Thread started 24 Sep 2015 (Thursday) 10:32
what am i doing wrong..
Iamjhil
Joined Jun 2014
Sep 24, 2015 10:32 |  #1
I've started taking photos, i'm total amateur, but i love it when a photo turns out right.. but lately it gets really frustrating when the photos don't end up being sharp.. What am i doing wrong lol..
Picture A was at a work award banquet. It was crazy trying to get a decent shot in a dim ballroom I had a flash on it was 1/60 F4
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/09/4/LQ_749743.jpg
Image hosted by forum (749743) © Iamjhil [SHARE LINK]
This photo was middle afternoon and the sun was pretty harsh. But the photo is Not crisp at all.. 1/125 F 14
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/09/4/LQ_749744.jpg
Image hosted by forum (749744) © Iamjhil [SHARE LINK]
P4ulG
Sep 24, 2015 10:52 |  #2
No.1 is good. You may be able to give it a bit of a lift in levels. No.2 clearly your focus was on the banner in the BG. The lettering is completely in focus.
Canon 6D Canon 600D Canons 24-105mm L 85mm 1.4 IS L 70-300mm L. 100mm F2.8 macro L IS. 16-35mm L nifty fifty. 55-250mm IS. Speedlights Siggy DG530 super Canon EX430II Vivitar 3700
randizzle
Sep 24, 2015 11:48 |  #3
I won't comment much on the first shot, either.
The second shot, though, is a technical mess (sorry to be blunt but it's true). You shot in harsh sunlight at ISO 800 @ f14 and 1/125.
First of all, there was probably no reason to stop down at all, but especially not to f14. When shooting people, almost always shoot at f4; it's already a pretty small aperture. If you need more DOF, maybe as high as f5.6 but I almost never make it up that high.
Second, when shooting outdoors, especially in sunlight, set ISO at 100 and forget about it. There is more than plenty light for ISO 100.
Third, your shutter speed should be much faster. No reason to introduce the possibility of shaky hands or moving targets if you don't need to.
philodelphi
Gallery: 50 photos
Sep 24, 2015 11:55 |  #4
I have to differ with randizzle here... f/4 would be too wide, no way both the dogs and the banner would be in focus... not even at f/5.6. I think the issue with #2 is that it's underexposed, and possibly, you were not holding the camera steady, or maybe your lens's IS has a problem. I had that happen with a Tamron lens and this is what it looked like. The banner is sharp and the pit in front is sharp, but the people look a bit fuzzy.
Sony DSC-RX100M2 α7R III / ILCE-7RM3 Cyber-shot DSC-RX10 IV | Voigtlander 65mm F2 Macro APO-Lanthar | Venus Optics Laowa 15mm f/4 Macro | Sony FE 24-240mm F3.5-6.3 OSS Sonnar T* FE 55mm F1.8 ZA FE 24mm f/1.4 GM | Samyang 35mm f/1.4 ED AS UMC | Canon MP-E 65mm f/2.8 1-5x Macro Photo EF 100mm f/2.8 Macro USM | Sigma 100-400mm f/5-6.3 DG OS HSM | Tokina Firin 20mm f/2 FE MF | Tamron 28-75mm F2.8 Di III RXD
bob_r
Gallery: 24 photos
Sep 24, 2015 12:15 |  #5
randizzle wrote in post #17720235 (external link)
He needed more DOF than f/4 would provide. With that setting, he would have about 1 foot in front of his subject and 1 1/4 feet behind his subject in focus (I used 12 feet for this calculation since the shot looks like it was taken between 10 and 12 feet). This clearly is not enough DOF to get the dogs in focus and since the people are not all on the same plane, probably not enough to have all of them in focus either. If he had focused on the middle dog, he probably would have had all of them in focus at f/14 (3 feet in front and 6 feet behind the focal point). Also, 1/125s shutter speed at 67mm should be fast enough for most people to avoid camera shake.
