Is there a function that forces the camers (350d) to focus and then shoot at the end of the autotimer versus at the beggining?
psykopyro Member 132 posts Joined Dec 2005 More info | Mar 05, 2006 11:49 | #1 Is there a function that forces the camers (350d) to focus and then shoot at the end of the autotimer versus at the beggining? Canon EOS 350D
Mar 07, 2006 00:40 | #2 bump. any ideas? Canon EOS 350D
ChopstickHero Senior Member 678 posts Joined Jan 2006 Location: Redlands, CA More info | Mar 07, 2006 00:43 | #3 if you press the shutter button halfway, it will autofocus. when you press down fully, it will initiate count down. the focus shouldn't change. unless of course, whatever you are taking a pic of changes position and causes an out of focus image. Canon 40D and 350D :: Canon 70-200mm f/2.8L IS :: Canon 17-55mm f/2.8 IS :: Canon 10-22mm f/3.5-4.5 :: Canon BG-E2 & BG-E3 :: Canon 430EX Speedlite :: Crumpler 6MDH & The Whickey and Cox
mrklaw Senior Member 678 posts Joined Jan 2006 More info | ChopstickHero wrote: if you press the shutter button halfway, it will autofocus. when you press down fully, it will initiate count down. the focus shouldn't change. unless of course, whatever you are taking a pic of changes position and causes an out of focus image. Like you sitting down on the chair in front of the camera? _______________
| Latest registered member is IoDaLi Photography 1768 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
