salsa-king wrote in post #17736825
many thanks for your input.
I've always liked the tamron 70-200 vc F2.8 and its a good price new £1000, 2nd hand cheaper. it's not an in your face lens, like cream canon L series.
When I tried one I thought how light and easy to use and quality it was. great value for money.
Is the above better than going F4 70-200 L series non IS?
Or is a 2nd hand F4 70-200 IS worth getting instead..... would i give good low light pictures at concerts or in a church environment.. or is 2.8 the only way to go?
I'm feeling the 70D is more the price I want to spend. Then I could get some more lens'
But looking at the spec of the new 760D, is that the same as the 'old' 70D?
Heya,
The 70-200 F4L IS, is good, but if you need F2.8, there's no substitute for F2.8.
For concerts & church environments, I would want F2.8, with or without stabilization, but with stabilization would be ideal. You're going to want to stop motion so you still need decently fast shutter even in low light, so you still will want to attempt 1/50s, 1/100s, etc, at F2.8, and ISO of whatever it takes to get exposure, maybe ISO 6400 or higher easily in a dark concert or church. More shutter speed would be even better, but with stabilization, you might be able to get away with slow speeds like that so long as the subjects are not moving very fast or at all much (or unless you intentionally want blur, some do).
If budget allows, I would get the 70-200 F2.8 VC Tamron. It's heavy. But it's fast, F2.8, and has good stabilization and costs way less than the Canon MKII and is very close to it in quality. It would be much better suited to low light concert & church stuff, as well as being capable of turning on some action if you needed it to. Work horse lens for everything.
The 70-200 F4L IS is an excellent lens in good light, not ideal for the lowest of light settings, more of an option for someone who doesn't want the weight of an 2.8 zoom.
Very best,
