Getting several emails lately asking if I have any lens conversions available so I thought I'd offer up something super crazy at a crazy cheap price. This is my own 800mm setup that I've used to take pictures of the moon, I live right in the middle of a city so that's the only thing I have access to. So I created a setup to perfect it. Samples pictures were taken on a 7DM2 and a EOS M, 1:1 ish crops.
What you get
80-200mm F4 Samyang(sears) lens
2 (2X) teleconverts which turn it in a 800mm, since it's a fast lens the light loss is not noticeable on a tripod.
1 Canon EF or 1 EF-M mount, your choice. This will work with ANY Canon EOS DSLR,Mirrorless or Cinema camera ever made. These are quality CNC machined aluminum adapters, no cheap die cast stuff.
The lens and each converter were each clearance'd to fit Full frame bodies, crops naturally work as well and with their 1.6 factors this turns into 1,280mm of goodness!
For the converters I went out to a shop in Los Angeles spent $320 buying 20 different converters, went home. Tested all of them and found the two best ones. Then I returned the rest. The lens and each converter have been custom matched to each other.
Bonus: 70-200 F4 Canon tripod mount, it's not an exact match but I'm throwing it for free. I used a piece of foam to shim and protect it. I will also send you links to the free moon stacking and cropping software I use, along with a tutorial.
All glass is clean, no fungus and no oil on aperture.
Front cap and rear EF cap included.
Reason for selling: been getting asked loads for lens conversion and I'm moving on to wide astro stuff in the desert.
$100 shipped anywhere in the US.
Will ship internally for added shipping fee.
Be sure to let me know what camera you have so I can use the correct adapter! I have Canon EF and Canon EF-M at the moment.
