Being lazy....
Has anyone compared the 2 at 1920x1080/24p?
Are there any resolution improvements?
Submariner Goldmember 3,028 posts Likes: 47 Joined May 2012 Location: London More info | Nov 07, 2015 19:12 | #1 Being lazy.... Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
TeamSpeed 01010100 01010011 More info | Nov 08, 2015 05:53 | #2 As 1920 and 1080 is your resolution for video, I don't see how having a 50mpx vs a 22mpx is more beneficial. I guess we shall see once the answers come in. Past Equipment | My Personal Gallery
sploo premature adulation More info | Nov 08, 2015 06:09 | #3 IRC the 5D3 resolution is exactly 3x the required video resolution (with some cropping for 16:9) so can be processed to get a good image with relatively little moiré. Camera, some lenses, too little time, too little talent
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Nov 08, 2015 07:06 | #4 Well assuming they use the whole sensor, at a 16:9 ratio crop, then the 50MP of the DS should allow for much more latitude in processing the results. In theory that should result in much better colour and less artifacts. It also calls for a lot of processing power to make use of all of that extra sensor data. Starting with more data should usually mean that you get superior results as you reduce its size.
AJSJones Goldmember More info Post edited over 8 years ago by AJSJones. | Nov 08, 2015 11:30 | #5 As Alan notes, it's all in the available processing power. That and how much data can be read from the available pixels in the frame-rate interval. There's no way either can read the whole sensor out 24 or 30 times a second, so there must be selective read-out (limited by number and arrangement(?) of data-pipes out of the sensor, line-skipping, binning etc) and/or processing during readout before final compression and storage. Not the kind of thing one can bring intuition to when trying to compare the two without any info on those factors. Then, it's up to the engineers and ultimately marketing (
Nov 08, 2015 18:34 | #6 TeamSpeed wrote in post #17776069 As 1920 and 1080 is your resolution for video, I don't see how having a 50mpx vs a 22mpx is more beneficial. I guess we shall see once the answers come in. Pretty much my thoughts but I lack the experience to test them technically. Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
Nov 08, 2015 18:40 | #7 sploo wrote in post #17776076 IRC the 5D3 resolution is exactly 3x the required video resolution (with some cropping for 16:9) so can be processed to get a good image with relatively little moiré. I don't think the 5Ds is, though there's way more processing performance in that newer body. I think there were hints from Canon that it wasn't really intended for video work though. I read that too,msomwas not expecting great advances on the video front - the question is has it regressed. Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
Nov 08, 2015 18:49 | #8 BigAl007 wrote in post #17776096 Well assuming they use the whole sensor, at a 16:9 ratio crop, then the 50MP of the DS should allow for much more latitude in processing the results. In theory that should result in much better colour and less artifacts. It also calls for a lot of processing power to make use of all of that extra sensor data. Starting with more data should usually mean that you get superior results as you reduce its size. Alan Hmmm see what you are saying. Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
Submariner THREAD STARTER Goldmember 3,028 posts Likes: 47 Joined May 2012 Location: London More info Post edited over 8 years ago by Submariner. | Nov 08, 2015 18:51 | #9 AJSJones wrote in post #17776275 As Alan notes, it's all in the available processing power. That and how much data can be read from the available pixels in the frame-rate interval. There's no way either can read the whole sensor out 24 or 30 times a second, so there must be selective read-out (limited by number and arrangement(?) of data-pipes out of the sensor, line-skipping, binning etc) and/or processing during readout before final compression and storage. Not the kind of thing one can bring intuition to when trying to compare the two without any info on those factors. Then, it's up to the engineers and ultimately marketing ( ) how those factors are balanced.(I like the ETC approach used by Panasonic and others - just take the 1920x1080 in the middle of the chip (or 3840x2160 etc) to produce clean 1080 video with a "teleconversion factor" good for distant wildlife and such. On the 5DS, that would give quite a teleconverter - but the chip has to be designed specifically to read out those data quickly - not something a "stills" camera would be optimized for )Hmmm maybe thats why Canon doent exactly extoll the 5DS R as a leap in video technology lol Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Nov 09, 2015 07:29 | #10 Assuming that you are using 1080p video using one of the "normal" codec's, then the processing power needed for video from the 5Ds will be the same as from the 5DIII. You have to remember that what you are getting from the camera is processed 1080p video, the equivalent of shooting JPEG in camera, but with a size restriction thrown in too. All of my comments in my previous post were to do with how Canon are dealing with the data coming from the sensor, and how they might be processing it down to the 1080p video that gets recorded to your memory card.
sploo premature adulation More info | Nov 09, 2015 15:48 | #11 Submariner wrote in post #17776668 Plus Imam worried about the processing power needed to edit video files from the 5DS R if theyncorrolate in size to stills! As BigAl has noted: 1080p video out of a 5D3 will be the same "size" as 1080p out of a 5Ds (all the processing to produce that video is in camera). Camera, some lenses, too little time, too little talent
Nov 10, 2015 12:27 | #12 Thanks for the info Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
sploo premature adulation More info | Nov 10, 2015 14:51 | #13 Submariner wrote in post #17778786 Thanks for the info No worries. Camera, some lenses, too little time, too little talent
Nov 11, 2015 04:29 | #14 sploo wrote in post #17778977 No worries. It does occur to me that it's possible they're having to throw away a lot of pixels (as opposed to averaging them together) to go from the 50MP sensor to the 2MP HD resolution (for performance reasons). That might lead to worse moiré than the 5D3, but I am just speculating. Thanks interesting point. Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
| Latest registered member is semonsters 1277 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
