I bought this Magic Arm
for supporting a flash for macro photography. A picture of mine is below.
It is possible to remove the fitting with the flash shoe on the left. This reveals a 1/4 inch screw. With 1/4" screws at both ends, it is possible to connect one end of the arm to a tripod ring and the other end to a flash.
However, with the flash (580EX) in place, I am finding that the rig is very unstable. The sleeves that connect to the ball joints rotate under the weight, and the 1/4" screws also twist and turn.
So I'm wondering if anyone else has experience with these, or if there is a way to tighten it or otherwise use it properly. Right now I'm thinking it is useless.
