Thread started 17 Nov 2015 (Tuesday) 17:05
Batteries and YN600EX-RT
rebop
Nov 17, 2015 17:05 |  #1
Just got my first of these flashes to try out and I'm impressed. However, I was very surprised at a card in the battery slot saying Alkaline or NiMH only. no Li-ion batteries! I am SURE I have seens others using Eneloops in posts maybe here, but definitely in some of the forums. It was one of the many reasons I considered these.
Any idea why its not recommended and what to do? They seem to work just fine.
~Bob
I'm Bob and I'm an L-coholic
R3 - RF 14-35
L - RF 24-70 L - RF 24-105 L - RF Thrifty-Nifty 50
RF 70-200 2.8 L - EF 70-300 L - EF 100 2.8 L Macro
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Post edited over 8 years ago by gonzogolf.
Nov 17, 2015 17:07 |  #2
Eneloops are nimn. Li-ion's can get hot enough to melt a flash. Canom recommends against them as well.
rebop
Nov 17, 2015 17:13 as a reply to  @ gonzogolf's post |  #3
Really? Eneloops are no Li-ion? I need to go read and check then. Thanks for the pointer.
Just checked: They do not say anywhere on the battery what they are. I think I just assumed. Will Google for more info.
Thanks again.
R3 - RF 14-35
gonzogolf
Gallery: 561 photos
Nov 17, 2015 17:26 |  #4
What made eneloops special was the low self discharge rate and general quality.
absplastic
Gallery: 40 photos
Post edited over 8 years ago by absplastic.
Nov 18, 2015 13:32 |  #5
I think there is some confusion here about batteries, Lithium disposables and Li-ion rechargeables are different beasts. Lithium AAs are not recommended for use in speedlites, because these are the ones that get hot.
Li-ion rechargeables work great powering flashes but they are not readily available in AA form factor because they have a cell voltage of 3.6V. There are some very specialized Li-ion AA batteries that have combination of battery plus internal voltage regulator to achieve 1.5V, but these are not common, affordable, or right for this application.
There are Li-ion external battery packs that can be used with the YN600ex-rt, but they are external. Example: http://www.bhphotovide​o.com …pp_310_compact_​power.html (external link)
5DSR, 6D, 16-35/4L IS, 85L II, 100L macro, Sigma 150-600C
SL1, 10-18 STM, 18-55 STM, 40 STM, 50 STM
My (mostly) Fashion and Portraiture Instagram (external link)
flickr (external link) (NSFW)
Lyndön
Nov 18, 2015 20:57 |  #6
^ ouch! $300 for an external Li-ion pack. I think I'll stick to eneloops, lol.
drmaxx
Gallery: 41 photos
Nov 19, 2015 00:36 |  #7
absplastic wrote in post #17788722 (external link)
Li-ion rechargeables [...] have a cell voltage of 3.6V.
^THIS!
Eneloop are NiMH and will work in most cases just fine as replacements for alkaline. It is fairly easy to get Li-ion in AA form factor (they have a different name though) but they have a different voltage (3.6 - 4.2 V instead of 0.9 to 1.5 V) and should be never used as replacement for alkalines.
Donate if you love POTN
Echo63
Nov 19, 2015 01:17 |  #8
Eneloops (and other rechargebles, both NIMH and NiCad flavours), Alkalines and Lithium (Energizer L91 etc) are all around 1.5 v per cell (rechargeable a bit lower at 1.2 and Lithium higher at 1.7)
most products can tolerate the slightly lower or higher voltage, though some devices will get a bit hot.
Lithium Ion are rechargeable cells, and are available in in a AA size (normally known as a 14500**)
these are nominally 3.6v - but range from 4.2v fresh off the charger to 3.2v when fully discharged.
using them in a device not designed for them will result in it being damaged.
**Lithium ion cells are named by size in mm, the first two numbers are the diameter, the second two are length, and the last 0 means its a cylindrical cell - so a AA sized cell "14500" is 14mm by 50mm, cylindrical cell - a CR 123 sized Lithium Ion is a 16340 - 16x34mm
My Best Imageswww.echo63.deviantart.​com (external link)
Gear listhttps://photography-on-the.net …p?p=2463426&pos​tcount=385
Oldschool1948
Joined May 2012
Nov 23, 2015 17:54 |  #9
Just received my first YN600EX-RT from B&H. I put in Eneloop model HR 3UTGB 1.2V batteries and took a few test shots and got weird color casts in my shots - mostly blue sometimes yellow. I put in regular non-rechargeable batteries and everything works fine. Anyone else experience this?
I have about 36 Eneloops that I sure hope I can use with this flash. I just sold one 580EXII; am trying to sell my 430EXII; and if this flash works OK, I had planned to sell my last 580EXII. Now I may have to rethink things. This is a hobby, so buying Canon 600EXs is out of the question.
5DIII Gripped
AD360 | Canon 600EX-RT (x2) | 580EXII | L358
70-200 f4L IS | 24-70 f2.8L II | 50 f1.8 mk I | Tamron 150-600 G2
Canon Pro-10 Printer | Adobe LR6 | OnOne Raw
gonzogolf
Gallery: 561 photos
Nov 23, 2015 18:06 |  #10
Oldschool1948 wrote in post #17794419 (external link)
I'd throw the eneloops back in for a second go just to eliminate the possibility that the first shots were due to some breaking in period.
Oldschool1948
Joined May 2012
Nov 23, 2015 18:27 as a reply to  @ gonzogolf's post |  #11
I did with the same result. The battery indicator is about 3/4 full. I'm going to put in a newly charged set and see what happens.
5DIII Gripped
Echo63
Nov 23, 2015 19:06 |  #12
You arent shooting indoors under tungsten light and seeing bits of your frame illuminated by the flash and bits by the tungsten ?
Oldschool1948
Joined May 2012
Nov 23, 2015 19:59 as a reply to  @ Echo63's post |  #13
I am shooting indoors, but the entire frame has a weird blue color cast.
When I use eneloops with the YN600, I consistently get a weird blue color cast
When I use the same eneloopes in my Canon 580EXII, no problems
When I use regular batteries in the YN600, everything works fine every time
I'm sending it back to B&H. If the next one does the same, then I'll buy some other RT system
I also ordered two YN receivers and the YN transmitter. So, I really want this to work :-)
5DIII Gripped
Oldschool1948
Joined May 2012
Nov 28, 2015 20:55 as a reply to  @ Oldschool1948's post |  #14
Received a new YN600. Using eneloops now with no issues :lol:
5DIII Gripped
Lance ­ Pecchia
1 post
Jul 09, 2017 15:03 |  #15
I get a blue cast when using theYN600EX-RT. I used fully-charged Powerex batteries. I put the same batteries in my Canon 600EX-RT and get the normal, warmer, results. So, it's not the batteries that are at fault in this case. I can compensate later in Lightroom for this but...
My previous Yongnuo 600 EX-RT was blue also, then stopped flashing. I'd better mention that long ago my Canon 580 Ex stopped flashing also. That's when I went with the Canon 600 series.
I wanted to stop paying almost $500 for a Speedlight and thought I'd try the Youngnuo route.
6,171 views & 0 likes for this thread, 8 members have posted to it and it is followed by 5 members.
1503 guests, 130 members online
