Thread started 25 Nov 2015 (Wednesday) 14:53
Today's work: a lollipop and a violin
atsilverstein
Gallery: 46 photos
Joined Mar 2015
Nov 25, 2015 14:53 |  #1
I'm probably starting to annoy the critique forum, but oh well.
From today.
More experiments with lighting.
#1 I know the light from the window is blown out but I don't know if there's a way to adjust for that in-camera or if I just shouldn't shoot in front of windows like this.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/11/4/LQ_761191.jpg
Image hosted by forum (761191) © atsilverstein [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/11/4/LQ_761192.jpg
Image hosted by forum (761192) © atsilverstein [SHARE LINK]
It matters not how strait the gate, How charged with punishments the scroll. I am the master of my fate: I am the captain of my soul.
- William Ernest Henley
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Post edited over 7 years ago by MalVeauX.
Nov 25, 2015 15:30 |  #2
Heya,
I assume you used flash in the first one? If so, just note that when using lighting, you're doing two exposures in one. Ambient & subject are separate.
With a portrait, your lighting is exposing the subject, and your camera is exposing for ambient light. So in your first photo, if you want to not blow out a window or ambient light in general like you did there, then you adjust camera settings for ambient exposure. You will find you either need to stop down aperture significantly against a bright sunny window (which you may not want to do, if you're trying to keep a thin depth of field look), or you have to employ things like high speed sync flash so that your shutter brings down ambient light, or use an ND filter to drop all light while keeping aperture open. Keep your sync speed on your camera (unless using HSS), and just adjust aperture & ISO for ambient light. Again, you could apply a ND filter to further drop ambient light without closing down aperture. Your flash power level is now your exposure for your subject, raise that to whatever it takes. Camera to ambient light. Flash to subject light. Also when mixing flash & ambient, you have to note that they're different temperatures of light often (flash is cold). It's a good idea to get a 1/4, 1/2, etc, CTO gel for your flash.
In your first, photo, you used ISO 500. But why? By doing that, you raised ambient light by over 2 stops (leave it base ISO 100 if you want to drop ambient exposure), and that contributed to blowing out the window exposure. Let your lighting expose the subject. Camera settings expose ambient.
Very best,
bob_r
Gallery: 24 photos
Nov 25, 2015 16:06 |  #3
You might try turning her towards the window. Window light is usually very soft and that's the type of light we often try to duplicate with flash.
Canon 7D, 5D, 35L, 50 f/1.4, 85 f/1.8, 135L, 200L, 10-22, 17-55, 70-300, 100-400L, 500D, 580EX(2).
Sigma 150 macro, 1.4X, 2X, Quantaray 2X, Kenko closeup tubes, Yongnuo YN685(3), Yongnuo YN-622C-TX. Lots of studio stuff.
** Image Editing OK **
atsilverstein
Gallery: 46 photos
Joined Mar 2015
Nov 25, 2015 16:23 |  #4
I actually didn't use flash in the 1st one since I didn't want to do another bounce flash. Bouncing the flash off the ceiling (my flash doesn't move side to side) seems to give me enough exposure, but it also "floods" my subject with light everywhere (it's a small room). I wanted to get some soft shadow to shape her face and I literally only have the flashhead for lighting as of now, so I thought I'd put her in front of the window like that to utilize it for lighting from behind. It’s a tight space right there so not possible to put her facing the widow (I'd be outside of my house). The best I can do is have the widow light on her from a front angle, but then there's no space for another light source besides the flash on the camera, which defeats the purpose.
atsilverstein
Gallery: 46 photos
Joined Mar 2015
Nov 25, 2015 16:24 as a reply to  @ MalVeauX's post |  #5
Thank you for your comments.. lots of things to think over now.
Martin ­ Dixon
Slit-scan project master
Gallery: 59 photos
Joined Sep 2009
Nov 26, 2015 06:02 |  #6
I still think the biggest jump in quality of my photos was buying a (cheap!) cable so I coulld hold my flash off the camera. Then you can point it where you like - I also use a "flashbender" so I can get some slightly softened light directly as well as ceiling bounce. The flashbender is very simple and portable.
flickr (external link) Editing OK (external link) www.slitcam.com (free slit-scan utility) (external link)
atsilverstein
Gallery: 46 photos
Joined Mar 2015
Nov 26, 2015 13:33 |  #7
Reshoot of her in front of the window, partially cloudy sky.
