Thread started 01 Nov 2015 (Sunday) 18:33
6D - Weird Image Line
drveede76
Joined Dec 2011
Nov 01, 2015 18:33 |  #1
Need some help from POTN.
I was at the the museum today with the family and in two specific display cases, this issue of a line in the image kept happening. it was not consistent and was random around the image. Is this a shutter issue? Or maybe a light cycle of the display case? It seems like it is in the camera since it remained in the same orientation of the camera. It only happened on these two parts of the museum. I was shooting aperture priority at f2.8.
Thank you,
Dave
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/11/1/LQ_757116.jpg
Image hosted by forum (757116) © drveede76 [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/11/1/LQ_757117.jpg
Image hosted by forum (757117) © drveede76 [SHARE LINK]
6D, 24-70L 2.8 ii, 16-35L 2.8, 70-200L 2.8 IS ii, 24-105L
JeffreyG
Gallery: 42 photos
Nov 01, 2015 18:39 |  #2
I'd say your shutter is failing. How much use has this camera had?
drveede76
Joined Dec 2011
Nov 01, 2015 18:49 as a reply to  @ JeffreyG's post |  #3
About 25k actuations. It was only on these two specific display cases. I even went back and tried again after it stopped and it happened again.
Dave
gjl711
Nov 01, 2015 18:52 |  #4
In both the shutter speed is quite high. It could easily be the lights cycling. S;ow down the shutter to 1/60th and it will go away if it is the lights cycling.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
gjl711
Nov 01, 2015 19:33 |  #5
Actually, looking at it closer, I don't think it's lights cycling. Looks more like shutter sticking.
::Gear::
drveede76
Joined Dec 2011
Nov 01, 2015 19:40 as a reply to  @ gjl711's post |  #6
Wouldn't the shutter look bigger, and be at an angle?
gjl711
Nov 01, 2015 19:48 |  #7
drveede76 wrote in post #17768668 (external link)
That's why at first I though it was something else.
::Gear::
gossamer88
"something else"
Gallery: 94 photos
Joined Aug 2014
Nov 01, 2015 19:51 |  #8
Do you have and/or used a EF-S lens on your 6D?
EOS R5 | EOS R7 | iPhone 12 Pro
RF 100-500mm | RF 100-400mm | RF 800mm F11 | RF 600mm F11
RF 24-240mm | RF 50mm 1.8 | RF 35mm 1.8 Macro | RF 16mm 2.8
CheleA
Joined Jul 2014
Nov 01, 2015 20:20 |  #9
gossamer88 wrote in post #17768676 (external link)
Nothing to add to the original post:( However, this comment caught my attention, does the EF-S lens on a 6D matter? If so, why?
Thanks,
drveede76
Joined Dec 2011
Nov 01, 2015 21:11 as a reply to  @ gossamer88's post |  #10
I was using a 24-70 2.8 when it happened. I never saw it before and I haven' seen it since. I even tried using the same settings in manual mode.
maverick75
Joined May 2012
Nov 01, 2015 21:30 |  #11
You can't even physically mount EF-S lenses on a Canon full frame.
joeseph
"smells like turd"
Gallery: 264 photos
Joined Jan 2004
Nov 02, 2015 01:29 |  #12
Kek & Kauket at play eh?
have a suspicion that it's fluro lighting causing the problem rather than shutter - both lighting sources appear to be at 90 degrees to the dark line. If you can get back and do some test shots at differing shutterspeeds you may be able to reproduce the problem & see how to sort it. Which museum was it?
TF posting: here :-)
Bassat
"I am still in my underwear."
Joined Oct 2015
Nov 02, 2015 05:56 |  #13
It doesn't look like shutter to me. In the portrait orientation shot, were you holding camera grip up, or grip down? The 'line' is only in the right place to be shutter failure if you had grip down. If shot grip up, it can't be a shutter issue, it is on the wrong side.
drveede76
Joined Dec 2011
Nov 02, 2015 08:01 |  #14
joeseph wrote in post #17768964 (external link)
It was the Houston TX Museum of Natural Science.
drveede76
Joined Dec 2011
Nov 02, 2015 08:01 |  #15
Bassat wrote in post #17769060 (external link)
I do grip up in portrait orientation.
4,407 views & 2 likes for this thread, 12 members have posted to it and it is followed by 8 members.
1400 guests, 136 members online
