR of the light. Exposure accounts for how much of it you gather. Shoot volleyball later today, will try the CWB.
Sep 23, 2015 15:18 | #15 Permanent banMake sure you do it in the light your SUBJECTS will be in. Some of our local schools have upgraded the floor/court lighting while leaving the crappy lighting in the stands/spectator area. If it is different, just walk to courtside and snap your CWB frame with your paper facing the light the players will be in. WARNING: I often dispense advice in fields I know little about!
| Latest registered member is semonsters 1032 guests, 107 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
