Thread started 24 Dec 2015 (Thursday) 16:19
Problem with macro extension tubes and chosing aperture
Lotta
Joined Dec 2015
Dec 24, 2015 16:19 |  #1
I have just got a set of macro extension tubes (for Canon). The problem is that it is not possible to chose the aperture when one or several rings are attached to the lens, it is fixed at F00. See photo...
The electronic contact "points" are slightly different on the tubes than on the lenses (Canon lenses) and we suspect that might be the fault? Has anyone had the same problem?
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/12/4/LQ_766080.jpg
Image hosted by forum (766080) © Lotta [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/12/4/LQ_766081.jpg
Image hosted by forum (766081) © Lotta [SHARE LINK]
Beekeeper
Gallery: 46 photos
Dec 25, 2015 05:41 |  #2
The contact points look like the ones on my Kenko tubes I just got on the 23rd. Not sure what the issue is. I'm wondering if you are getting some kind of incomplete connection between the tube(s), lens, and camera?
Zach--C&C is welcome on my photos
https://www.flickr.com​/photos/46367607@N06/ (external link)
7DI Body Gripped|7DII Gripped|EF 85mm1.8|EF 50mm1.4|EF 100mm2.8L IS Macro|EF-S 10-22mm|EF 400mm5.6L|430EXII|580E​XII
Lotta
Joined Dec 2015
Dec 25, 2015 15:22 as a reply to  @ Beekeeper's post |  #3
How are your Kenko tubes working?
Beekeeper
Gallery: 46 photos
Dec 25, 2015 16:01 |  #4
Lotta wrote in post #17832244 (external link)
I've only given them a quick function check on the night of the 23rd, and they functioned fine. I worked a long Christmas Eve night, and haven't had a chance to really test them yet, but funtion wise everything seems to work fine. What brand did you get? If you are having issues I'd try to return them.
Lotta
Joined Dec 2015
Dec 26, 2015 02:09 as a reply to  @ Beekeeper's post |  #5
Worked yesterday, but will look at it again today. The package has no brand name...
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2015/12/4/LQ_766246.jpg
Image hosted by forum (766246) © Lotta [SHARE LINK]
Alveric
Gallery: 38 photos
Dec 26, 2015 03:25 |  #6
My Kenko tubes work fine. Lotta, I think your problem is that the units you got were made by the lowest bidder: not uncommon with cheap Chinese stuff.
NickWell24
Joined Sep 2014
Post edited over 7 years ago by NickWell24.
Dec 26, 2015 08:53 |  #7
If you're not ready to pony up the dough for Kenko tubes Neewer had a set that runs about $30 on amazon. I purchased a set and after exchanging the first set because they didn't work properly I've had good results from them. I used 3 of them stacked to help get this image.
IMAGE: https://farm1.staticflickr.com/377/18718912812_b678805a1b_b.jpg
Canon 6D, Canon 16-35 f/4L, Canon 24-70 f/2.8L ii, Canon 70-200 f2.8Lii, Canon 85 1.8, Canon 135 2L, Sigma 35 1.4A
racketman
Gallery: 20 photos
Dec 26, 2015 16:11 |  #8
at least they have the coveted red ring!
Toby
Wilt
Post edited over 7 years ago by Wilt. (2 edits in all)
Dec 26, 2015 17:26 |  #9
I purchased a very inexpensive tubes ($58 shipped) with electronic contacts from a vendor on eBay, and although folks can put ONE tube onnevertheless they lose contact with multiples stacked...Yet I can stack all three and still communicate with the lens as if none were there. My expeience does not solve your problem, but it does give you an idea of what is POSSIBLE, even with the expense of Kenko tubes.
3,589 views & 7 likes for this thread, 6 members have posted to it.
2292 guests, 130 members online
