FORUMS Community Talk, Chatter & Stuff Photography Industry News
Thread started 15 Dec 2015 (Tuesday) 15:33
Nikon D5
DarthVader
There is no such thing as Title Fairy ever
Post edited over 7 years ago by DarthVader. (3 edits in all)
Dec 15, 2015 15:33 |  #1
http://nikonrumors.com …ictures.aspx/#m​ore-100027 (external link)
153 af points. Checkmate Canon :-).
Here is the updated list of the rumored Nikon D5 specifications:
New 20MP FX sensor (confident)
New focusing module with larger coverage and 153 autofocus points (confident)
Native high ISO of 102,400 (confident)
15 fps (not sure)
Body design similar to the D4s (confident)
4K video 60/30fps (not sure)
Full HD slow motion (not sure)
Update: 2 identical memory cards (not sure CF or XQD, I was told that both memory cards slots are identical and looked bigger than SD - maybe something got lost in the translation)
Announcement expected in early 2016 (confident)
Nikon/Fuji.
Gear is important but skills are very important :)
thenextguy
Gallery: 105 photos
Best ofs: 8
Dec 15, 2015 15:48 |  #2
But how many of those AF points will be cross type? Will all the cross types still be clustered toward the center of the sensor?
Steve -- Website (external link) -- Instagram (external link) -- 500px (external link)
Canon 5Ds R | 24-70L f/2.8 II | 35 F2 IS | 50mm f/1.4 | 70-200L f/2.8 II
smythie
I wasn't even trying
Gallery: 31 photos
Dec 15, 2015 16:58 |  #3
A much wider array of cross sensitive AF points is the biggest thing I would like improved over the D4/D4s. The bump to 20 odd MP is nice (though 24+ would have been better IMO).
Not that I could afford one for 2 or 3 years minimum...
DarthVader
Dec 15, 2015 18:49 as a reply to  @ thenextguy's post |  #4
It has wider coverage then previous version but not sure the number of x types.
Nikon/Fuji.
smythie
Gallery: 31 photos
Dec 15, 2015 18:53 |  #5
I'd expect it to have wider overall coverage going from 51 to the rumoured 153 points. I'd be happy with 51 if they were wider spaced with cross types out at the edges but I think the smaller mount may be a limitation for them
Keema
Joined Feb 2012
Dec 15, 2015 20:46 |  #6
153 AF points and with "wider" coverage is really good! Hope it will be! :)
But, like what other is saying here, how many and which will be cross-type/s?
Anyway, will just wait for the announcement.. :)
DarthVader
Jan 04, 2016 18:57 |  #7
http://nikonrumors.com …their-facebook-page.aspx/ (external link)
Nikon/Fuji.
smythie
Gallery: 31 photos
Jan 05, 2016 00:34 |  #8
Hmm, let's hope something is coming
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jan 05, 2016 00:37 |  #9
153 AF Points? That's 3 times what the top bodies have now.. I'm not sure what that will do for performance actually, but I'm intrigued to see what Nikon does with the D5.
CDS' HOT LINKS
thenextguy
Gallery: 105 photos
Best ofs: 8
Jan 05, 2016 13:43 |  #10
It's official.
http://www.dpreview.co​m …rofessional-grade-d5-dslr (external link)
Also, they announced a D500!
DarthVader
Jan 05, 2016 14:42 as a reply to  @ thenextguy's post |  #11
D400 could cause bad luck.
Nikon/Fuji.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Post edited over 7 years ago by CyberDyneSystems.
Jan 05, 2016 15:57 |  #12
99 cross type AF sensors,. 153 total. Wow.
20MP @ 14fps.. ISOs of up to 3,280,000! (sensor is said to be "developed by Nikon CMOS", does htis mean it's not Sony Exmor? )
Low light sensitivity of the AF points have also been improved: the central point is sensitive down to -4 EV, ( Previously the only body capable of that -4EV was the A7s as far as I know) with all other points sensitive to -3 EV.
CDS' HOT LINKS
smythie
Gallery: 31 photos
Jan 05, 2016 16:02 |  #13
D500! Oh Yeah!
Great looking specs and interestingly less resolution than the D7200 (~20mp vs ~24mp). I wonder who designed/builds this sensor. D5 up to ~20mp from 16mp - a very welcome bump
D5 Press release (external link)
D500 Press release (external link)
"Technology Digest" (external link)
Same AF system
- (153 points, 99 cross, ).
- 98 of those are not selectable though leaving 55 selectable in total and 35 cross types selectable
- Near full width coverage in the D500 but still pretty big in the D5 (would have liked bigger in the D5 ideally though but still an improvement).
- centre at -4EV and rest at -3EV
- The DX crop mode in the D500 (down to roughly the same size as m4/3) cuts out a number of the available AF points. Why bother with the crop mode then? Just shoot normally and crop in post.
(below was snipped from section 1-1 of the digest)
IMAGE: http://smythie.id.au/images/Other/D5-D500%20AF%20Array.jpg
The new AF array looks interesting (I assume it will eventually filter down to the D810 and D750 replacements). I'll be interested to see how it performs in the field. Finally they've given us some cross sensitive points at the edges of the frame. I'll also be interested to see how the available max aperture of the mounted lens affects the operation of those points. I'm hoping at least the centre cluster retain their f/8 sensitivity
- Frame rate: D500 matches the 7D2 and D5 (finally) catches up to the 1DX (12fps with AF and 14 locked out)
- Buffer: 200 12-bit lossless raw for both (using the highest speed XQD available). I'm guessing 14-bit lossless should be in the order of 150 or so. Wow!
- Native ISO range: 100 to a bonkers 102400 in the D5, only astounding 51200 on the D500. I'm hoping the D5 should be very clean at 25600
- Higher res main touch screen, tilting in the D500 with a couple of extra functions over the fixed touch screen on the D5
- Automatic MFA using Live-view. That will be very interesting
- Flicker reduction: Astoundingly the D5 only uses it for movies while the D500 uses it for movies and stills. What's with that?
- Dual memory slots in both. D500 uses SD and XQD while Nikon is building two versions of the D5, one with dual XQD and one with dual CF - no mention of CFast though
- Radio control for speedlights
- 4K Video; But only 3 minute duration on the D5 (what's with that?) while a second short of 30 minutes in the D500
- HDMI output to external recorder on D500 (unsure of D5)
- Electronic VR in-body on D500 in video recording
Some interesting differences there. The D500 looks like a good competitor to the 7D2 (albeit a year or so late) while the D5 should at least give Canon something to leap over with the 1DX replacement. Looking forward to reviews to see how they perform
FarmerTed1971
fondling the 5D4
Gallery: 66 photos
Joined Sep 2013
Jan 05, 2016 16:06 |  #14
Still doesn't work with EOS glass.
 :p
Getting better at this - Fuji X-t5 & X-t3 - 16 1.4 - 35/50/90 f2 - 50-140 - flickr (external link) - www.scottaticephoto.co​m (external link)
smythie
Gallery: 31 photos
Jan 05, 2016 16:08 |  #15
FarmerTed1971 wrote in post #17845852 (external link)
 :p
hahaha.
13,639 views & 12 likes for this thread, 12 members have posted to it and it is followed by 7 members.
Nikon D5
911 guests, 117 members online
