Thread started 09 Dec 2015 (Wednesday) 08:08
noise with Canon 7D
anitaw2
Joined Jun 2015
Dec 09, 2015 08:08 |  #1
I have the older model 7D. I find if I shoot in low light I have so much noise in my pics that they are almost useless. I mean over ISO800. is this the norm? I use the Sigma 17-55 F2.8 lens.
Anita W.
CanonCameraFan
Joined Sep 2011
Dec 09, 2015 08:23 |  #2
Are you shooting in RAW format and processing in PS or LR?
I'm shooting 1600 for concerts and setting NR at 80 in LR 4.4.
I just got my 7D's a couple months ago, so only my last 2 concerts were shot with it. I tried 5000 but was not pleased, so backed off to 1600.
EOS 7D w/BG-E7 (3), 550EX (3), 430EX II, Vivitar 285HV, Opteka 6.5mm/3.5, Canon EF-S 10-18/4.5-5.6 IS STM, Canon EF-S 24/2.8 STM, Canon EF 40/2.8 STM, Canon EF 100mm/2.0 USM, Canon EF 70-300mm/4-5.6 L IS USM, Canon 77mm 500D Macro, Tamrac 614 Bag & 787 Backpack, Crumpler 8 MDH, 7 MDH, 6 MDH
http://www.flickr.com/​photos/johnebersole/se​ts/ (external link)
bacchanal
Dec 09, 2015 08:34 |  #3
Useless/useful is pretty subjective. What is your workflow, what is your output, what are you comparing the results to?
Imo, the 7D should be able to give you acceptable results up to ISO1600, maybe 3200 with some NR and processing, and you can go beyond that depending on the processing and output requirements. It is very important to expose the image correctly in camera as exposure and shadow recovery will certainly degrade your results.
Orogeny
Gallery: 90 photos
Joined Aug 2003
Dec 09, 2015 08:42 |  #4
I shoot a lot of small birds that tend to stay deep in bushes which require me to use high ISOs in order to keep my shutter speed up and I never hesitate to shoot 6400. It all depends on what YOU consider useless.
Here is a significantly cropped photo shot at ISO 5000 using the 7D:
Not National Geographic quality, but I like the photo. Noise is fairly easy to deal with in post processing. Search for posts by forum member TeamSpeed as he has some great information about removing noise from 7D shots.
Tim
There's someone in my head, but it's not me! - Roger Waters
https://www.flickr.com​/photos/orogeny/ (external link)
anitaw2
Joined Jun 2015
Dec 09, 2015 09:24 |  #5
I just shoot as a hobby. I always shoot RAW and process in LR.
Anita W.
gjl711
Dec 09, 2015 09:36 |  #6
Orogeny wrote in post #17812564 (external link)
... Search for posts by forum member TeamSpeed as he has some great information about removing noise from 7D shots.
Tim
I second this suggestion. The 7D can produce very high quality images in high ISO. 6400 should be no problem but I have gone higher as well. However, it is not a forgiving camera and requires some up front planing to make sure you capture the original image as best as you can.As with most Canon cameras, it is not forgiving if the image is under exposed.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Moonshiner
Joined Jul 2013
Dec 30, 2015 23:02 |  #7
I would suggest learning how to use ETTR effectively. I find that the 7D likes to underexpose more than my T3i.
YMMV
Engler519
Joined Feb 2012
Jan 12, 2016 12:20 |  #8
I upgraded from the 7D to the 6D specifically for low light performance. The improvement in noise levels was significant. I can comfortably use the Auto ISO setting with the 6D where I was afraid to go above iso 800 on the 7D.
Engler519
Joined Feb 2012
Jan 12, 2016 12:22 as a reply to  @ Orogeny's post |  #9
Did you post process the noise out of this shot?
maverick75
Joined May 2012
Jan 12, 2016 12:40 |  #10
Bad exposures usually create noise. My first body(10D) could get clean results at 1,600 . There's no way you should be maxing out at 800.
gjl711
Jan 12, 2016 12:45 |  #11
maverick75 wrote in post #17855364 (external link)
I agree, I have a 7D and ISO3200 is pretty easy with minimal nois processing. Above that, well you have to get a lot more aggressive.
::Gear::
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 7 years ago by TeamSpeed.
Jan 12, 2016 20:26 |  #12
Here is a direct unprocessed 7D ISO 800 shot from one of my old 7Ds. I suspect that you are falling into the trap that others do where you don't want to raise the ISO very high, and that is self-defeating in low light, underexposed shots. Raise your ISO to 3200, get the exposure brightened up a bit and I suspect the noise will be less.
https://teamspeed.smug​mug.com …QD/0/X3/7d_iso8​00a-X3.jpg (external link)
Here is ISO 12800 if you learn to expose properly and post process well. This is low light as you can tell from the exif. This exposure is equivalent to an ISO 800 1/20 f2.8, to give you an idea.
IMAGE: https://teamspeed.smugmug.com/Electronics/7D-Full-ISO-JPG-Suite-OOC/i-RjWcqcm/0/X3/IMG_6599-X3.jpg
Orogeny
Gallery: 90 photos
Joined Aug 2003
Jan 12, 2016 21:36 |  #13
Engler519 wrote in post #17855342 (external link)
Yes, I removed some of the noise in LR4.
Tim
ThreeHounds
Gallery: 129 photos
Joined Mar 2014
Jan 12, 2016 21:54 |  #14
This. It's not the high ISO as much as the images sound like they may be underexposed also. Can you post a couple with the EXIF intact?
5D MkIII | 7D | Bronica ETRS
EF 24-105 f/4 L | EF 85mm f/1.8 USM | EF 17-40 f/4 L | EF 70-300 f/4 L | Sigma 35 f/1.4 Art | Zenzanon 105 f/3.5 | Tamron SP90 f/2.8 Di Macro VC USM
Blanton James Photography (external link)
Engler519
Joined Feb 2012
Post edited over 7 years ago by Engler519.
Jan 12, 2016 22:02 |  #15
Yes, I agree, the 7D can do better than iso 800. Most of the issues I had were in a theater setting with mostly poor lighting where I had to keep shutter speed fast enough to stop motion and aperture small enough to control depth of focus. The 6D has been a life saver. When sorting through over 2000 pictures, any post processing steps I can skip saves a lot of time.
11,264 views & 8 likes for this thread, 24 members have posted to it and it is followed by 12 members.
noise with Canon 7D
1677 guests, 140 members online
