I’m not a pro in any way, shape or form, but I think I may have come to a crossroad with lighting for product photography & am looking for some advice regards strobe v continuous.
I’m currently using a EOS 70D, EF-S 60 2.8 macro & EF-S 18-55 kit lens with a pair of 70 watt (350 equivalent (apparently)) 5500k CFL’s. Most work is with reflective metal engineering components (many cylindrical) from roughly 1/2cm to 60cm square in size. Everything is done tethered in RAW, & ultimately ends up on a pure white, no shadow background.
The smaller items aren’t an issue, but I don’t seem to have enough light as I move onto larger products where I’m often using bizarrely long shutter speeds & even then have a load of post production to carry out. I don’t know if it’s due to my lack of skill or my current lighting, but I also have issues with DOF, but again only on larger stuff – no matter what adjustments I make & can’t seem to get a balance / reasonable compromise….. (I’m also re-reading Light, Science & Magic). I’m figuring that most these issues are related to light issue rather than technique (?), so please do tell.
I’m utterly confused with the strobe/continuous debate as there seems to be a mass of contradicting info out there. I do like continuous as I’ve got into the swing of using tethered live view & appreciate that there will be a learning curve if I move to strobe, but it’s image quality, improved DOF & a reduction in post processing time that I’m looking for & don’t mind spending the time that may be involved to get strobes working for me.
For continuous I’ve been considering Westcott products & for strobe something along the lines of the Elinchrom D-Lite RX 4/4 set or Lencarta Smartflash 2 or ElitePro 2 kit.
Any advice hugely appreciated.
The best dimmers for higher power tungsten lights are also the heavier, more expensive auto-transformer type (Variacs), not the solid-state duty-cycle kinds used for household lights.
