Thread started 12 Oct 2015 (Monday) 06:24
70d bounce flash
Frodge
Joined Nov 2012
Oct 12, 2015 06:24 |  #1
Its underexposing quite a bit on ettl. The pics look better without a flash...I think I've read about this before, is there a solution? My brother just bought a 70d and I let him try my flash, and I noticed underexposure immediately.
“It's kind of fun to do the impossible.” - Walt Disney.
Equipment: Tokina 12-24mm, Canon 40mm 2.8, Tamron 17-50 2.8 XR Di, Canon 18-55mm, Canon 50mm 1.8, Tamron 70-300VC / T3I and 60D
sapearl
Gallery: 243 photos
Oct 12, 2015 06:53 |  #2
What metering mode do you have set on the camera and what part of the scene is being metered? It may be something with your technique but if you provided a sample image we could more easily tell. I'm sure it can be easily remedied - I've done this myself in the past ;-)a (using a 5d though)
MY WEBSITE (external link)- MY GALLERIES (external link)- MY BLOG (external link)
Artists Archives of the Western Reserve (external link) - Board
Frodge
Joined Nov 2012
Post edited over 8 years ago by Frodge.
Oct 12, 2015 07:02 |  #3
Evaluative and ettl. Ive never had a problem like this on my 60d or t3i...
I can assure you its not technique. Maybe a setting I'm missing, but the pictures look like a flash is not being used at all
sapearl
Gallery: 243 photos
Oct 12, 2015 07:14 |  #4
Frodge wrote in post #17742172 (external link)
What shutter speed/aperture and ISO - perhaps you are trying to illuminate too large an area? I too use evaluative. If there are brighter reflective objects in the scene the camera could be metering those, be tricked into thinking the scene is brighter than it is, and the flash then reduces power output. I'm only suggesting this because I've done this exact same thing :oops:.
windpig
Chopped liver
Oct 12, 2015 07:32 |  #5
It always under exposed for me when bouncing. Like any of the metering, you have to learn the cameras idiosyncrasies and then compensate.
Go ahead, spin the wheel.
Bassat
"I am still in my underwear."
Joined Oct 2015
Post edited over 8 years ago by Bassat.
Oct 12, 2015 07:38 |  #6
I agree with the original post. Something is different about the 70D and bounce flash. I used a 70D and 18-55 STM the other day. Indoors, incandescent light, Av, 430EX II, 1/250, f/8, ISO 800, flash at 45 degrees and using a flash mounted reflector. I got a lot of underexposed shots, so I bumped up FEC to 2/3. No help. I bumped ISO to 1600. No help. The 70D 430EX II combination does not behave the same way my 6D does.
I did notice that the wide shots encompassing most of a room were more properly exposed than zoomed in shots of individuals and/or couples. Very odd.
sapearl
Gallery: 243 photos
Post edited over 8 years ago by sapearl.
Oct 12, 2015 07:54 as a reply to  @ Bassat's post |  #7
Are you shooting in (camera) manual mode or are you using one of the automatic settings?
When I'm shooting dark wedding receptions or other dim venues I typically set the camera in manual. The onboard meter is pretty useless under these conditions. I manually select a slower shutter speed and wider aperture and let the ETTL fill in the rest.
Bassat
Joined Oct 2015
Oct 12, 2015 08:12 as a reply to  @ sapearl's post |  #8
I'm using the settings I listed in the post you responded to. The goal was to overpower ambient, not blend it. My house is an eclectic mixture of mixed fluorescent and incandescent light, combined with my wife's flair for colored lampshades. There is no way to blend this nightmare. My 6D and 17-40 and 24-105 have done the job nicely in the past. I thought I'd give the 70D a run, since I had it out for STM video anyway, which was a total fail. I think windpig is right. I just need to figure out what works with the 70D. It did not behave like my 6D, but it was consistent.
Frodge
Joined Nov 2012
Oct 12, 2015 08:18 |  #9
It acts almost as if your shooting high I so and no flash. The pics look like garbage.
sapearl
Gallery: 243 photos
Oct 12, 2015 08:22 as a reply to  @ Frodge's post |  #10
What are your settings?
Frodge
Joined Nov 2012
Oct 12, 2015 08:22 |  #11
Its almost as if the camera wants to override the flash. Basically it knows there is a flash and it pulls down exposure excessively
Bassat
Joined Oct 2015
Oct 12, 2015 08:23 |  #12
E
Frodge wrote in post #17742238 (external link)
That is exactly what I got. Dark, looks like WB is off, very noisy. Garbage is the proper term.
davesrose
Title Fairy still hasn't visited me!
Post edited over 8 years ago by davesrose. (2 edits in all)
Oct 12, 2015 08:24 |  #13
sapearl wrote in post #17742213 (external link)
This is what I do as well...I find manual mode (and maybe letting camera just decide ETTL) is the most reliable setting. What flash are you using OP? If you're bouncing off the ceiling, there may not be enough light output getting to your subject (this can also be effected by battery power and/or modifiers used). If you bump your flash exposure compensation up and nothing changes: then you know the flash isn't able to give enough light for your settings.
Canon 5D mk IV
EF 135mm 2.0L, EF 70-200mm 2.8L IS II, EF 24-70 2.8L II, EF 50mm 1.4, EF 100mm 2.8L Macro, EF 16-35mm 4L IS, Sigma 150-600mm C, 580EX, 600EX-RT, MeFoto Globetrotter tripod, grips, Black Rapid RS-7, CAMS plate and strap system, Lowepro Flipside 500 AW, and a few other things...
smugmug (external link)
Bassat
Joined Oct 2015
Oct 12, 2015 08:39 |  #14
davesrose wrote in post #17742249 (external link)
My settings: Av @ 1/250 w/flash, ISO 1600, and f/8 is essentially manual mode, but not really. Perhaps the different mode does make a difference in how flash is metered. I will go back and try the 6D in Av, and the 70D in manual. If the results fip-flop, I believe we have an answer.
Keyan
Joined Mar 2011
Oct 12, 2015 08:43 |  #15
To the helpers who are pitching in who haven't used a 70D - it's the 70D. It does this when using diffusers or bouncing the flash. Canon has never fixed the issue, and it's maddengly inconsistent - one shot will be great and the next 5 are way under.... Generally the work around is to up the flash EC by about 2/3, but that runs the risk of occasionally massive over exposure when it does meter correctly. I have no idea why it does this.
Cameras: 7D2, S100
Lenses: 17-55 f/2.8 IS USM, 18-135 STM, 24-70 f/4L IS USM, 50 f/1.4 USM,70-300L IS USM
Other Stuff: 430 EX II, Luma Labs Loop 3, CamRanger
65,485 views & 78 likes for this thread, 39 members have posted to it and it is followed by 21 members.
70d bounce flash
1294 guests, 135 members online
