Thread started 09 Nov 2015 (Monday) 08:08
off camera lighting
mike_311
Checking squirrels nuts
Gallery: 18 photos
Joined Mar 2011
Nov 09, 2015 08:08 |  #1
when using off camera lighting does anyone shoot without a modifier? i usually shoot weddings by myself and using a modifier is just too much hassle, especially when the wind blows. i like the extra light for fill but i'd really like to lighten things up so i can move around quicker and easier.
Canon 5d mkii | Canon 17-40/4L | Tamron 24-70/2.8 | Canon 85/1.8 | Canon 135/2L
www.michaelalestraphot​ography.com (external link)
Flickr (external link) | 500px (external link) | About me
Nethawked
Gallery: 24 photos
Joined Oct 2014
Nov 09, 2015 09:23 |  #2
I don't do weddings, but I have this and it's very useful for both handheld or mounted off-camera flash.
http://www.bhphotovide​o.com …_267_Pocketbox_​Max_8.html (external link)
gonzogolf
dumb remark memorialized
Gallery: 559 photos
Nov 09, 2015 09:35 |  #3
If you look at Dankatas work in the 135l thread he rarely uses a modifier. One thing to consider is the effect you are trying to achieve. If you just want a little fill then bare lights can be very effective, but if you are trying to make the ocf the key light then the sharp edges of the shadows are more noticeable.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 7 years ago by TeamSpeed. (2 edits in all)
Nov 09, 2015 09:38 |  #4
Considering that it seems the best lighting is one where the light source is big, about the only way is to add a diffuser of some sort, either an umbrella or softbox, correct? Otherwise either the light falloff would be too great because you had to move your light back pretty far, or you will have hotspots if you move the light too close. Even if you bounce the light off a panel, you are still going to have that panel to deal with.
There are ways to easily anchor a light stand down so that breezes don't knock down your equipment. 4 tent stakes and 2 long bungies can hold down a stand pretty well and won't take up a lot of space.
Some of these: http://www.amazon.com …ctive-Tools/dp/B00WC1OJXO (external link)
Some of these: http://www.amazon.com …=1-7&keywords=bungie+cord (external link)
4 stakes down, one bungie to each pair, but wrapped once around the light stand on one of the extension clamps. Just a thought? I haven't tried this yet myself, but it is my plan. Thoughts? I know it goes against your wanting to move around alot, so this won't work in that situation. :(
I just bought a streaklight monolight, and am thinking about adding this accessory. I could put this light about anywhere, a tree, a light stand, have it held, etc, and it should make for a very portable system.
http://www.adorama.com​/fpbd11sl.html (external link)
gonzogolf
Gallery: 559 photos
Nov 09, 2015 09:41 |  #5
TeamSpeed wrote in post #17777291 (external link)
Staking a stand is impractical for wedding work. It's great in theory but the time simply isn't there.
mike_311
Gallery: 18 photos
Joined Mar 2011
Nov 09, 2015 09:54 |  #6
gonzogolf wrote in post #17777295 (external link)
exactly. time is very limited.
for normal portrait session, i have no problem weighing it down with sand bags, for wedding work that time inst there. until i start using a VAL, i may have to experiment with bare flash.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Nov 09, 2015 10:04 as a reply to  @ gonzogolf's post |  #7
I did say this wouldn't meet the criteria of moving around... ;)
How about this article? http://improvephotogra​phy.com …amera-lighting-modifiers/ (external link)
mike_311
Gallery: 18 photos
Joined Mar 2011
Nov 09, 2015 10:19 as a reply to  @ TeamSpeed's post |  #8
i keep seeing those recommended. i may have to try one out.
gonzogolf
Gallery: 559 photos
Nov 09, 2015 10:21 |  #9
TeamSpeed wrote in post #17777325 (external link)
Basically worthless when used off camera. The flashbnender is useful where you can bounce and you want to redirect some of the light forward for fill. But off camera they don't increase the size of light source and the bounce card is inefficient directing most of the light skyward.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Nov 09, 2015 10:27 as a reply to  @ gonzogolf's post |  #10
It shows that it can be bent in about any shape, including a snoot. Interesting idea.
I use a DEMB bounce card on my 580II for weddings, and it worked well enough in about all situations, where I was pretty close. I didn't have any off camera flash stands with me on the last outing however.
gonzogolf
Gallery: 559 photos
Nov 09, 2015 10:30 as a reply to  @ TeamSpeed's post |  #11
I know what they are capable of, I have one and I use it. But if anyone who has one would do empiracle tests they would realize that it's a poor solution for ocf. This falls into the fong, stofen, mini softbox category of things that make you feel like you are doing something but in the long run may even detract rather than help.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 7 years ago by TeamSpeed. (3 edits in all)
Nov 09, 2015 11:27 |  #12
I always use some sort of diffuser, and even though Fong did this 1st comparison, since each shot was consistent, it makes for a pretty good comparison of effects. It sounds like the only issue is what diffuser can be used that won't act like a sail, and is easy to lug around on the flash and stand as you have to move around.
https://www.youtube.co​m/watch?v=9UFGy3F2Suc (external link)
https://www.youtube.co​m/watch?v=3ZstWIk2cTU (external link)
It would be fun just to go out and try to do different things, you can pick up white foam cheaply and you can shape it to about any shape, copying many of the designs of things you can purchase, just to see what the impacts are.
Here is a topic on FM talking about this in the past: http://www.fredmiranda​.com/forum/topic/93119​3 (external link)
mike_311
Gallery: 18 photos
Joined Mar 2011
Post edited over 7 years ago by mike_311.
Nov 09, 2015 11:42 as a reply to  @ TeamSpeed's post |  #13
i have a stofen, small soft boxes, a small 8x12 flash mount modifier, honestly none do much more than a bare flash. if im going to use a modifier, then i may as well use a large one. The problem is that its too much to carry around and work with when its just me.
i more interested in if anyone shoots a bare flash and how good the results are. Do you set the flash to manual a a low power, eTTL, other, etc?
gonzogolf
Gallery: 559 photos
Nov 09, 2015 11:45 |  #14
TeamSpeed wrote in post #17777416 (external link)
If its not big enough to catch some wind, its not big enough to do any good. Bounce cards don't work outside as 80% of your light is lost to the sky. Speedlite are underpowered as it is.
gonzogolf
Gallery: 559 photos
Nov 09, 2015 11:51 as a reply to  @ TeamSpeed's post |  #15
Don't confuse indoor use and outdoor. The Northrup video was all about using different bounce devices. I didn't bother watching the fong video. He has zero credibility.
4,195 views & 7 likes for this thread, 10 members have posted to it and it is followed by 7 members.
off camera lighting
1323 guests, 124 members online
