Shake before serving
Dec 09, 2015 21:23 | #1 Shake before serving Image hosted by forum (763445) © grizzerbear [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Barry
vilimo Senior Member 558 posts Likes: 109 Joined Apr 2008 More info | Dec 17, 2015 19:42 | #3 Nice picture and looks like a great dressing
Dec 18, 2015 10:50 | #4 Lupo-Lobo wrote in post #17816768 Looks like the good stuff vilimo wrote in post #17823022 Nice picture and looks like a great dressing ![]() To me, there are 2 things that took away from the picture - the black / dark spot (rectangle) on the left and the brightness of the bottle's edge on the right ![]()
Barry
vilimo Senior Member 558 posts Likes: 109 Joined Apr 2008 More info | Dec 18, 2015 12:20 | #5 grizzerbear wrote in post #17823624 Thank you for the comments. I especially appreciate the constructive critique. I'm not very experienced with this type of photography and am not sure how to fix those issues. I imagine I have some lighting techniques to learn! I'd appreciate hearing any ideas. Thanks again. Am not an expert either
Dec 18, 2015 20:16 | #6 vilimo wrote in post #17823713 Am not an expert either ... but if I were taking this photo, I would use a softer light source (or pull the light source a bit further and put a cloth over it to dim it slightly) so that it will not reflect harshly on the right side of the bottle (seems that your light source is about 45 degrees from the bottle's right). As for the dark spot, am not sure what is causing that... the bottle seems to be clear and does not have any label attached to it. If that is a permanent dark spot, I would just turn it so that it is behind ![]() hope that helps ![]() Many thanks for your constructive thoughts and ideas, Vilimo. I look forward to using them! Thanks again! Barry
| Latest registered member is griggt 1435 guests, 104 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
