Hey guys, I'm looking at buying equipment for at home studio photography of people.
Just to be clear, I have no idea what I'm doing, so bear with me. I apologize in advance for what are probably very amateur questions.
For my needs, I'm really looking for bang-for-the-buck. Good, but doesn't have to be the best. Think passably professional. And with sufficient versatility because I feel artsy.
I've been looking online and have some ideas, and I want your opinions on whether these are good or bad options, let me know if things are incompatible, if I'm missing things I should include, etc. Again, I don't know anything.
Lights: Bowens Gemini 400Rx kit.
This comes with two, and I'd get two pair for a total of 4 lights.
(Also, question, do these stay on or are they like a flash? I don't know how to tell the difference.)
Oh, I guess I should probably also get at least one boom arm. Will those stands handle the weight leverage if I give it a counterweight? And are the attachments one size? Like any arm should fit?
Softboxes: Bowens Lumiair 60-80 Softbox
Is that right with those lights? Not sure what to look for. And I'm thinking only three of these because I'm poor and I'd already have the umbrellas anyway.
Egg Crates: Bowens 40 Degree Soft Egg Crate
Two of these. Looks fun. And only two because money, and that's at least enough to put two behind the subject.
A few barn door attachments would also be great too but I couldn't find them.
Reflectors: Impact 5-in-1 Collapsible Oval Reflector - 42x72"
Is that size overkill or would it be usefull for a full body photo? Also not sure what stand to use. Think I could just clip it to a microphone stand and save some money? I have endless quantities of mic stands.
And an umbrella reflector
Backdrops: Is this hella cheap or is this what these are supposed to cost?![]()
And I also wasn't sure about the actual backdrops. Like which brands to buy from. I'd want a grey, white, and black. 10 feet wide and I'm guessing pretty long if I want feet in the picture. Suggestions?
End goal is around $3000ish. I realize I'm slightly over, but close enough is good enough. Just don't want to spend too much.
Thanks!
Three lights= One for background (unless you're going with a white seamless full body, then you'll need two on the background), one for key, one for hair or rim (if needed) and a reflector for fill. It's a lot easier to maintain a pleasing balance between key and fill by using reflectors instead of lights. If you want something that packs away easily then just go with a regular background stand "kit" (two tripods and a background crossbar). I personally don't care for them, but that's mainly because I have a very limited amount of space.
