Is there a formula to calculate the change in minimum focusing distances of a lens when using a 1.4x extender or if using extension tubes?
Any help would be appreciated.
Thank you.
QuackMeUp Senior Member 262 posts Likes: 16 Joined Nov 2011 Location: Rogers, MN More info | Oct 05, 2015 20:17 | #1 Is there a formula to calculate the change in minimum focusing distances of a lens when using a 1.4x extender or if using extension tubes?
Oct 05, 2015 20:24 | #2 The min focus distance should be the same with a teleconverter. But extension tubes...that can get complicated. Here's a link to a site where you can enter the data for extension tubes. Bill in Houston Texas
Archibald You must be quackers! More info | Oct 05, 2015 20:27 | #3 Quack Me Up wrote in post #17734396 Is there a formula to calculate the change in minimum focusing distances of a lens when using a 1.4x extender or if using extension tubes? Any help would be appreciated. Thank you. No change with the extender, but big changes with extension tubes. Canon R5 and R7, assorted Canon lenses, Sony RX100, Pentax Spotmatic F
Archibald You must be quackers! More info Post edited over 8 years ago by Archibald. (4 edits in all) | Oct 05, 2015 20:44 | #4 There is a useful formula, which is Canon R5 and R7, assorted Canon lenses, Sony RX100, Pentax Spotmatic F
InfiniteDivide "I wish to be spared" More info | Oct 05, 2015 20:55 | #5 http://www.dofmaster.com/dofjs.html James Patrus
TomReichner "That's what I do." 17,636 posts Gallery: 213 photos Best ofs: 2 Likes: 8386 Joined Dec 2008 Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot More info | Oct 06, 2015 00:41 | #6 InfiniteDivide wrote in post #17734447 http://www.dofmaster.com/dofjs.html Just manually calculate your selected FL based on your lens FL and the extender used. It looks to me like that link you provided is dealing with depth of field, not minimum focus distance. "Your" and "you're" are different words with completely different meanings - please use the correct one.
Choderboy I like a long knob More info | Oct 06, 2015 02:26 | #7 f1.4bthere wrote in post #17734402 The min focus distance should be the same with a teleconverter. But extension tubes...that can get complicated. Here's a link to a site where you can enter the data for extension tubes. http://www.cambridgeincolour.com …tension-tubes-closeup.htm
Dave
Choderboy I like a long knob More info | Oct 06, 2015 02:36 | #8 You will need to research particular lens and if no data found experiment yourself. Dave
smythie I wasn't even trying More info | Oct 06, 2015 02:54 | #9 Choderboy wrote in post #17734788 Nothing personal, but that page is a fail IMHO. First fail: "Note how extension tubes provide minimal magnification when used with telephoto lenses — which is unfortunately their main weakness." That is true for quite a few Canon super teles. Not true for 300 F4 L IS which has high magnification. Also not true for other Canon Telephoto zooms. Eg the original EF100-400L had high magnification, the updated 100-400II even higher. Second fail: Entering correct data for the 100-400 II with 25mm tube. it calculated "newest closest focusing distance" as 2022.8 mm. The 100-400 II focuses at 980mm bare. According to Canon with a 25mm tube that reduces to 814mm. Regardless if that is true, it definitely reduces with a tube rather than increasing to more than double. I would suggest that the first point is correct if read to understand that it is talking about increase of magnification (particularly in comparison to the same extension for shorter focal lengths). This is borne out by Canon's specs for the 100-400II showing that 12mm of extension increases max magnification from 0.31x to 0.38x and 25mm of extension to 0.46x. In comparison to the dramatic changes you can get with shorter focal lengths this is a change that could correctly be argued to be minimal.
Choderboy I like a long knob More info Post edited over 8 years ago by Choderboy. (2 edits in all) | Oct 06, 2015 03:12 | #10 smythie wrote in post #17734806 I would suggest that the first point is correct if read to understand that it is talking about increase of magnification (particularly in comparison to the same extension for shorter focal lengths). This is borne out by Canon's specs for the 100-400II showing that 12mm of extension increases max magnification from 0.31x to 0.38x and 25mm of extension to 0.46x. In comparison to the dramatic changes you can get with shorter focal lengths this is a change that could correctly be argued to be minimal. Secondly I would suggest that you are incorrectly assuming that the 100-400II is actually a 400mm lens at MFD. This is quite likely not the case. It could be quite a bit less. The calculator on that site suggests it's around 180mm which to me sounds pretty short but plugging 400mm into the calculator and expecting correct results is an exercise in futility
Dave
smythie I wasn't even trying More info | Oct 06, 2015 03:15 | #11 Choderboy wrote in post #17734815 I disagree with your first point. "which is unfortunately their main weakness" is clearly not true for many telephotos. Particularly for 300 F4 IS L and 100-400II it is considered a strong point for many buyers and reviewers. Your second point - I agree. Using 180mm results in correct MFD and magnification but I also doubt that is the true focal length at MFD. I just tried to get an idea how much focus breathing there is with the 100-4500II and there seems to be little. "their main weakness" would not be in reference to telephoto lenses, but rather extension tubes
Choderboy I like a long knob More info Post edited over 8 years ago by Choderboy. | Oct 06, 2015 03:33 | #12 smythie wrote in post #17734818 "their main weakness" would not be in reference to telephoto lenses, but rather extension tubes
Dave
Archibald You must be quackers! More info | Oct 06, 2015 10:41 | #13 Choderboy wrote in post #17734824 Well I will continue to use tubes with my 100-400II. 25mm tube for near 50% increase in max magnification is not a weakness to me, it's a useful result. (I usually use a single 36mm tube for more increase) I agree with smythie that the actual focal length of the 100-400mm II is close to 175-180mm at its minimum focus distance. It seems extreme, but these lenses are known to change F by quite a bit when focusing. Canon R5 and R7, assorted Canon lenses, Sony RX100, Pentax Spotmatic F
| Latest registered member is semonsters 1507 guests, 129 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
