This lady is past her prime and I was too cheap to replace her just yet...
Anyhow, I applied some funky lighting using my, adjustable colors, LED lights.
Then stacked and merged to 40"
Nov 19, 2015 08:13 | #1 This lady is past her prime and I was too cheap to replace her just yet... The things you do for yourself die with you, the things you do for others live forever.
MartinDixon Slit-scan project master More info | Nov 19, 2015 14:21 | #2 Not sure I understand the "40 inches" bit? flickr
TeamSpeed 01010100 01010011 More info Post edited over 8 years ago by TeamSpeed. (4 edits in all) | He isn't stacking them (or only stacking them), he does the "panoramic dance", ie. he takes a ton of shots in a spiral or grid format and merges them to get a result as if he used a high resolution camera. The merging is causing the effects you are seeing. Past Equipment | My Personal Gallery
k4j98 Member 92 posts Likes: 26 Joined Dec 2013 More info | Nov 19, 2015 14:52 | #4 TeamSpeed wrote in post #17789885 I will point you to this "fun" post: https://photography-on-the.net …showthread.php?p=17775358
TeamSpeed 01010100 01010011 More info Post edited over 8 years ago by TeamSpeed. (2 edits in all) | I hope not, at least not until all the stairstep effects have been blended out, and the ghosting/chromatic effects on the edges of the outer petals are addressed. Once those were taken care of, it would be a nice print. Past Equipment | My Personal Gallery
MartinDixon Slit-scan project master More info | Thanks for explaining! flickr
Nov 19, 2015 15:45 | #7 I haven't been that successful using roses with the "stack and merge technique"...not sure why. The things you do for yourself die with you, the things you do for others live forever.
don1163 Goldmember More info | Nov 19, 2015 16:45 | #8 chauncey wrote in post #17789976 I haven't been that successful using roses with the "stack and merge technique" I wouldn't have guessed 1DX, 500L f4, 70-200L f2.8II, 100L f2.8 macro ,16-35 f4, 1.4xIII, Metz 64-AF1
| Latest registered member is semonsters 907 guests, 119 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
