Thread started 13 Nov 2015 (Friday) 08:28
Can't delete pics off SD card?
mamaof2
Gallery: 10 photos
Joined May 2014
Nov 13, 2015 08:28 |  #1
For some reason I can not delete pics from my SD card off my computer?? I can delete them from the camera though? Thoughts?
Jessi
T4i/Nifty fifty/ 18-55/ DCR 250 macro attachment/ 55-250 stm/ Few old film lenses
Hannya
Nov 14, 2015 06:46 |  #2
Have you 'locked' the SD card - the little tab on the side?
“Your first 10,000 photographs are your worst.” ― Henri Cartier-Bresson
Sports Pics (external link)
DGStinner
Gallery: 24 photos
Joined Jan 2014
Nov 14, 2015 07:19 |  #3
Is it possible you using a card reader which doesn't allow write access? You would need write access in order to delete a file. I prefer to format the card in the camera instead of selective deleting.
mamaof2
Gallery: 10 photos
Joined May 2014
Nov 14, 2015 07:39 |  #4
I thought I have deleted from this card b4 that is what is so weird.
(I also made sure the SD card was not locked)
Jessi
hidroela
Gallery: 40 photos
Joined Jul 2014
Nov 14, 2015 09:33 as a reply to  @ mamaof2's post |  #5
If you can move the contents on it to another place. Try to format the card.good luck.
Pérez
GEAR
mamaof2
Gallery: 10 photos
Joined May 2014
Nov 14, 2015 19:40 as a reply to  @ hidroela's post |  #6
I was able to put them into a folder just not delete. I got them all burnt onto a DVD and reformatted the card in the camera.
Jessi
hidroela
Gallery: 40 photos
Joined Jul 2014
Nov 15, 2015 07:21 as a reply to  @ mamaof2's post |  #7
After that did you try to delete any file on the card.
Pérez
GEAR
DGStinner
Gallery: 24 photos
Joined Jan 2014
Nov 15, 2015 07:48 |  #8
Try and put a file on the card. If that doesn't work, you have a card reader with no write capability. If you can't write to the card, you can't delete from the card.
Bassat
"I am still in my underwear."
Joined Oct 2015
Nov 15, 2015 07:56 |  #9
SD cards are cheap. Buy a new one. At worst you have a spare.
birderman
Joined Mar 2011
Nov 23, 2015 09:10 |  #10
I posted about this in the computers thread, sounds like a similar issue.
Everyone automatically jumps on the bandwagon suggesting the the Write Lock is On or the card is faulty and new one should be purchased or the card needs to be formatted. In my experience they are all wrong and it is actually an OS issue, the solution that I found works is to uninstall the card reader driver from the PC then re-install it. It seems to be an issue with Windows 10 and possibly 8.1. I know it's not the card because the issue has happened on one PC but not another PC, surely if the SD card was faulty then it would be apparent on all PCs.
Windows 10 has just done a big upgrade, will need to see how this performs now hopefully they have corrected the issue even though it has been difficult to find proof that it is windows problem.
HTH
Birderman
London, UK
my photos on Flickr (external link)
My Website (external link) or my Facebook - KishWphotos (external link)
ansicy
Joined Aug 2015
Nov 26, 2015 05:51 |  #11
maybe u locked the card.check it .it is a little bottom on the left.or,your card was broken.buy a new one.lol
birderman
Joined Mar 2011
Dec 03, 2015 08:37 |  #12
ansicy wrote in post #17797194 (external link)
As in my previous post NO ....
Birderman
London, UK
vraspagraphix
Dec 03, 2015 11:00 as a reply to  @ birderman's post |  #13
Most of the time when someone ask me about this type of problem it is usually because they altered images on the card in their computer. Try formatting the card first and then put it in your computer and erase anything left on the card. When using sd cards it is always best to just drag your files to the desk top and then remove the card. Do not work with the card in the computer if you are going to use it in a camera. Also if you put the files in a folder on the sd card , take them out.
birderman
Joined Mar 2011
Dec 04, 2015 07:36 |  #14
Since the 1511 Windows 10 Update the issue has corrected itself on my system.
Although there may be instances where others are correct and people are having problems due faulty cards, lock switch in wrong position etc. The problem shows as delete option not being available from Windows explorer... THERE IS DEFINITELY an issue with PCs with built in Card Readers and Window 10 OS (and probably Windows 8), Google reveals many such instances but no accurate reliable resolution - which IMO points to a buggy OS and or driver interface - whether this is compatibility between driver and OS or a bug in the third party driver or the OS itself has not yet been proven and no information has been found on the internet yet.... So if all other issues have been tested and negated then it would appear that the only solution is to reinstall the driver software or wait for the OS and or Driver to be fixed....
Birderman
London, UK
3,857 views & 1 like for this thread, 8 members have posted to it and it is followed by 2 members.
1090 guests, 119 members online