I'm not sure if the OP had any options, but shooting in the sunlight during mid-day without flash is rarely going to give you acceptable results. Were no alternatives available?
Canon 7D, 5D, 35L, 50 f/1.4, 85 f/1.8, 135L, 200L, 10-22, 17-55, 70-300, 100-400L, 500D, 580EX(2).
Sigma 150 macro, 1.4X, 2X, Quantaray 2X, Kenko closeup tubes, Yongnuo YN685(3), Yongnuo YN-622C-TX. Lots of studio stuff.
** Image Editing OK **
randizzle
Sep 24, 2015 13:39 |  #6
People are defending f14, 1/125, and ISO 800 for a family shot in midday sun. I'll just go ahead and check out of this thread.
You can absolutely get acceptable results in midday sun with no flash, but not with those camera settings.
Ray ­ Marrero
Gallery: 23 photos
Sep 24, 2015 14:06 |  #7
The second one needs more light. I would be at ISO 100, maybe 200, no higher than that, especially when outside. Then I would start at f4.0 and 1/125 and take a test shot.
Depending on how it comes out I adjust the f-stop or shutter speed, very rarely the ISO. If I still don't like it, I will use fill flash.
Ray
Canon 6D, 7D, 30D, Flashpoint Zoom Li-on R2 x2, Flashpoint eVOLV 200 and XPlor 600, AB800 x3, Canon 10-22mm, 18-55mm, 50mm 1.8, 85mm 1.8, 24-70mm 2.8L, 24-105mm 4.0L, 70-200mm 2.8L IS, Sigma 28-105mm 2.8, Tamron 28-75mm 2.8, CyberSyncs.
Dermit
Joined Nov 2005
Post edited over 8 years ago by Dermit. (3 edits in all)
Sep 24, 2015 14:23 as a reply to  @ randizzle's post |  #8
What bob_r says here is true. Look up the numbers on any DOF calcultor. The only number we don't have here is the distance from camera to subject but 10-12 feet would probably be close. Given this info: Canon 5D Mark II | Canon 24-105 f/4L IS @67mm | 1/125 | f/14 | ISO 800 the DOF calculators for 12 feet away has a total DOF to be around 9 feet. If an aperture of 4.0 was used this drops the dof down to 2.3 feet which is too shallow. A 5.6 would get you to 3.35 feet, probably still a little too narrow. It looks to me more like the depth could have been closer to 6-7 feet and been fine which would mean the aperture could have been closer to f/10 - f/12 ish. This would have allowed for lower ISO and/or faster shutter.
Now even though I agree that 1/125 should be fine to hand hold a 67mm focal length steady the other factor is the movement of the subjects so faster would be better. This image is acceptably sharp for smaller prints and digital media. If it were to be printed large it would likely need to be a bit sharper. It's difficult to know why it's not tack sharp all the way through. Like mentioned the pit in front looks sharp as does the banner but people are a little soft. Are all the shots from this session exhibiting the same?
Other factors could come into play... is the lens clean? If there is a smudge on the lens or dried water drop stains this could come into play at f/14. Diffraction 'may' start to come in at f/14 as well, usually not, but maybe. The smaller aperture starts to diffract the light to where stray light could cause softness in areas as well.
5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
http://www.pixelcraftp​hoto.com (external link)
bob_r
Gallery: 24 photos
Sep 24, 2015 14:23 |  #9
randizzle wrote in post #17720360 (external link)
I would love to see your family portraits taken in the midday sun without using flash or reflectors. Please include your exif info so I can learn the secret.
bob_r
Gallery: 24 photos
Sep 24, 2015 14:35 |  #10
Ray Marrero wrote in post #17720390 (external link)
It would not be possible to get everyone and the dogs in focus at f/4 unless you changed the pose. There's simply not enough DOF available.
As for the ISO, I agree that he did not need ISO800. These were shot in the midday sun and according to the "Sunny f/16 rule", ISO100 should have worked fine for a shutter speed of 1/125s at f/14.
