Thread started 02 Dec 2015 (Wednesday) 05:33
Using YN622C, YN 622C-TX with Rovelight 600
frozenframe
Gallery: 189 photos
Joined Jun 2013
Dec 02, 2015 05:33 |  #1
I purchased some additional lighting, the Rovelight 600, and a YN 622C-TX, which I should receive within the next week. I want to use my YN622C transmitters with it, and my speedlights, 2-430EX II, and a Shanny SN600C. I purchased the 622C-TX from Amazon, and it shows 2 PC sync cords with it. I'm not sure if they are actually included, I'm thinking they are.
So if I place the YN622C-TX on my camera hotshoe, then one of my YN622C on the Rovelight, attached with a sync cord, will I be able to also control the power settings on the Rovelight from the YN622C-TX? I've read the posts regarding using the Rovelight's transmitter to change power settings, but am wondering if it's possible to just not use it all together?
I'm wanting to do a 3 or 4 light setup, and be able to adjust settings on all flashes from my camera. I have enough YN622Cs, for each flash, and have in the past just used my camera menu to change settings.
Hope my question is clear, it's early morning and I've yet to have my coffee, so a little foggy this morning.. ;-)a
Ron
My Gear List
OceanRipple*
Joined Dec 2014
Post edited over 7 years ago by OceanRipple*. (3 edits in all)
Dec 02, 2015 07:09 |  #2
Hi,
" .. So if I place the YN622C-TX on my camera hotshoe, then one of my YN622C on the Rovelight, attached with a sync cord, will I be able to also control the power settings on the Rovelight from the YN622C-TX? I've read the posts regarding using the Rovelight's transmitter to change power settings, but am wondering if it's possible to just not use it all together? .. "
No, the Yn setup will trigger the Rovelight but it will not modulate power output. Changing power fractions remotely has to be done with the included Jinbei trigger, 'pre-shot'.
The Yn system offers both X-sync timing and the sync timing associated with HSS (ie early) - this affords the option of 'Supersync' - the Rovelight needs to be operating with its 'H' setting enabled, for Supersync to work down as far as 1/16th power.
Timing & duration info here:
https://photography-on-the.net …/showthread.php​?t=1439469
https://photography-on-the.net …ead.php?t=13933​90&page=68
frozenframe
Gallery: 189 photos
Joined Jun 2013
Dec 02, 2015 15:53 as a reply to  @ OceanRipple*'s post |  #3
Thank you for clarifying that.
Ron
My Gear List
frozenframe
Gallery: 189 photos
Joined Jun 2013
Dec 05, 2015 10:18 |  #4
I have another question,
The 2 cords included with the YN622C-TX are used for what exactly? One has what looks like 2 male 3.5mm stereo plugs, the second however has a 3.5mm male stereo plug on one end, the other is an odd shaped plug.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/12/1/LQ_762692.jpg
Image hosted by forum (762692) © frozenframe [SHARE LINK]
What would that odd-shaped plug go to?
Ron
My Gear List
Nutmeger ­ Photos
Gallery: 6 photos
Joined Jan 2015
Dec 05, 2015 10:35 as a reply to  @ frozenframe's post |  #5
I believe those 2 cables are shutter releases. Use the remote tx to act as a shutter release or interval timer.
I just bought a set of Yongnuo YN-560IV and am waiting for them to arrive. I have 2 other flashes, a Nikon SB-700 and a old sunbeam I am hoping I can get to trigger from a RX plate. I hear good things about Yongnuo and the price is amazing so I hope they work for me.
BTH Photos
frozenframe
Gallery: 189 photos
Joined Jun 2013
Dec 05, 2015 11:03 |  #6
Nutmeger Photos wrote in post #17808140 (external link)
I only have the YN transceivers and now the TX, and the transceivers have worked great using them with my speedlights.
Since I'm needing to purchase a sync cord, what is recommended to use to connect one of my YN600C to the Rovelight? Also what length would be best? I'm thinking of hanging the transceiver on the lightstand or possibly attaching it to the light with velcro.
Would this Impact one suffice?B&H Photovideo (external link)
Ron
My Gear List
michaellynnjrphotography
Joined Aug 2013
Dec 06, 2015 23:22 |  #7
following... I'm in the same boat
OceanRipple*
Joined Dec 2014
Dec 07, 2015 02:29 |  #8
frozenframe wrote in post #17808166 (external link)
One mounting option from earlier in this thread ...
https://photography-on-the.net …ead.php?t=13933​90&page=61
Nutmeger ­ Photos
Gallery: 6 photos
Joined Jan 2015
Dec 07, 2015 17:29 |  #9
I am thinking 1' would be long enough. You don't want it to be to long that is just asking for trouble.
What unit are you using with the PC sync cable?
BTH Photos
frozenframe
Gallery: 189 photos
Joined Jun 2013
Dec 07, 2015 22:16 |  #10
Nutmeger Photos wrote in post #17810725 (external link)
One of my YN622C.
Ron
My Gear List
2,851 views & 2 likes for this thread, 4 members have posted to it and it is followed by 2 members.
926 guests, 118 members online
