I am looking for a solution for putting a gel on my gel for Flashpoint RoveLight 600...
In case you have it, how do you use color modifiers with the head? I intend to use the head with Elinchrom softboxes.
Thanks!
oharing Senior Member 564 posts Likes: 23 Joined Apr 2010 Location: Miami, FL More info | Oct 30, 2015 13:30 | #1 I am looking for a solution for putting a gel on my gel for Flashpoint RoveLight 600...
OceanRipple* Senior Member 842 posts Likes: 175 Joined Dec 2014 More info Post edited over 8 years ago by OceanRipple*. | Oct 30, 2015 14:11 | #2 Hi, See this thread which is quite similar as I am using a Rovelight/Jinbei HD600:
Echo63 Goldmember 2,868 posts Likes: 169 Joined Aug 2006 Location: Perth - Western Australia - Earth More info | Oct 31, 2015 11:09 | #3 is there an internal baffle in your softbox ? My Best Imageswww.echo63.deviantart.com
happy2010 Looking for the light first 559 posts Likes: 99 Joined Feb 2011 More info Post edited over 8 years ago by happy2010. (3 edits in all) | Oct 31, 2015 15:00 | #4 I've had a pair of these double clips for years: MARY
windpig Chopped liver More info | Oct 31, 2015 17:27 | #5 I've tried some of those clips. It just depends on the construction of the modifier I'm gelling and how much bleeding around the edges I feel I can deal with. I actually use blue painters tape a lot to secure gels. Would you like to buy a vowel?
happy2010 Looking for the light first 559 posts Likes: 99 Joined Feb 2011 More info | Oct 31, 2015 17:42 | #6 Absolutely WINDPIG. Hence mine was just one view (& as I am cautious around strobes & potential heat). MARY
MalVeauX "Looks rough and well used" More info Post edited over 8 years ago by MalVeauX. | Nov 06, 2015 02:28 | #7 Heya,
level5photog Member 171 posts Likes: 30 Joined Nov 2015 More info | Oct 08, 2016 15:49 | #8 There are a couple ways I found to gel the flash. One is to buy a small plastic and double tape the gel. Cheetahstand is working on a glass gel available in 1/2 CTO and CTO gel. Alternatively, I'm currently cut up CTS gel and use cooking rubber band to hold the gel. It's not elegant but I've tested and it works/
| Latest registered member is semonsters 1039 guests, 115 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
