Thread started 12 Oct 2015 (Monday) 09:47
Salt Water Damage - Any Hope?
MacA488
Gallery: 31 photos
Joined Dec 2013
Oct 12, 2015 09:47 |  #1
While on a recent trip to the coast, we got caught in a storm while on a boat. Waves were crashing over the sides and we got SOAKED!! I had wrapped my camera (70D) in a poncho (water-proof), but when we got back to the dock I noticed that some water had found its way inside the poncho. At first, it looked like only the external surfaces were wet. No water was in the battery compartment or around/inside the lens mount, mirror or sensor area. I removed the battery and SD card. I then wiped everything down good with a wet (fresh water) cloth, dried it off good, then I covered it with white rice in a ziplock bag. After waiting 4 days, I removed the camera and lens (separate bags). The lens is fine, but the camera will not power up. I used 3 different batteries with no luck.
So, I guess it is safe to assume that SOME water got inside and caused damage. Am I SOL, or can it be repaired?:cry:
Mark
C&C welcome! I'm here to learn from the best!
Canon 5D MKIII || Sigma 10-20mm || Rokinon 18mm f2.8 || Canon 24-70mm f4L || Canon 70-200mm f4L IS || Canon 100-400L
My flickr (external link)
Aswald
Joined Oct 2013
Oct 12, 2015 09:51 |  #2
MacA488 wrote in post #17742330 (external link)
Best bet is to send it in to Canon quickly. They'll take it apart to access the damage. Salt water corrosion is worse the longer you leave it.
If it's not left too long, a thorough cleansing and corrosion inhibition by Canon may revive the camera.
Time is your greatest enemy here.
Good luck and I hope you get your camera back on track soon.
Frodge
Joined Nov 2012
Oct 12, 2015 09:53 |  #3
Unfortunately, if the circuit boards and connectors became wet with salt water, my gut instinct just thinks it will get worse over time. It acts in a similar fashion that rust does.
“It's kind of fun to do the impossible.” - Walt Disney.
Equipment: Tokina 12-24mm, Canon 40mm 2.8, Tamron 17-50 2.8 XR Di, Canon 18-55mm, Canon 50mm 1.8, Tamron 70-300VC / T3I and 60D
davesrose
Title Fairy still hasn't visited me!
Oct 12, 2015 09:57 |  #4
If there's corrosion on any main circuit board, then it's at least a several hundred dollar repair. There may be a shorted circuit board, as well as ancillary components that got shorted with it. Send it immediately and get an estimate of the repair. It's worth a repair estimate fee to see if it's more expensive to repair then buy another camera.
Canon 5D mk IV
EF 135mm 2.0L, EF 70-200mm 2.8L IS II, EF 24-70 2.8L II, EF 50mm 1.4, EF 100mm 2.8L Macro, EF 16-35mm 4L IS, Sigma 150-600mm C, 580EX, 600EX-RT, MeFoto Globetrotter tripod, grips, Black Rapid RS-7, CAMS plate and strap system, Lowepro Flipside 500 AW, and a few other things...
smugmug (external link)
MacA488
Gallery: 31 photos
Joined Dec 2013
Oct 12, 2015 15:28 |  #5
Thanks for the replies! I contacted the Canon Factory Service Center this morning and will be sending them my 70D ASAP!
Mark
Perfect_10
Joined Aug 2004
Oct 13, 2015 11:50 |  #6
Do you carry accidental damage insurance? .. if so you may need it.
My Gear List  :p
PCousins
Gallery: 1191 photos
Joined Nov 2014
Oct 13, 2015 12:24 |  #7
Im reckoning on $495 estimate from Canon. Will be interested to know your quote.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Oct 13, 2015 18:41 |  #8
I didn't think Canon would work on any anything if they see salt water? I guess time will tell. :)
davesrose
Oct 13, 2015 18:43 |  #9
TeamSpeed wrote in post #17744401 (external link)
Yeah they will. It's just that "water damage" is not covered by the warranty. I had a bead of sweat get in my 5Dc once....it's was over $850 (which at the time was less then buying another camera).
Canon 5D mk IV
Submariner
Joined May 2012
Oct 13, 2015 23:13 |  #10
Thats what I was told by a guy, who had a problem after shooting water skiing, Canon UK apparently would not repair it.
Probably kinder to the customer in the long run, as once corrosion has been started , apparently can fail later.
Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
Archibald
You must be quackers!
Gallery: 789 photos
Oct 13, 2015 23:32 |  #11
I believe Canon will service water-damaged gear but obviously not under warranty, and they won't honor a repair estimate if they open it up and discover water damage that wasn't disclosed.
davesrose
Oct 13, 2015 23:52 |  #12
Archibald wrote in post #17744715 (external link)
I didn't know what was wrong with my camera when I sent mine in, and they contacted me to say it was "water damaged". That I could either agree to pay for repairs or get it returned. They're happy to do a repair on your dime;-)a
Canon 5D mk IV
Aswald
Joined Oct 2013
Oct 13, 2015 23:57 |  #13
My experience with Canon has always been, a fixed surcharge to open up the unit. A final quote will be presented once they find out what needs to be replaced or done. Either way, the surcharge has to be paid.
Depending on where you are at and the competence of the technicians at that svc center, they may even try to repair units which are discontinued.
Archibald
Gallery: 789 photos
Oct 14, 2015 00:23 |  #14
davesrose wrote in post #17744728 (external link)
Sure.
I was just saying that there are situations where they will quote an amount for a repair, and on actually doing the repair, find further damage - for instance hidden water damage. In such cases they will not honor the original quote.
From Canon: "Any damage due to liquid, sand, corrosion, battery leakage, or accidental damage is specifically excluded from warranty coverage. In the unlikely event that
any internal or external damage is found due to any of the above mentioned conditions, a revised estimate will be sent for your authorization."
So certainly, Canon will do repairs like this.
davesrose
Oct 14, 2015 00:42 as a reply to  @ Archibald's post |  #15
My experience was that they inspect and quote out before doing any repair/maintenance.
Canon 5D mk IV
9,832 views & 1 like for this thread, 9 members have posted to it and it is followed by 4 members.
1000 guests, 121 members online