How does the wb look overall? I probably processed it too quickly, otherwise I would've kept playing around with it. But it’s not too far off from the raw.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/11/4/LQ_761324.jpg
Image hosted by forum (761324) © atsilverstein [SHARE LINK]
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Nov 26, 2015 14:21 |  #8
I'm going to be blunt partly because I'm on my phone, and partly because I am just that way. If you want I will come back and fill in the gaps. But reflect on these shots and ask some questions
You seem to be getting comfortable with the technical aspects of your camera and photography. It's time to start looking at light. I'm not talking about just the light coming through the the lens, but light everywhere. If you can see it with your eyes it will come through in the photo, I promise.
"By a window" is not a sufggestion for a background, it is a suggestion for seeing the quality of light falling on the subject. The image you posted has zero window light falling on your little girl. It is all the room light.
Start looking at light falling on your subject without the camera and do it all the time. Compare a lightbulb to window light to outside under a tree, WITHOUT A CAMERA. Just look at the light and the shadows it creates.
Cheers.
atsilverstein
Gallery: 46 photos
Joined Mar 2015
Post edited over 7 years ago by atsilverstein.
Nov 26, 2015 14:36 as a reply to  @ Left Handed Brisket's post |  #9
Thanks for the feedback. I think I see what you mean. The window lighting is not sufficient. But just to be cheeky, the entire right side of her hair is lit up from behind at an angle by a ray of sun (albeit too weakly, from what it sounds like). Also there is no lightbulb being used, I aimed my flash behind me against part of a wall.
I guess the main reason for reshooting (it's not a strong composition) was to match the ambient light to the additional light, as it was pointed out there was a mismatch in lighting in the first one. And also to not have the sky blown out.
One thing at a time, right? :-)
Gallery: 15 photos
Joined Jun 2011
Nov 26, 2015 17:31 |  #10
The first goal is always to put your subject in the best light. Always.
If you can balance the back lighting situation that's great but you are pretty obviously in a small room and bouncing a flash around will usually result in flat light that gives no dimension to the face.
The window light can be sufficient given the right angle and exposure settings. ISO 100 won't get you there.
Lemme watch the rest of this terrible game and I will post an example of what I am talking about.
Gallery: 15 photos
Joined Jun 2011
Nov 26, 2015 18:11 |  #11
I had some continuous lights set up for some focus testing, this set up lent itself to some easy examples taken with my phone. Here they are.
First light on the right emulates backlight from the window. Light on the left is a bounced flash. You can see my buddy Jethro Hedroom on the right.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/11/4/LQ_761355.jpg
Image hosted by forum (761355) © Left Handed Brisket [SHARE LINK]
Next is from what would be the real camera position. Light from the front and rear are basically balanced but the result is flat light on the subject.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/11/4/LQ_761356.jpg
Image hosted by forum (761356) © Left Handed Brisket [SHARE LINK]
Gallery: 15 photos
Joined Jun 2011
Nov 26, 2015 18:21 |  #12
So now I turn off the bounced "flash" on the camera and just leave the "window light.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/11/4/LQ_761357.jpg
Image hosted by forum (761357) © Left Handed Brisket [SHARE LINK]
So now I turn the subject and move the camera. The window light now gives depth to the subject. Rather than Max's head being flat, the difference between light and shadow gives depth to his beautiful bald head.
Where flash might come into play is if the difference between light and shadow is too great for your taste. One would balance a bounced or even direct flash to give detail to the shadow side.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/11/4/LQ_761358.jpg
Image hosted by forum (761358) © Left Handed Brisket [SHARE LINK]
atsilverstein
Gallery: 46 photos
Joined Mar 2015
Nov 26, 2015 18:22 as a reply to  @ Left Handed Brisket's post |  #13
Thanks! This was very helpful!
Gallery: 15 photos
Joined Jun 2011
Nov 26, 2015 18:31 |  #14
You're welcome.
Watch light all the time. It is kind of a sickness for me. I watch movies and look for light sources. I drive, walk and sit while trying to see how direct light, bounced and other ambient interact.
You don't need a camera to practice seeing light.
Gallery: 15 photos
Joined Jun 2011
Post edited over 7 years ago by Left Handed Brisket. (2 edits in all)
Nov 26, 2015 19:00 |  #15
just remembered this awesome resource.
read it and the next few pages about phase angle
http://www.clarkvision​.com/articles/lighting​.part3/ (external link)
background music :D
3,820 views & 11 likes for this thread, 7 members have posted to it and it is followed by 2 members.
1025 guests, 108 members online