Dermit
Joined Nov 2005
Sep 24, 2015 14:41 |  #11
bob_r wrote in post #17720429 (external link)
I agree and thought about this... the ISO800 makes no sense to me here... Is the OP SURE about the settings... is this exif data or hand typed in info we got for the image?
randizzle
Post edited over 8 years ago by randizzle. (2 edits in all)
Sep 24, 2015 14:59 |  #12
bob_r wrote in post #17720412 (external link)
IMAGE: https://foilphotography.smugmug.com/photos/i-vZFQXX8/0/L/i-vZFQXX8-L.jpg
IMAGE LINK: https://foilphotograph​y.smugmug.com …/i-vZFQXX8-L.jpg&lb=1&s=A  (external link) on Smugmug
IMAGE: https://foilphotography.smugmug.com/photos/i-RhFTVW8/0/L/i-RhFTVW8-L.jpg
IMAGE LINK: https://foilphotograph​y.smugmug.com …/i-RhFTVW8-L.jpg&lb=1&s=A  (external link) on Smugmug
This one is literally at high noon with no cloud cover whatsoever:
IMAGE: https://scontent-ord1-1.xx.fbcdn.net/hphotos-xfa1/t31.0-8/s960x960/11896408_480302902129373_4767079119957982528_o.jpg
Here's a snapshot in a setting that looks almost identical. And by snapshot I mean I didn't even think about it, just had my camera with me and quickly took the one picture.
IMAGE: https://scontent-ord1-1.xx.fbcdn.net/hphotos-xtf1/v/t1.0-9/11693984_10204576857762938_3258704570378324051_n.jpg?oh=c9c7db9dcb55e9833aacc4dc06225eb4&oe=5660A351
Are any of these great? Absolutely not. Are they acceptable? I guess that's relative, but I haven't heard any complaints. Not a single one used any flash or any modifiers.
bob_r
Gallery: 24 photos
Post edited over 8 years ago by bob_r.
Sep 24, 2015 16:09 |  #13
randizzle wrote in post #17720458 (external link)
Personally, I'd rather add a flash or reflector if I absolutely have to shoot in midday sun than to accept the eyes squinting or in such deep shadow from their eye sockets.
BTW, the third shot is not a family portrait and the last one was not taken in the midday sun. The only way to avoid the deep eye shadows is to have your subjects turn their
heads up towards the sun (as you did in the third image) and when you're taking a family portrait, you'll have at least some of your subjects squint their eyes so much they'll look like they're closed (much like your subjects did in your first image). I'm sorry, but I think I'm still looking for the secret.
freestylee30
Gallery: 164 photos
Sep 24, 2015 16:13 |  #14
I don't think people are defending ALL the settings... primarily just the aperture. It really does look like focus was on the banner. I'm wondering if everything is in auto mode?
Brandon | zenfolio (external link)| ♥ feedback ♥
Eternal Blue Forever Green
Image Editing OK
CANON 5DIV 50 f/1.8 85 f/1.8 135 f/2L 70-200 f/2.8L IS II
ROKINON 14 f/2.8 | TAMRON 15-30 f/2.8 VC 24-70 f/2.8 VC | SIGMA 35 f/1.4 Art |
DreDaze
Gallery: 49 photos
Post edited over 8 years ago by DreDaze.
Sep 24, 2015 16:21 as a reply to  @ freestylee30's post |  #15
it was all done in manual...i don't think f14 was needed in that shot...could've probably gotten away with f8, it's not like the banner in the background has to be in perfect focus
also i'll address your first shot since nobody else is...don't shoot in ai-focus, it's terrible...use one shot if it's stationary, and ai-servo if it's moving, use ai-focus if you want headaches
Andre or Dre
gear list
Instagram (external link)
4,887 views & 4 likes for this thread, 13 members have posted to it and it is followed by 9 members.
1526 guests, 130 members online
