If you use the adjustment brush with the mask tool and select the Flow of 100 and Density of 100, then move the noise slider to 100, will that remove all noise from the masked area?
P.
Dec 06, 2015 18:18 | #1 If you use the adjustment brush with the mask tool and select the Flow of 100 and Density of 100, then move the noise slider to 100, will that remove all noise from the masked area?
DanMarchant Do people actually believe in the Title Fairy? 5,635 posts Gallery: 19 photos Likes: 2059 Joined Oct 2011 Location: Where I'm from is unimportant, it's where I'm going that counts. More info | Dec 06, 2015 19:27 | #2 I don't know. What happened when you tried it? Dan Marchant
Dec 06, 2015 20:01 | #3 Dan Marchant wrote in post #17809751 I don't know. What happened when you tried it?
Dec 06, 2015 20:14 | #4 To explain an example - I got a good sharp pic of a Swallow Hawk in flight the exposure of it was about average(it could have been slightly lighter but not a lot) it was a against a clear blue sky, there was lots of detail in the feathers that I did not want affected, so I decided the best action would be to use the brush mask tool and to apply the mask around the bird, and just loose the noise in the sky, I did this twice as I said above but noise was still present and not completely clean.
Nogo POTN record for # of posts during "Permanent Ban" 9,194 posts Gallery: 17 photos Likes: 685 Joined Dec 2013 Location: All Along the Natchez Trace (Clinton, MS) More info | Dec 06, 2015 20:45 | #5 You could try it backwards. Philip
Dec 06, 2015 20:58 | #6 Nogo wrote in post #17809833 You could try it backwards. Remove the noise the regular way then make an adjustment to the area you don't want noise filtered from and set to -100. Then if that is not enough do an adjustment on the sky and try to lower clarity and sharpness as well as adding more noise reduction.
Dec 06, 2015 21:27 | #7 I think it worked - I used the mask brush tool first after the initial adjustments to exposure size etc, but this time I reduced clarity to - 40 and sharpness -40 and then noise to +100, after doing that and pressing done I then went into my USM sharpness settings set the mask till no noise speckles showed in the Alt/right key mode - while checking this against varying amounts of sharpening till I got to a mask of 40 and sharpening of 75 while retaining a clear sky. Image hosted by forum (762961) © Pagman [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff.
Nogo POTN record for # of posts during "Permanent Ban" 9,194 posts Gallery: 17 photos Likes: 685 Joined Dec 2013 Location: All Along the Natchez Trace (Clinton, MS) More info | Dec 07, 2015 00:00 | #8 Looks good. You were probably creating noise by sharpening that much in the first attempt. Philip
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Dec 07, 2015 04:43 | #9 Looks good. Elie / אלי
| Latest registered member is Thunderstream 1853 guests, 99 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
