BLD 25 wrote in post #17795794
Hey, everyone, considering all of the good deals Canon has going, I am thinking about upgrading. My wife and I like the T1i, and have some pretty good glass (40mm pancake, 50 1.8, Sigma 17-50 2.8 HSM). The sigma was a nice upgrade from the 18-135(non STM), and we aren't really limited too much by the camera. Better low light would be nice, video capabilities(the T1i is pretty crude by today's standards), better AF, newer sensors, etc would all be nice. But, how much would the upgrade actually be? We could probably sell the T1i and 18-135 lens for close to what it would cost to get the SL1, and even the T5i wouldn't cost too much more than that. From everything I have been reading on many review sites and forums, is that the main advantage of the T5i is the 9 cross AF sensors, but I am not sure how much that matters. My wife says that if we upgrade, she wants it to be worth it(70D territory), but she is also cheap and doesn't want to spend the money.
The SL1 is so cheap though!
Any thoughts from people who have spent some time with many of these cameras?
thanks
Heya,
While technically it is an upgrade, the final output may not be any different realistically, making it potentially not worth it in a real world upgrade sense. You're not getting much of an increase in resolution to really make an impact with that. You are getting some better higher ISO usability, but this doesn't mean it automatically is better in low light, it still requires you shoot with a technique of high ISO use in mind (exposing to the right) and using good post processing to clean it up. It will have about the same AF frankly. And having a few more cross type AF points sounds great on paper, but it depends on if you use them or not, or if you're even telling the camera what to even use or leaving it in automatic selection mode, where it just has all points available and in use and it decides what to focus on, or if you're manually telling which focus point to use where you'll take more advantage of having those extra cross type points for improved non-center point focus. If you're letting the camera choose everything, mostly automatic use, then no, it will not be much of an upgrade frankly.
The SL1 is cheap for a reason. It's a decent enough camera, but it's truly very small, can't take a grip, no swivel screen, isn't any more modern than a T3i, and is really just barely a one step upgrade for you from your T1i. The T1i is a fine camera by the way.
If you really wanted a true upgrade, I would consider a lot of other options. A 70D refurb makes the most sense if you want an actual upgrade in every way, and not just an insignificant upgrade, but one that has substantial effect on the output even if you don't change your shooting habits or skill (mind you, it can still take a bad photograph... they all can). But it has the resolution, much improved AF, much much much improved build quality, other accessories/features like the screen, Wifi, MFA (this is huge if you get into fast or long glass), has modern video capability, and significantly better high ISO performance.
What you shoot, actually is more important to know.
And what you want out of the camera is more important to know (other than "low light" and "video"). Something more specific.
If you're not camera limited now, then I would definitely consider carefully if you really need a new camera.
Very best,
