Thread started 30 Sep 2015 (Wednesday) 00:11
Next best alternative to cleaning sensor (other than Rocket blower)?
the.forumer
Joined Oct 2011
Sep 30, 2015 00:11 |  #1
Hi guys,
What would you recommend for cleaning the sensor on my 6D? I have 2 very small strands of cotton/hair stuck on the sensor, and no matter how many times I use my Giottos blower (largest version) on it, it refuses to come off.
What is the next best (DRY) method to clean the sensor?
Otherwise, how much does it cost for Canon to clean the sensor (and also my lens) respectively?
My 24-70ii also got ruined by the fine sand when I visited the sand dunes last week. It seems to leave some fine scratches that I can't remove after blowing/cleaning with isopropyl alcohol. :(
Tom ­ Reichner
"That's what I do."
Gallery: 213 photos
Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot
Sep 30, 2015 01:16 |  #2
the.forumer wrote in post #17727183 (external link)
No need to send to Canon for any reason whatsoever. A quick wet clean is, of course, the best method (and can in no way result in a ruined sensor). However, if you are stuck on dry cleaning, then just go thru the process of a wet clean, but without any fluid. The sensor-sized swab should clear away the strands of cotton/hair, even if no fluid is used.
Sounds like it didn't get ruined at all....it just got some scratches on it. Don't worry about the scratches - they don't and won't cause you any problems whatsoever.
diveguy
Gallery: 21 photos
Joined Jun 2014
Sep 30, 2015 02:05 |  #3
I strongly recommend joining Canon Professional Services. For $100 a year, you can receive Complimentary Canon Maintenance Service on up to 5 items per year.
I just sent my 5D MKIII in on Monday via UPS and received it back on Friday (CPS also covers free return shipping). The sensor is completely clean and they also run through an 18-point cleaning and inspection. The camera came back as clean as it was when I first purchased it – viewfinder, sensor, mirrors, battery compartment, etc.
If you have a single strand of whatever on your sensor, then I would probably try to blow it off or gently remove it, but if you have sensor spots and dirt just send it in when you have some down time. It's really a great service.
Chris Constantine
Chris Constantine Photography
San Rafael, California 94903
https://www.chrisconst​antinephoto.com (external link)
https://www.instagram.​com/chrisconstantineph​oto (external link)
rwmson
Gallery: 91 photos
Sep 30, 2015 06:43 |  #4
VisibleDust Arctic Butterfly 724
yeah, I gots some stuff.
Roger
armis
Joined Jan 2012
Oct 01, 2015 03:07 |  #5
Hi guys,
Buy one of these (external link), it'll last you a lifetime.
1. make sure your battery is full
2. lift the mirror (there's a sensor cleaning mode hidden in the camera's menu just for this)
3. grab a clean swab, put one or 2 drops of product on it, then swipe once from left to right then right to left, keeping the swab flat against the sensor. It's cut to the right size anyway, it's pretty straightforward. You don't need to push it hard against the sensor, just swipe.
4. see if you still have your hair problem (check that you didn't just push it to the edge of the sensor). If so, repeat.
5. lower mirror, let it dry for a few minutes
Alternatively, I cleaned my sensor once with burning alcohol and a Q-tip and it was fine.
Fuji X-T4, 18-55 and 55-200 zooms, Samyang 12
www.wtbphoto.com (external link)
ejenner
Gallery: 98 photos
Joined Nov 2011
Post edited over 8 years ago by ejenner.
Oct 01, 2015 19:45 |  #6
Sensor gel stick is absolutely made for this situation. I use it after a wet clean to get rid of any residual bits of fluff from the pads. as well as any time I have non-stuck dust that whone come out with a blower.
A wet clean or even a pec-pad dry clean is great when something more 'gunky' is on the sensor.
Haven't tried the Arctic Butterfly though.
