Thread started 24 Nov 2015 (Tuesday) 11:00
Need a flash meter - seeking advise.
javapop
Gallery: 13 photos
Nov 24, 2015 11:00 |  #1
What is a good starter flash meter? I have a 580EX2 and a 270EX2 and Yongnuo YN-622C triggers. I would love to be able to trigger the flash while standing next to the subject, vs having them hold it. Or is that a biggy?
Sony A7r2|24-70 f/4 FE|85 1.8 FE|28 f/2 FE|Venus Laowa 15mm f/2|Habakkuk 2:2 (external link)|
instagram (external link)David.Stembridge.us (external link)
DunnoWhen
Nov 24, 2015 15:24 |  #2
Sekonic L-358.
Use the 622 from the camera (or a spare) to trigger the lights.
My wisdom is learned from the experience of others.
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Nov 24, 2015 15:35 |  #3
DunnoWhen wrote in post #17795486 (external link)
Sekonic L-358.
this is my solution. I dropped my previous meter which smashed it to pieces, then bought the 358. As long as you don't have a cup of coffee, or a beer in one hand, you can hit the test button on your trigger while holding the meter in the other hand.
i think i picked mine up on the for sale pages here for $180. If you see one come up for sale, act immediately, they go fast.
absplastic
Gallery: 40 photos
Nov 24, 2015 19:13 |  #4
I have the L-478D which is I think the update to the one being recommended to you. The touchscreen is blessing and curse: nice big easy-to-read display, but also a bit too easy to accidentally change settings when holding it or putting it in your pocket. You have to be careful when you look at the reading and make sure you haven't changed the ISO or shutter speed just by handling the meter. I normally just pop the strobes with the test button right from whatever trigger I'm using.
5DSR, 6D, 16-35/4L IS, 85L II, 100L macro, Sigma 150-600C
SL1, 10-18 STM, 18-55 STM, 40 STM, 50 STM
My (mostly) Fashion and Portraiture Instagram (external link)
flickr (external link) (NSFW)
javapop
Gallery: 13 photos
Nov 24, 2015 20:17 |  #5
Thanks folks. I tried out the L-308DC a couple years ago; but it was before the current flashes. I had a 285HV at the time. Is the L-358 really going to be better than the L-308DC? Price is about the same well, on the used L-358
Gallery: 15 photos
Joined Jun 2011
Nov 25, 2015 04:54 |  #6
javapop wrote in post #17795783 (external link)
not a huge difference between the two
http://www.sekonic.com …/all/comparison​chart.aspx (external link)
javapop
Gallery: 13 photos
Post edited over 7 years ago by javapop. (2 edits in all)
Nov 25, 2015 07:52 |  #7
Left Handed Brisket wrote in post #17796132 (external link)
I read that the 358 could do measurements of mixed ambient and flash; but the 308 can't.
http://www.fredmiranda​.com/forum/topic/78232​7 (external link)
Gallery: 15 photos
Joined Jun 2011
Nov 25, 2015 07:59 |  #8
javapop wrote in post #17796213 (external link)
yup, pretty sure that is the "Flash Analysis" feature.
SkipD
Joined Dec 2002
Post edited over 7 years ago by SkipD.
Nov 25, 2015 08:18 |  #9
That is correct.
The L358 can also accept adapters to make it be a true spot meter (for reflected light only). I use the 1° adapter. In addition, 5° and 10° adapters are/were available as well.
Skip Douglas
RicoTudor
Joined Jul 2014
Nov 27, 2015 14:06 |  #10
L-308 integrates ambient light just fine. Just set the shutter speed on the meter before the flash reading.
Canon, Nikon, Contax, Leica, Sony, Profoto.
SkipD
Joined Dec 2002
Nov 27, 2015 14:50 |  #11
RicoTudor wrote in post #17798485 (external link)
I'm pretty sure that what javapop was referring to is that the Sekonic L358 meter can show you a ratio of flash-sourced light to continuous light in the scene that it is measuring. It does this for each reading it makes that include flash and continuous light.
To the best of my knowledge, the L308 meter cannot do that at all.
Skip Douglas
RicoTudor
Joined Jul 2014
Nov 27, 2015 17:42 as a reply to  @ SkipD's post |  #12
Ah, true, the so-called flash analyzing function is absent from the 308.
windpig
Chopped liver
Post edited over 7 years ago by windpig.
Nov 28, 2015 06:27 |  #13
I'm probably odd man out, but I was never enamored with the L358. It was bulky and the ambient\flash feature wasn't accurate enough for me. I found chimping for ratios is much more to my liking. I would go with a simpler model.
Go ahead, spin the wheel.
Wilt
Post edited over 7 years ago by Wilt. (9 edits in all)
Nov 28, 2015 10:23 |  #14
windpig wrote in post #17799079 (external link)
I have always been puzzled by the need for the ability to see flash:ambient in ratios as precise as 10% increments (which Sekonic flaunted in its advertising/literature to differentiate themselves from Minolta, who they were trying to catch up with in the marketplace 30 years ago), using the L358. The Minolta meters with ratio capability do so in 25% increments (and Minolta never particularly boasted about the capability), and like you, windpig, I have simply not used the function at all. Neither approach has a particular inherent advantage (or use!). For others reading this thread, think about this...
  1. 1:1 shows 50%:50%
  2. 1:2 shows 33%:66% ('low contrast' per traditional portrait lighting texts)
  3. 1:3 shows 25%:75% ('medium contrast' per traditional portrait lighting texts)
  4. 1:4 shows 20%:80%
  5. 1:5 shows 17%:83% ('high contrast' per traditional portrait lighting texts)
  6. 1:6 shows 14%: 86%
  7. 1:7 shows 12.5%:87.5%
#1 is flat lighting, so really no one ought to ever WANT to achieve that. So the L358 only has one ratio that has any value (1:4), while Minolta has one ratio that has any value (1:3), and of the two the portraitist really uses the 3:1 ratio setup mostly, since simply distance of light-to-subject allows this to be easily set in the studio (rendering the ability to meter this easily to be rather pointless). In fact, all can be very simply set with source distances in the studio and the need to meter these is rather superfluous.
So back to the OP question, the ability to change a flashmeter from an incident to a reflected spotmeter is a nice capability to have, for a commercial photographer, but is not really 'necessary' for a home portraitist. Whether the spot metering capability (in reflected mode) is 1 degree vs. only 5 degrees is not particularly beneficial in the studio where measuring distances can easily be made very short...the need for one degree AOV is more useful in an outdoor ambient metering context due to the longer shooting distances that are typical.
windpig
Chopped liver
Nov 28, 2015 11:02 |  #15
Wilt wrote in post #17799279 (external link)
For me it's shooting with the flash as fill and dialing pretty close to flat for what I've been trying to achieve. I said screw it and set up the picture style such that I get a pretty accurate depiction of contrast.
3,880 views & 0 likes for this thread, 10 members have posted to it and it is followed by 4 members.
1029 guests, 109 members online
