memo90061 wrote in post #17801333
Hello!
I just bought a Canon SL1 because I saw a really good deal on Craigslist, and I'm coming from micro four thirds.
I want a fast and semi wide lens for my SL1. I bought the Canon 24mm F2.8, and I like it. I just wish it was faster. I usually shoot wide, and thought about the Sigma 30mm F1.4. I think I would be good with that. Are there any other lenses you would recommend that would still make the SL1 lightweight?
Heya,
Basically no. Anything fast, will be big. Anything light weight, will be slow.
If you want smaller, faster, lighter, and still APS-C, there is the EOS-M (M3) & 22mm F2. That thing is small and fast and sharp.
The 30 F1.4 and 28 F1.8 flavors are the fastest options that are not huge for an APS-C that are relatively wide and quite fast.
There's also the Yongnuo 35 F2 which is pretty small and light weight, it's the size of a nifty-fifty. This is probably the smallest, fastest, widest lens for $100 that will work.
At this point though, if you need your SL1 to be super small, and a lens to be super small, I don't think moving to a dSLR is the right way to go. Unless you needed the larger APS-C sensor coming from M43, for lower light performance, you're not going to get anything significant from it. And the strength of the dSLR is the adaptability of lenses, none of which are small, and they just get bigger and bigger.
Very best,
