Other than image stablization and an $800 price difference, what else does the "IS" version of the 70-200mm 2.8 have that the non "IS" doesn't?
Do they have identical glass elements, construction, tripod collars?
snegron Senior Member 503 posts Likes: 142 Joined Jul 2012 Location: Florida More info | Dec 13, 2015 14:06 | #1 Other than image stablization and an $800 price difference, what else does the "IS" version of the 70-200mm 2.8 have that the non "IS" doesn't?
MalVeauX "Looks rough and well used" More info | Dec 13, 2015 14:48 | #2 snegron wrote in post #17817566 Other than image stablization and an $800 price difference, what else does the "IS" version of the 70-200mm 2.8 have that the non "IS" doesn't? Do they have identical glass elements, construction, tripod collars? Heya,
JeffreyG "my bits and pieces are all hard" More info | Dec 13, 2015 15:12 | #3 Just to be clear, Canon has made three different versions of a 70-200/2.8. These are: My personal stuff:http://www.flickr.com/photos/jngirbach/sets/
Bassat "I am still in my underwear." 8,075 posts Likes: 2742 Joined Oct 2015 More info | Dec 13, 2015 15:48 | #4 Permanent banConfusing title. Both of those are the same lens. I thought you had gotten one with a problem, or something. The only II is the IS version. Got it now.
Choderboy I like a long knob More info | Dec 13, 2015 20:48 | #5 Common mistake. People think you pay so much more for IS but it's IS and MKII in the case of 70-200 2.8 Dave
silvex Cream of the Crop More info | Dec 15, 2015 19:24 | #6 The EF 70-200mm 2.8L IS II is on a league of its own. You can pick up a copy from canon's refurbished site for under $1600 with one year warranty. You most keep checking because they go really fast. .
Nethawked Senior Member More info | Dec 16, 2015 11:34 | #7 If you don't need the wider aperture don't discount the 70-200mmL f/4 IS. With 4 stops of stellar image stabilization vs. 3, unless you're into action photography it's just as good in a much lighter and cheaper package.
Dec 16, 2015 13:02 | #8 silvex wrote in post #17820436 The EF 70-200mm 2.8L IS II is on a league of its own. You can pick up a copy from canon's refurbished site for under $1600 with one year warranty. You most keep checking because they go really fast. I'll definitely look into that. Thanks!
Dec 16, 2015 13:04 | #9 Nethawked wrote in post #17821161 If you don't need the wider aperture don't discount the 70-200mmL f/4 IS. With 4 stops of stellar image stabilization vs. 3, unless you're into action photography it's just as good in a much lighter and cheaper package.
| Latest registered member is semonsters 1680 guests, 138 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
