FORUMS Photo Sharing & Visual Enjoyment Transportation
Thread started 11 Dec 2015 (Friday) 08:19
take off
kingsown
Dec 11, 2015 08:19 |  #1
BAE WARTON off to the southport air show
http://barrowdpc.com/c​pg1414/index.php (external link)
LA ­ Smith
Dec 11, 2015 08:25 |  #2
What a neat old airplane! That thing must be a blast to ride in!
5D,20D, some lenses and stuff
BigAl007
Gallery: 543 photos
Dec 11, 2015 12:54 |  #3
Fairey Swordfish Maritime Strike and reconnaissance aircraft. Operated by the Royal Navy during WWII. The Swordfish was replaced in service by the Fairey Albacore, which was also a biplane, but with an enclosed cockpit. The Albacore was then replaced in service by the Swordfish! The problem was that the Albacore, was heavier and even slower than the aircraft it replaced. It made it a bit of a flop, and so the RN effectively just carried on using the older aircraft.
There are now two flying Swordfish left, both operated by the RN Historical Flight based at RNAS Yeovilton.
Alan
My Flickr (external link)
texaskev
Gallery: 15 photos
Dec 11, 2015 16:34 |  #4
Nice shots! If memory serves, the Swordfish was the type of aircraft that disabled the Bismarck.
Canon 1DX II, 1DX, 11-24 F4 L, 100 F2.8 L, 16-35 F2.8 L II, 17-40 F4 L, 24-70 F2.8 L II, 24-105 F4 L II, 70-200 F2.8 L II
BigAl007
Gallery: 543 photos
Dec 11, 2015 20:25 |  #5
texaskev wrote in post #17815525 (external link)
Yes correct, and probably even more famously disabled/sunk most of the Italian Fleet's battleships in Taranto Harbour, in a low level night torpedo attack on 11/12 November 1940. It was the RN's attack on Taranto that proved that the attack on the USN in Pearl Harbour on 7 December 1941 was highly likely to be successful.
Alan
GibJock
Kill killer
Gallery: 47 photos
Joined May 2013
Location: From Scotland, living in Gibraltar "A Jock on the Rock"
Dec 12, 2015 01:12 |  #6
BigAl007 wrote in post #17815756 (external link)
Alan
So Pearl Harbour could be blamed on us Brits rather than the Japanese? Ooops!
BigAl007
Gallery: 543 photos
Dec 12, 2015 05:53 |  #7
Ian Mackie wrote in post #17815997 (external link)
Well the Japanese had been working on using aerial torpedos in shallow water since about 1938, so I think they already had that idea in mind. There was a Japanese Military Attache on site in Taranto within 24 hrs, and a larger delegation visited soon after. What it does say is if the Brits could do in Taranto with Swordfish and standard "deepwater" torpedos, that then they could do it at Pearl Harbour with their improved equipment. Which is pretty much exactly what happened of course. I think the real lesson of Taranto, which was the first ever true "Naval Aviation" battle, where only aircraft engaged the opposing fleet, was that Naval Aviation worked and was the new cutting edge. It was also where the Japanese attack on Pearl failed, as none of the American carriers were in harbour that morning. So it is Taranto that we should really be remembering, not Midway. By Midway Naval Aviation was fully proved.
Alan
davechng
Joined Oct 2013
Dec 16, 2015 09:35 |  #8
nice string bags! great sets!
would like to see this in person!!!
DaveC
www.airwingspotter.com (external link)
Dedicated to Military Aircraft spotting and great Aviation pictures
PhotosGuy
Moderator
Joined Feb 2004
Dec 16, 2015 10:13 |  #9
It's best to blame your friends, 'cause your enemies just don't give a sh!t? ; D
Pagman
I just hold the thing :-)
Gallery: 2124 photos
Joined Dec 2011
Dec 16, 2015 18:28 |  #10
Its such a shame that the string bags did not act against the Bismarck when they were in action from Hood and the other British battle ship, instead I believe they were just used for recon, perhaps the Hood would not have been destroyed if the Swordfishes had carried and used torpedo's?
P.
Some stuff.
BigAl007
Gallery: 543 photos
Dec 17, 2015 17:36 as a reply to  @ Pagman's post |  #11
The thing is you are not going to load up your reconnaissance aircraft with a very heavy torpedo, s it drastically reduces the range/patrol time. The Stringbag was designed as a multi role, Torpedo Strike and Reconnaissance, TSR, although in the later infamous TSR2, of the 1960's the Torpedo was changed to Tactical. The only disadvantage of using the same airframe for both strike and reconnaissance is that you have to bring the recon birds back to base to convert them into strike aircraft. Rather than being able to launch your strike, while the recon assets stay in place. With a squadron of ships that are cruising at around 25 Kts, a couple of hours or more between the initial sighting and the arrival of the strike force means you still actually have quite a large area of ocean to cover to reacquire the target.
Even the type of weapon chosen can make a big difference. The classic is Yamamoto at Midway, he had his aircraft loaded ready for a bombing strike against Midway Island, when parts of the US carrier fleet were spotted. Instead of then sending the strike aircraft off with the already loaded bombs, he decided to rearm them with torpedoes for a strike against the US carriers. While they were rearming the US got in a hit the Japanese carriers with their own strike aircraft, putting a couple of the carriers out of the battle, and sparing the US fleet serious damage. The US did have a lot of tactical advantages at Midway, but if Yamamoto had launched immediately the successful US strike might not have had any aircraft carriers to return to either.
Alan
GibJock
Kill killer
Gallery: 47 photos
Joined May 2013
Dec 19, 2015 05:06 |  #12
BigAl007 wrote in post #17816103 (external link)
Alan
Thanks for the info Alan, much appreciated.
2,960 views & 3 likes for this thread
take off
Latest registered member is argikon
854 guests, 227 members online
