Thread started 28 Sep 2015 (Monday) 10:43
Turn off IS when bracing?
OhLook
Gallery: 105 photos
Joined Dec 2012
Sep 28, 2015 10:43 |  #1
I seldom bother with setting up a tripod. For instance, last night I steadied the camera against a window sash to shoot the eclipsed moon. Afterward, it occurred to me that bracing against a stable object approximates the effect of using a tripod, and turning off image stabilization might have given a clearer result.
Do you turn off IS when using a solid object instead of a tripod to hold the camera still?
PRONOUN ADVISORY: OhLook is a she. | Comments welcome
The new forum developed by POTN members is open to all:
https://focusonphotogr​aphy.community.forum/ (external link)
BigAl007
Gallery: 556 photos
Sep 28, 2015 11:01 |  #2
As you are still holding the camera, you will still be imparting some vibration in to the system, so I would have IS/OS/VC on in this situation. I would be using a remote release and mirror lock or LV (wish i had remembered that last night myself) shooting off a tripod before turning off the stabilisation.
Alan
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Sep 28, 2015 11:10 |  #3
https://www.youtube.co​m/watch?v=Mzcgyk62cHU (external link)
Dan Marchant
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Sep 28, 2015 11:27 |  #4
there are only 4 lenses that require turning off IS (see page 2) (external link). Later lenses are supposed to be smart enough to figure out if they are stationary.
that said, I think systems like this can be fooled, and i think there are situations where you can get worse results when using it than when it is off.
OhLook
Gallery: 105 photos
Joined Dec 2012
Sep 28, 2015 11:46 |  #5
Given that this is my entire gear list:
CAMERAS
Own:
Canon IXUS 80 IS ... 7/10
Canon G15 ... 8.5/10
. . . does it follow, then, that I never need to use IS at all?
Gallery: 15 photos
Joined Jun 2011
Sep 28, 2015 11:54 |  #6
OhLook wrote in post #17724905 (external link)
CAMERAS
Own:
i think you are misunderstanding that article. The list of 4 lenses are the ones that are not smart enough to sit on a tripod with IS on and not get screwed up … all other lenses (and presumably cameras) are smart enough to sit on a tripod with IS on and produce a good image.
but again, I think systems like this can be fooled. Other's will probably disagree, but I have braced against a rail with IS on and occasionally had weird results.
can you even turn IS off on either of your cameras?
OhLook
Gallery: 105 photos
Joined Dec 2012
Sep 28, 2015 12:07 |  #7
Left Handed Brisket wrote in post #17724919 (external link)
i think you are misunderstanding that article. . . .
I construed the first part of the article to mean that the impetus for developing IS in the first place was the shake caused by trying to hold big, heavy, long lenses. Accordingly (my inference here), a lightweight camera that doesn't take attached lenses shouldn't need IS.
I can turn off IS on the G15, at least. On the smaller one, I'd have to check. I don't use that camera much anymore.
Gallery: 15 photos
Joined Jun 2011
Sep 28, 2015 12:14 |  #8
long shutter speeds, and even light weight long lenses benefit from IS too.
Kolor-Pikker
Sep 28, 2015 15:01 |  #9
Weight isn't the problem so much as focal length, on the contrary, a light camera is more easily influenced by the smallest twitches in your muscles while a heavy camera has more mass to smooth motion out with. A classic example is the A7r which had a fairly strong shutter in a small mirrorless body, which often resulted in less than perfectly sharp images unless you strapped a brick to it.
You also shouldn't overestimate being able to brace a camera as still as a tripod, in fact, with many lower-end tripods you'll see the image shake in liveview just by putting your hand on the camera, unless by "brace" you mean balance it on something and use a timer. As long as your hand is touching the camera, IS should be turned on.
5DmkII | 24-70 f/2.8L II | Pentax 645Z | 55/2.8 SDM | 120/4 Macro | 150/2.8 IF
I acquired an expensive camera so I can hang out in forums, annoy wedding photographers during formals and look down on P&S users... all the while telling people it's the photographer, not the camera.
Gallery: 15 photos
Joined Jun 2011
Sep 28, 2015 21:31 |  #10
Search function is broken right now, but there was a post a year or two ago that showed a shot of the ISS taken from a not so good tripod. The shutter slap alone made a crazy cork screw out of the space station with IS not on.
Agree with everything you said KP. While I do think there are times it might mess up, I think it is so rare to be a non issue.
tonylong
...winded
Gallery: 60 photos
Sep 30, 2015 07:55 |  #11
I've used my "older" 100-400 IS L lens on a tripod a fair number of times with the IS on. I've done this to cut down shake visible in the viewfinder. Something to watch, though, is if you don't keep the shutter button half-pressed, after a few seconds the IS will deactive and the lens internal will "slump", not good for getting a good shot!
Tony
ejenner
Gallery: 98 photos
Joined Nov 2011
Oct 01, 2015 19:58 |  #12
Hand on camera - IS on.
Hand off camera, tripod rock steady - IS off.
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
Gallery: 15 photos
Joined Jun 2011
Oct 06, 2015 15:20 |  #13
this is not the picture of the ISS i mentioned above but is almost identical in its result.
https://photography-on-the.net …showthread.php?​p=15265663
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Oct 06, 2015 16:20 |  #14
No.
IS stays on for me, even when on a monopod. I Only turn IS off if I am locked down solid like on a tripod.
CDS' HOT LINKS
3,418 views & 8 likes for this thread, 8 members have posted to it.
2075 guests, 102 members online
