Tamron makes their own telwconverter. And then there is a canon. The tamron is way cheaper. Anybody use the tamron? I would love to get it at that price and have sharpness rather than buy the expensive canon.
Regards
Nov 13, 2015 14:33 | #1 Tamron makes their own telwconverter. And then there is a canon. The tamron is way cheaper. Anybody use the tamron? I would love to get it at that price and have sharpness rather than buy the expensive canon. _______________
crofter Senior Member More info Post edited over 8 years ago by crofter. | Nov 13, 2015 14:49 | #2 The Canon one won't fit,the Tamron is a rebadged Kenko (I had one),the results were not good on that lens. http://www.flickr.com/photos/70718847@N02/
Nov 13, 2015 15:20 | #3 Thanks for the reply. Weird, because mine is very sharp otherwise. _______________
The lens is sharp,I have one but the teleconverter does it no favours,you loose a stop or two of light and IQ and depending on your camera autofocus as well, the Tamron teleconverters appear to be the older lower specced Kenkos, I don't think Tamron sell them any more. http://www.flickr.com/photos/70718847@N02/
PIXPHATIC Senior Member More info | Nov 15, 2015 21:00 | #5 The lens is superb by itself.My friend used to have it.I have the Kenko 300 Pro DGX 1.4 X TC,which once was mounted on it.He tried the 'less expensive' way to go to 400+mm reach,but after a single outing dropped the idea.Later went ahead with the Canon 400f5.6. Photography my religion,World my Tabernacle.
MalVeauX "Looks rough and well used" More info Post edited over 8 years ago by MalVeauX. | Nov 16, 2015 05:30 | #6 Frodge wrote in post #17782656 Tamron makes their own telwconverter. And then there is a canon. The tamron is way cheaper. Anybody use the tamron? I would love to get it at that price and have sharpness rather than buy the expensive canon. Regards Heya, Very best,
Why won't the canon teleconverter fit? BTW malveaux, moon shots and slow moving or non moving objects is what I'd use it for. Not a bird in flight guy. Any recommendations on which one? _______________
Nov 19, 2015 10:13 | #8 It's got a big lump that sticks out of the front. http://www.flickr.com/photos/70718847@N02/
I thought the tamron was designated EF... _______________
MalVeauX "Looks rough and well used" More info | Nov 19, 2015 19:12 | #10 Frodge wrote in post #17789674 I thought the tamron was designated EF... Third party lenses are EF mount. Even if designed for APS-C, they're still EF mount. They will fit and work with teleconverters unless physical limitations (like protruding, etc). On some zooms, the rear element will drop backwards into the TC and hit it, making it physically impossible. Primes are a lot easier to use teleconverters on. That and large telephoto zooms (not wide angles). Frodge wrote in post #17789598 Why won't the canon teleconverter fit? BTW malveaux, moon shots and slow moving or non moving objects is what I'd use it for. Not a bird in flight guy. Any recommendations on which one? Great shot BTW....the tamron has great is BTW. Virtually any non-Canon will work for you. Canon's are picky. Kenko, Sigma, Tamron, etc, they will work. They may not report. But they will work. The Kenko is what I use, because it doesn't care what's plugged into it, it will pass on electronics and work even on ancient stuff, and new stuff, from any maker. Sharp too.
Nov 19, 2015 19:45 | #11 Thanks. I'm going to check that out! _______________
CyberDyneSystems Admin (type T-2000) More info | Nov 19, 2015 20:45 | #12 Might want to check this out; GEAR LIST
Talley Talley Whacker More info Post edited over 7 years ago by Talley. | Nov 19, 2015 23:01 | #13 Just shot the moon. F11, ISO 400 1/125 using a Tamron 70-300VC at 300mm w/ a 1.4x Sigma TC. Image hosted by forum (760265) © Talley [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. A7rIII | A7III | 12-24 F4 | 16-35 GM | 28-75 2.8 | 100-400 GM | 12mm 2.8 Fisheye | 35mm 2.8 | 85mm 1.8 | 35A | 85A | 200mm L F2 IS | MC-11
| Latest registered member is semonsters 1294 guests, 135 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
