Thread started 16 Nov 2015 (Monday) 19:01
Lightroom Sharpen Mask "Look..."
Moonshiner
Joined Jul 2013
Nov 16, 2015 19:01 |  #1
I don't know how to describe it other than the title...
In Lightroom, when you hold down the ALT button and drag the masking slider over, the image is converted to a black and white line/edge rendition of the image. Obviously, this is to allow you to see the edges for sharpening...
My question is this, how can I duplicate the visual of this mask? What filter or action in PS CC 2014 (assuming LR 5.7 cannot do this natively) can I use to recreate this "look?"
Thanks!
BigAl007
Gallery: 556 photos
Nov 17, 2015 02:59 |  #2
In PS you would need to first run the Find Edges filter, then desaturate it. If you are going to use it in PS to mask a sharpening filter then you copy the original layer and then just working in the alpha channel paste it in, it will be monochrome already when you do this, so just run Find edges.
With the edges image you then need to run a Levels command (Ctrl L). You will need to bring both ends inwards to make the lines more defined. I usually use 192/.10/230 as my starting point when making an edge filter for a highpass sharpening layer. I also usually keep everything as black on white until the end of the process, then invert to black in white at the end using Ctrl I.
If you look in the Sharpening sticky above there is a really good tutorial on this, with lots of example images. Although aimed at edge sharpening I also like the effect you get from doing this in colour as a layer over the original using the Soft light blend mode. You get a kind of watercolour effect but with a defined almost drawn outline. If you do that as well as keeping it in colour, don't go nearly as far with the sliders in the Levels operation, and don't invert at the end.
Alan
Moonshiner
Joined Jul 2013
Nov 17, 2015 09:34 as a reply to  @ BigAl007's post |  #3
I wasn't looking to use this to sharpen... I just like the inverted black and white effect...
Thanks for this... I will give it a try!
Moonshiner
Joined Jul 2013
Nov 18, 2015 09:45 as a reply to  @ BigAl007's post |  #4
This was perfect.. Exactly what I was looking for... Thanks again!
1,221 views & 0 likes for this thread, 2 members have posted to it.
1514 guests, 131 members online