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
Alveric
Gallery: 38 photos
Oct 01, 2015 20:47 |  #7
Eclipse and VisibleDust swabs.
rdalrt
Oct 01, 2015 21:22 |  #8
ejenner wrote in post #17729493 (external link)
Another vote for the gel stick. So simple to use. And works so well. I haven't had to wet clean since I got it.
Just Sports Photographyexternal link
My Junk ;)
Picture ­ North ­ Carolina
Gaaaaa! DOH!! Oops!
Oct 02, 2015 06:26 |  #9
Didn't see it mentioned here. I have read that if you use a rocket blower, it should be replaced every few years. Apparently the rubber begins to break down after time and if that happens, you can actually be blowing dust onto your sensor.
Website (external link) |
mcoren
Beware the title fairies!
Gallery: 192 photos
Joined Mar 2015
Oct 02, 2015 19:41 |  #10
I use Eclipse solution and SensorSwabs, both from Photographic Solutions. For the 6D you'll need SensorSwab type 3.
Mike
Canon EOS R7, M5, 100 (film), and Sony α6400
I have an orange cat and a brown cat. In HSL, they're both orange.
Nighthound
Gallery: 224 photos
Best ofs: 24
Oct 12, 2015 12:11 |  #11
rdalrt wrote in post #17729568 (external link)
Agree. Just cleaned a 5D II and ID Mark IV with the gel stick. One and done, no repeating to get debris being pushed around the sensor.
Steve
philodelphi
Gallery: 50 photos
Oct 12, 2015 12:52 |  #12
Another vote for the gel stick!
Sony DSC-RX100M2 α7R III / ILCE-7RM3 Cyber-shot DSC-RX10 IV | Voigtlander 65mm F2 Macro APO-Lanthar | Venus Optics Laowa 15mm f/4 Macro | Sony FE 24-240mm F3.5-6.3 OSS Sonnar T* FE 55mm F1.8 ZA FE 24mm f/1.4 GM | Samyang 35mm f/1.4 ED AS UMC | Canon MP-E 65mm f/2.8 1-5x Macro Photo EF 100mm f/2.8 Macro USM | Sigma 100-400mm f/5-6.3 DG OS HSM | Tokina Firin 20mm f/2 FE MF | Tamron 28-75mm F2.8 Di III RXD
the.forumer
Joined Oct 2011
Oct 13, 2015 08:34 |  #13
wow, thanks for the overwhelming responses guys! I've decided to get the sensor swab off eBay (costs me only 3Usd for 6 sticks).
By the way, which gadget do you guys use to clean the viewfinder? Can I use the lens pen or the sensor swab? or is there another dedicated tool for the viewfinder?
BlakeC
"Dad was a meat cutter"
Gallery: 372 photos
Joined Jul 2014
Oct 13, 2015 08:34 |  #14
Lick it
Blake C
BlakeC-Photography.com (external link)
Follow Me on Facebook (external link) , Instagram (external link), or Google+ (external link)
80D |70D | SL1 - Σ 18-35 1.8 ART, Σ 50-100 1.8 ART, Σ 17-50 2.8, Canon 24 2.8 Pancake, Canon 50 1.8 STM, Canon 10-18 STM, Canon 18-135 STM
Alveric
Gallery: 38 photos
Post edited over 8 years ago by Alveric. (3 edits in all)
Oct 13, 2015 10:52 |  #15
the.forumer wrote in post #17743660 (external link)
I use a microPro from Lenspen. If you buy the Lenspen DSLR Pro Kit it comes with three 'pens': one for lenses, one for filters and one for viewfinders (LensPen, FilterKlear, and microPro, respectively).
Also, I'd be leery of buying elcheapo stuff off ewwBay: there's a lot of Sinojunk around that's likely to cause damage simply because it's not built to the same standards and with the same care as the reputable products. I'd rather pay 40 bucks for a 12-pack of VisibleDust swabs than risk totaling a ~$2000 camera by using a rough-fibre, sensor-scratching swab.
5,242 views & 5 likes for this thread, 15 members have posted to it and it is followed by 10 members.
1501 guests, 134 members online
