Thread started 10 Nov 2015 (Tuesday) 11:47
New Mini-ITX build
UKmitch86
Gallery: 15 photos
Joined Jun 2012
Nov 10, 2015 11:47 |  #1
Just wanted to bounce my thoughts around as I'm building a new editing machine to replace the inconvenient system of connecting a laptop to several cables and anchoring it to the desk, only to unplug them all to move away!
I'm putting a machine together into a Silverstone Sugo SG05 case. These have great small footprints, but the parts available now have almost as much grunt as larger ATX sized parts.
Naturally, I'm building a machine primarily to run DPP3, DPP4 (hopefully) and DXO10. I'm handing 1Ds3 raw files, and I'm hoping to build a machine without any noticeable lag.
So far, I've opted for the Intel H170 chipset to use the latest Skylake processors. I did flirt with the idea of building a Xeon machine but the IO and motherboard selection is dreadful which is a shame because I understand they're computationally better than the i5 at the same pricepoint. I'm not going to overclock and won't have space on the MB for a second GPU (not that it's useful in editing anyway) so I won't need the 'enthusiast' level Z170 chipset.
I'm probably going to pick up a basic i5, the 6400 most likely at 2.7GHz.
RAM limitation will be either 32GB or 64GB, so that'll be overkill.
Just need a cheap nvidia card with a displayport out so I'm not connecting to the monitor through an adapter.
I'll pick up a 128GB SSD as the main disk, external storage for the images.
I should think I'll get away with Silverstone's own 450W SFX PSU, but the 600W is supposedly quieter and only £20 extra. Again, overkill, but at least the base is covered.
Canon 1Ds3 | 16-35/4 | 50/1.8 | 135/2
https://www.flickr.com​/photos/ukmitch86/ (external link)
110yd
Joined Jan 2005
Nov 10, 2015 18:03 |  #2
I have been toying with the idea of building something similar. My reasoning has boiled down to the fact that I can build a Media Center type machine that will be able to edit photos as well as play back quickly edited slide shows for events... I think cost wise it might even come out cheaper
that the laptop that offers similar performance.
Regards,
110yd
wunhang
Nov 10, 2015 18:11 |  #3
I'm assuming you're talking USB3 for the external storage? I think that might be the bottleneck in your whole setup.
Canon 5D IV | Canon 5D II | XSI (Infrared modified) | SL1 | 16-35mm L f/4.0 IS | 24-70mm L f/2.8 II | 40mm f/2.8 | 85mm f/1.8 | 70-200mm L f/4.0 IS | Rokinon 14mm f/2.8 | C/Y 28mm f/2.8 | Tamron 35mm f/1.8 VC | C/Y 50mm f/1.7 | Zeiss 100mm MP
::SmugMug (external link)::
mike_d
Nov 10, 2015 19:43 |  #4
wunhang wrote in post #17779196 (external link)
USB 3.0 doesn't bottleneck a hard drive or even a moderately sized array of hard drives. Hard drives just aren't that fast.
110yd
Joined Jan 2005
Nov 10, 2015 20:13 as a reply to  @ wunhang's post |  #5
The motherboard I am considering (Asus Z170 variant) supports USB 3.0, but I don't see a bottleneck regarding external storage. More of a concern to me at the moment is the transfer speed
of the camera which would be tethered, which only supports a USB 2.0 interface. I need to do
some homework to see if the camera tethered with a USB 2.0 interface is an issue speed wise.
Regards,
110yd
wunhang
Nov 10, 2015 21:09 as a reply to  @ mike_d's post |  #6
Sorry... I was stringing along two different thoughts. I was clarifying if the storage was USB3 or network-based (NAS). The other thought is that the read/write on the disk-based drive would likely be the bottleneck.
interlopr
Gallery: 6 photos
Joined Nov 2012
Post edited over 8 years ago by interlopr.
Nov 10, 2015 23:41 |  #7
Why not build an x99 system? It might set you back an extra $100 but you'll get a lot more grunt..
CPU: i7 5820k
Mobo: Asrock X99E-ITX/AC
I just built a itx PC my self for my photo editing and gaming, except I'm using an i7 5960x
As for a power supply, if your case will fit it, Silverstone make a 500w SFX-L, it's a tad longer then a true sfx power supply but you get a 120mm fan and is quieter then both the 450w and 600w.
My 2c
6D - 24L II - 50L - 85L II - 135L
UKmitch86
Gallery: 15 photos
Joined Jun 2012
Nov 11, 2015 09:50 |  #8
110yd wrote in post #17779191 (external link)
Regards,
110yd
I'm planning on having mine as a desktop-based machine, but yes, there are some nice carry-bags for them, and frankly I guess people are less likely to try and steal it above a macbook from an event.
I work locally on an SSD, then transfer back into the slow mechanical external storage. That's the benefit of working with DPP and DXO - the edits are made in the same folder as the original RAW. The desktop storage might evolve into network attached storage, but I won't be doing anything clever with NAS boxes - once bitten twice shy!
interlopr wrote in post #17779467 (external link)
CPU: i7 5820k
My 2c
You're a wealthier man than I am! I have just bought a house though...
The X99 is limited in choice to two Asrock mobos here in the UK - in the grand scheme of things, I prefer not to buy bleeding-edge technology - the cost-benefit relationship is never quite acceptable to me.
I'm quite content with the H170 choice - as mentioned, the Z170 is OTT for me and the X99 (which I hadn't considered) is even more OTT! I have bought a Quadro card since I last posted - I do hope this helps crunch the numbers effectively. It has displayport-out, so I don't have to worry about the connection standard limiting refresh rates and colour palettes.
The PSU is an interesting point - I absolutely want a modular PSU, and I'd settled on the 600W variant - I've no idea whether the SFX-L will fit, but yes the 120mm fan is attractive. I might have to investigate - I can see it's modular so that's one box ticked.
tim
Light Bringer
Nov 11, 2015 14:41 |  #9
USB 3.0 has bandwidth, but I suspect slightly more latency than SATA disks. If you edit from an internal SSD I would probably go with 256GB. Samsung 850 pro (external link) is great, the slightly cheaper evo almost as good.
1,617 views & 0 likes for this thread, 6 members have posted to it and it is followed by 5 members.
New Mini-ITX build
1511 guests, 131 members online
