Thread started 05 Mar 2006 (Sunday) 11:50
Fill Flash
canon ­ shooter
Mar 05, 2006 11:50 |  #1
I have a 20D and a 580EX, and trying to figure out how to use as Fill Flash. Can't find anything in either manual about it
Jim
5D Mark III Grip, 40D Grip, Canon 17-40L, Canon 24-105 F4L IS, Canon 70-200 IS II F2.8L, Canon 100-400L, Canon 50 F1.4, Canon 100 F2.8, Canon 580 EX
It's the Glass that Counts!
ChopstickHero
Mar 05, 2006 11:53 |  #2
a little complicated, but here's everything you need to know on Canon flashes: http://photonotes.org/​articles/eos-flash/ (external link)
And here's the fill flash part:
http://photonotes.org …ash/index2.html​#fillflash (external link)
Canon 40D and 350D :: Canon 70-200mm f/2.8L IS :: Canon 17-55mm f/2.8 IS :: Canon 10-22mm f/3.5-4.5 :: Canon BG-E2 & BG-E3 :: Canon 430EX Speedlite :: Crumpler 6MDH & The Whickey and Cox
Wilt
Mar 05, 2006 11:58 |  #3
Super (over) simplified: Fill flash, put Canon camera in Av or Tv mode,turn on flash, aim and shoot!
The comlications: A) doing the above and not being aware that in low light setting the camera in Av can and will select a very sllloooowww shutter speed to pick up ambient light to the appropriate level (while exposing main subject via ETTL flash) will result in motion blurred shots because you are assuming the camera has a decent handholdable shutter speed. B) what the camera truly does is determine in part by the Custom Fn for selection of flash synch speed C) the camera behaves differently above EV10 light level vs. below EV10 light level
blundar
Mar 07, 2006 09:35 |  #4
Here is everything that you need to know about fill flash:
http://www.popphoto.co​m …download/821200​311318.pdf (external link)
or (same article)
http://www.popphoto.co​m …ction_id=4&arti​cle_id=706 (external link)
This will give you a great start but obviously, you always have to consider these additional things also (max & min shutter speed, over exposing sky/circular polarizer/lens flare, position of shadows across a person's face).
Antonio Cotto
GemPhoto
http://www.myspace.com​/gemphoto (external link)
http://ujenatalent.com​/photographer/11253.ht​ml (external link)
http://www.modelmayhem​.com/member.php?id=886 (external link)
1,042 views & 0 likes for this thread, 4 members have posted to it.
Fill Flash
2102 guests, 96 members online
